Re: 4 speed hump
[Re: MoJoe]
#2409897
11/28/17 12:13 AM
11/28/17 12:13 AM
Posts: 5,139 East Aurora (Buffalo) NY
RoadRunner
Yep. You will have to cut away a section of the floor pan to clear the shifter mechanism and make clearance for the rods. The cutaway will leave a tear drop shaped hole. The hump provides room and also provides a surface to mount the shift boot.
68 Road Runner (383/4speed, post car w/decor pkg) - Major Project 69 Road Runner w/472 Hemi & 4 speed. 70 Challenger R/T SE EF8 w/ V9J, U - A32 - Major Project 2023 Ford Mach 1
Re: 4 speed hump
[Re: MoJoe]
#2409969
11/28/17 02:25 AM
11/28/17 02:25 AM
Posts: 43,292 Bend,OR USA
Cab_Burge
I'm doing a 4 speed conversion on a 69 b body...do I really need the hump? Only if you want to do it correctly, look proper and work well
