MILODON GEAR DRIVE #2410245
11/28/17 06:43 PM
11/28/17 06:43 PM
Queensland Australia
moparmacka Offline OP
Chasing some advice on fitting a Milodon gear drive to my LA stroker. Tried fitting the gears to the crank and cam only to find out WAY too tight with approx 0.0018 interference fit. Milodon couldn’t give me an exact answer......”snug fit”. So was wondering what most of you chase when fitting these gears. I was thinking along the lines of 0.0005 - 0.0008.
Thanks again
Macka
Re: MILODON GEAR DRIVE [Re: moparmacka] #2410268
11/28/17 07:51 PM
11/28/17 07:51 PM
Washington
madscientist Offline
Washington
I've never had to fit either gear. That seems weird but if you have to hone them a bit you have to hone them.
I don't think .00018 is much more than it should be. Honestly mine have always fit so I've never measured the press fit.
Re: MILODON GEAR DRIVE [Re: moparmacka] #2410284
11/28/17 08:23 PM
11/28/17 08:23 PM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
Not used that part exactly, but .001-.002 is common for press fit on crank snout stuff that's not driving a blower or something. Add a little heat and should slide right on. S/F....Ken M
Re: MILODON GEAR DRIVE [Re: moparmacka] #2410403
11/28/17 11:24 PM
11/28/17 11:24 PM
TN
SCATPACK 1 Offline
SCATPACK 1  Offline
TN
Heat it and it should slide right on. i would rather have it be a little snug than a little loose when the motor heats up.
Old Geezer Racing
Re: MILODON GEAR DRIVE [Re: SCATPACK 1] #2410446
11/29/17 12:33 AM
11/29/17 12:33 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
Last time I fitted one, I popped it in the oven and dropped it on
Alan Jones
Re: MILODON GEAR DRIVE [Re: LA360] #2410560
11/29/17 06:24 AM
11/29/17 06:24 AM
Silly question .....what’s temp is safe as to not adversely effect the hardness/metallurgy of the material?
Re: MILODON GEAR DRIVE [Re: moparmacka] #2410564
11/29/17 07:52 AM
11/29/17 07:52 AM
Victoria, Australia
Ian Offline
Ian  Offline
Victoria, Australia
Originally Posted By moparmacka
Silly question .....what’s temp is safe as to not adversely effect the hardness/metallurgy of the year material?
just use a emery roll on the inside just a little thats how mick and i done ours
1.37 60 ft [email]6.0@113[/email] [email]9.57@141[/email] 408 glide 3550lbs
new video http://www.youtube.com/watch?feature=player_embedded&v=Xvq3ZObywQE
Re: MILODON GEAR DRIVE [Re: moparmacka] #2410568
11/29/17 08:35 AM
11/29/17 08:35 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I usually heat bearings or races/etc up to 300 degrees Fahrenheit to achieve a slip fit, or 148 C for you metric guys...
Re: MILODON GEAR DRIVE [Re: Ian] #2410573
11/29/17 09:04 AM
11/29/17 09:04 AM
That thought crossed my mind if the oven thing doesn’t work.
Re: MILODON GEAR DRIVE [Re: DAYCLONA] #2410574
11/29/17 09:05 AM
11/29/17 09:05 AM
Thanks!
Re: MILODON GEAR DRIVE [Re: moparmacka] #2410623
11/29/17 12:09 PM
11/29/17 12:09 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Take it to someone who can hone a harmonic balancer. He should be able to get it where you need it.
2011 Drag Pak Challenger
Re: MILODON GEAR DRIVE [Re: moparmacka] #2410629
11/29/17 12:24 PM
11/29/17 12:24 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Just use the appropriate size brake cylinder hone to get proper press fit.If you heat it to press them on then if you have to remove it can be very difficult.It may galled to the crank and you have a real mess.Add antiseize before installing.
Re: MILODON GEAR DRIVE [Re: B G Racing] #2410719
11/29/17 03:22 PM
11/29/17 03:22 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
This iagree ,also I fill the key slot with bondo or fiberglass resin. after a light smear of vasoline so it dosen't stick. then I save them for future use.
Re: MILODON GEAR DRIVE [Re: moparmacka] #2410729
11/29/17 03:38 PM
11/29/17 03:38 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
only to find out WAY too tight with approx 0.0018 interference fit. Milodon couldn’t give me an exact answer I was thinking along the lines of 0.0005 - 0.0008.
Thanks again
Macka [/quote]
.0018 is way too tight. I have never ever had to heat any crank gear or cam gear on anything to make it fit. At +.0018, your shearing metal off to get it to fit. Keep in mind, a crank damper is typically a press on fit, at +.0006 to .0008. That is a positive press because of the nature of the part itself and what it does. A cam gear doesnt need a press fit as such, and the crank gear, well, yes tighter to keep harmonics and such in check, but 99% of them STILL are a slip fit, maybe a slight tap with a brass hammer.Where is a crank gear going to go with a keyway in it? If its too loose, then chain whip and harmonics can affect it for sure, bit it never should need heat to install.
Something doesnt sound right here, unless, the crank is a bit oversized on the snout dimension, and the cam is the same?
If you must make an adjustment, a rod hone is the correct way to do it, with a keyway mandrel. Its the only way to properly keep it straight and round, but I am sure some of the other ways here will " get it done" if thats your decision .
RIP Monte Smith
Re: MILODON GEAR DRIVE [Re: moparmacka] #2410805
11/29/17 05:26 PM
11/29/17 05:26 PM
Honed to the correct size sounds like the way to go!
Re: MILODON GEAR DRIVE [Re: moparmacka] #2410834
11/29/17 06:23 PM
11/29/17 06:23 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We find many aftermarket cranks vary in dementions,snug is better than loose,press fit is idea, interference is not.We have seen crank gears actually split and crack from being forced on and once seen a Milodon gear go out of round from too much heat being applied and crack from becoming too brittle.Too tight or loose can cause metal transfer result in galling and actual weld the gear to the crank snout.
Re: MILODON GEAR DRIVE [Re: moparmacka] #2410835
11/29/17 06:24 PM
11/29/17 06:24 PM
MR_P_BODY Offline
MR_P_BODY  Offline
With .0018 you might not even get it on..
might pull the threads out of the crank..
I had to hone 2 of mine.. I set them for
.0007 press and it was still tight with no
warming them.. once its on and off its a
bit easier
wave
Re: MILODON GEAR DRIVE [Re: moparmacka] #2411018
11/29/17 11:25 PM
11/29/17 11:25 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I've always felt that nothing negative "starts" to occur on steel until the 400F range.
Re: MILODON GEAR DRIVE [Re: moparmacka] #2411143
11/30/17 04:02 AM
11/30/17 04:02 AM
Cab_Burge Online work
Cab_Burge  Online Work
up iagree
Hone it until it barely slides on up
