2500 Ram rear differential question. #2410134
11/28/17 02:36 PM
11/28/17 02:36 PM
God's Country Maryland
GODSCOUNTRY340 Offline OP
I found the window sticker in the glovebox of my 2011 2500 Megacab Cummins Ram. In the left column ( std. options) it has 10.5" differential but the right side (optional equipment) it has 11.5" differential with limited slip. It has a 14 bolt cover, which rear is in my Ram?
Re: 2500 Ram rear differential question. [Re: GODSCOUNTRY340] #2410141
11/28/17 02:57 PM
11/28/17 02:57 PM
Lakeland, FL
sixpakchallenger Offline
Lakeland, FL
you can get your build sheet from dodge:
https://www.dodge.com/webselfservice/dodge/index.html
Click on the link down the left side of the page that says "Equipment List"
Enter your VIN in the smaller search bar and click search
But that should be an AAM 11.5
Codes:
[DME]=Axle Ratio - 3.73
[DMF]=Axle Ratio - 4.10[
[DRW]=Axle - Rear,10.50
[DRQ]=Axle - Rear,11.50
[DRX]=Axle - Rear,11.50, Dual Wheels
[DSA]=Axle - Anti-Spin Differential
2007 Mustang GT Vert
2004 Ram 2500 QC 4X4
1971 Challenger Vert 5.7 Hemi Project
Re: 2500 Ram rear differential question. [Re: sixpakchallenger] #2410142
11/28/17 03:02 PM
11/28/17 03:02 PM
Indiana
EV2DEMON Offline
The Camaro Kid
EV2DEMON  Offline
The Camaro Kid
Indiana
10.5" was standard on the 2500. Selecting the Cummins option automatically added the 11.5 AAM.
Re: 2500 Ram rear differential question. [Re: EV2DEMON] #2410147
11/28/17 03:22 PM
11/28/17 03:22 PM
Thanks guys.
Re: 2500 Ram rear differential question. [Re: GODSCOUNTRY340] #2410888
11/29/17 07:39 PM
11/29/17 07:39 PM
dogdays Offline
dogdays  Offline
Dodge was doing some funky things like Dana 70 with a Dana 80 center section.
In your case my online lending library confirms that your center section at least is the AAM 11.5" used also on GM trucks.
https://www.drivetrainshop.com/GM_Chrysler_AAM_11_5_s/104.htm
R.
