Small block aluminum heads. #2410628
11/29/17 12:20 PM
11/29/17 12:20 PM
Bradford, Ontario
Barrelhouse Offline OP
Bradford, Ontario
Hello fellow Moparts members. I will be buying a set of aluminum heads for my 340 engine rebuild . Who makes the best quality castings. My engine builder says my 340 will be making a honest 400 to 450 HP what are my options ?, thanks.
Re: Small block aluminum heads. [Re: Barrelhouse] #2410634
11/29/17 12:32 PM
11/29/17 12:32 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Edelbrock Performer RPM is my vote.
Re: Small block aluminum heads. [Re: Barrelhouse] #2410669
11/29/17 01:21 PM
11/29/17 01:21 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Sadly, the Eddy heads leave a LOT to be desired.
Remember the Engine Masters video where they ran the 408 Ford/Mopar engines?
Dulcich later ported the Mopar heads and gained nearly 100 hp.
- Stu Harmon
Re: Small block aluminum heads. [Re: feets] #2410710
11/29/17 03:09 PM
11/29/17 03:09 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
Yeah, but the op made no mention of stroking the motor. Eddie RPM heads flow more than enough to feed 340 cubes and will easily meet the stated HP goals.
Re: Small block aluminum heads. [Re: Barrelhouse] #2410741
11/29/17 03:57 PM
11/29/17 03:57 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
For that build, the Sidewinder heads are perfect. Built to your specs ( as needed) better quality hardware, and less money, with a better casting.
RIP Monte Smith
Re: Small block aluminum heads. [Re: CompWedgeEngines] #2410993
11/29/17 10:32 PM
11/29/17 10:32 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
Sidewinders get my vote for a stock stroke 340 up
Re: Small block aluminum heads. [Re: Barrelhouse] #2411200
11/30/17 12:10 PM
11/30/17 12:10 PM
IN
polaraholic Offline
polaraholic  Offline
IN
Mopar performance heads are like the edelbrock but have the stock plug angle. That will make it easier to find headers that fit. If you know someone that works at Chrysler they get a discount on parts just like on cars.
Re: Small block aluminum heads. [Re: polaraholic] #2411287
11/30/17 02:24 PM
11/30/17 02:24 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
That's a big block head deal.
Re: Small block aluminum heads. [Re: autoxcuda] #2411296
11/30/17 02:47 PM
11/30/17 02:47 PM
WASHINGTON, PA
11secaarcuda Offline
WASHINGTON, PA
Where to buy Sidewinder heads?
67 Dart GT 340 4 speed
70 AAR Cuda 408 6 barrel
96 Indy Ram original owner
2011 Hemi Durango
Re: Small block aluminum heads. [Re: Barrelhouse] #2411302
11/30/17 03:01 PM
11/30/17 03:01 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Trick Flow showed a new set for small blocks at SEMA
Mo' Farts
Moderated by "tbagger".
Re: Small block aluminum heads. [Re: Barrelhouse] #2411310
11/30/17 03:21 PM
11/30/17 03:21 PM
GA
roadrunninMark Offline
GA
I am going with the sidewinders too. Marsh Performance, I believe his name is Todd (been a while), he is a member on here. Get them direct and save 100 over JEGS.
Re: Small block aluminum heads. [Re: autoxcuda] #2411335
11/30/17 04:11 PM
11/30/17 04:11 PM
IN
polaraholic Offline
polaraholic  Offline
IN
Yeah mine are BB but they do have small block heads. ( I'm retired Chrysler just trying to keep the checks coming.)
Re: Small block aluminum heads. [Re: polaraholic] #2411354
11/30/17 04:44 PM
11/30/17 04:44 PM
dogdays Offline
dogdays  Offline
Choices for aluminum smallblock heads are few:
Listing from low$ to high$.
ProComp (Speedmaster) are the least expensive especially if you start with the bare heads and build them yourself. Although many will tell you that Speedmaster = Chinese junk, the casting in the last few years has improved in quality. Valve guides and valve job will need checking out after you buy the other components.
Sidewinder These heads start out with a high quality Chinese casting and are assembled by Marsh Racing, used to be called Moparts Racing. Owner is Todd Marsh, known on this board as Sasquatch. These heads will be custom made to your specs, meaning you have to confer with Todd to get what you need. He (or staff) assembles the heads with name brand parts. Clearances and valvejobs are correct. These are the only aluminum heads that come totally ready to run, no need to take them to the machine shop to check stuff.
ProMaxx These heads start out with the same casting as Sidewinder. A different company builds them and they are available from Summit and Jegs, etc. I seem to remember that this is the same group of guys who make Patriot heads for other engine brands. The disadvantage over the Sidewinders is, Promaxx costs more and you have no assurances the heads are ready to run.
Edelbrock These heads are very good but you pay more to get an American casting. They need to be looked at to be completely sure but there have been many bolted on out of the box with complete success. Available in both Magnum and LA configurations.
That's it AFAIK. Any of these heads will make 500hp with no port work. All of these heads have CNC programs already developed that will increase flow by quite a bit. Despite all the B$ floating around, they are all decent heads.
The value leader has got to be Sidewinder. Next to lowest price, hand assembled and checked, using name brand parts, what's not to like?
When looking at prices be sure to price a pair of heads. A couple of manufacturers price heads each.
R.
Re: Small block aluminum heads. [Re: Barrelhouse] #2411449
11/30/17 08:31 PM
11/30/17 08:31 PM
St Louis, MO, USA
srunge55 Offline
srunge55  Offline
St Louis, MO, USA
If you can wait until the 3rd quarter 2018 the new Trick Flow PowerPort 190 heads for small block mopar will be available. The TF big block heads are very nice and I'm sure the small block heads will be the same. Fully assembled and ported head ready to bolt on. I don't know the pricing but the BB heads are an excellent value.
Re: Small block aluminum heads. [Re: srunge55] #2411453
11/30/17 08:46 PM
11/30/17 08:46 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Predicting somewhere around 2100.00 a pair
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Small block aluminum heads. [Re: pittsburghracer] #2411466
11/30/17 09:24 PM
11/30/17 09:24 PM
dogdays Offline
dogdays  Offline
No doubt the TrickFlow heads will be primo. For half the price, though, the Sidewinders will make 500hp just as easily.
Edelbrocks are $1370 a pair.
R.
Re: Small block aluminum heads. [Re: dogdays] #2411512
11/30/17 11:11 PM
11/30/17 11:11 PM
IN
schmitty Offline
schmitty  Offline
IN
I ran a set of edelbrocks on my daily driver with great reliability and decent performance. Exhaust ports on these stock port located heads are strongly hindered; but I found a ton of low end torque with my mild build that I could drive anywhere on a daily basis. Torque is King on the street!
