Distributor-oil pump drive shaft breaks #2409128
11/26/17 02:56 PM
11/26/17 02:56 PM
TP Exit 7, NJ, USA
DANA60 Offline OP
DANA60  Offline OP
TP Exit 7, NJ, USA
I lost oil pressure at the end of a run yesterday. I pulled the distributor and then the gear/shaft. It was sheared off at the bottom that goes into the oil pump. I pulled the pump and the shaft was shattered in pieces. The pump seems to spin OK so it doesn't appear that it locked up. I still need to take it apart to look inside. The gear was a Mopar Perf. one, not the stock one. Any suggestions on what happened.
Re: Distributor-oil pump drive shaft breaks [Re: DANA60] #2409138
11/26/17 03:23 PM
11/26/17 03:23 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Yeah. The Mopar Performance piece failed. Take the intake off and verify that the shaft isn't in a bind between the distributor and oil pump. If all is ok, get a Milodon shaft.
[image][/image]
Re: Distributor-oil pump drive shaft breaks [Re: sgcuda] #2409149
11/26/17 03:57 PM
11/26/17 03:57 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
If he's running a flat tappet/iron gear, are the stock ones failure prone? How are the melling shafts?
Re: Distributor-oil pump drive shaft breaks [Re: DANA60] #2409155
11/26/17 04:08 PM
11/26/17 04:08 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I would have expected to have junk in the pump lock it up to cause that. Sheared, shattered, twisted - how it broke may indicate a heat treat problem. Not good. I would be looking at everything.
Re: Distributor-oil pump drive shaft breaks [Re: DANA60] #2409157
11/26/17 04:12 PM
11/26/17 04:12 PM
How many runs and years of use did you have on this unit?
I have twisted more than one of the Mopar Hi Po off with debris in the pump realcrazy
It didn't break for no reason scope Maybe what broke it went up into the motor shruggy
Figure out what went wrong before proceeding and correct it up twocents
Re: Distributor-oil pump drive shaft breaks [Re: CMcAllister] #2409179
11/26/17 05:03 PM
11/26/17 05:03 PM
TP Exit 7, NJ, USA
DANA60 Offline OP
DANA60  Offline OP
TP Exit 7, NJ, USA
I still have to take the pump apart. It does spin freely when I took it out. Roller lifter, belt drive, 1st run on this motor, the pump is fairly old, we took it apart before assembly and cleaned it, the gear/shaft was brand new. The binding comment may have something to do with it. The gear/shaft went in a little harder than I'm use to. What could cause the binding?
Re: Distributor-oil pump drive shaft breaks [Re: DANA60] #2409360
11/26/17 11:13 PM
11/26/17 11:13 PM
Do you have a old stock oil pump drive unit? If so have the teeth removed from it and install it into your block with that pump and use a long handle screw driver to rotate the pump counter clockwise to check for binding scope wrench
Is this a internal pick up oil system oil system or external pickup system? If you are you using the stock pump with the stock cover it shouldn't matter how it spins in the block compared to out of the motor, but if you don't check it both ways you won't know if it does have a problem installed in the block or not scope thumbs
I built a bracket race motor several years ago with a new cast iron 4.500 bore World block and a Milidon dual line external oil system that worked fine on the engine stand when priming and checking, worked fine for 30 minutes on the engine dyno and then twisted the new Milidon shaft off in the pump rotor runaway puke Luckily it was running under 2500 RPM warming up after lunch so no damage was done to it boogie That dang block had a .003 machining ridge on the oil pump mounting boss that ended binding that cast aluminum Milidon oil pump body enough to bind and twist off that shaft when warmed up the second time work
Good luck on your deal, let us know what you had to do to fix it thumbs
Re: Distributor-oil pump drive shaft breaks [Re: DANA60] #2409396
11/27/17 12:11 AM
11/27/17 12:11 AM
New York
polyspheric Offline
polyspheric  Offline
New York
X2
Boffin Emeritus
Re: Distributor-oil pump drive shaft breaks [Re: CMcAllister] #2409422
11/27/17 12:51 AM
11/27/17 12:51 AM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
Yeah, only time I have seen them break.
1963 Plymouth Max Wedge
1971 Barracuda
Re: Distributor-oil pump drive shaft breaks [Re: ozymaxwedge] #2409473
11/27/17 02:49 AM
11/27/17 02:49 AM
Great Neck,LI,new york
hemi-itis Online content
hemi-itis  Online Content
Ditto,I did that one time only!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Distributor-oil pump drive shaft breaks [Re: DANA60] #2409536
11/27/17 12:10 PM
11/27/17 12:10 PM
TP Exit 7, NJ, USA
DANA60 Offline OP
DANA60  Offline OP
TP Exit 7, NJ, USA
Thanks for the help guys. It's an external PU. with a milodon pump. The pickup has a front and back PU. The block is a 400 cast block, 512, that I had replaced the same. Pretty much everything was replaced, except the pump. I will take apart the pump later, but as I said, it seem to spin freely. I'll drop the pan as well to check.
Again, thanks for the help.
Re: Distributor-oil pump drive shaft breaks [Re: DANA60] #2409543
11/27/17 12:28 PM
11/27/17 12:28 PM
On a side note, with the quality/fitment issue resolved, install the pump with the bolts lightly snugged then drop in the intergear then torque the pump bolts the rest of the way for a dead on hex alignment. EDIT with the pump out confirm the intergear turns free, one of mine had interference on the intergear cross pin to the bushing, it was driven down a bit too far.
Re: Distributor-oil pump drive shaft breaks [Re: DANA60] #2409666
11/27/17 04:40 PM
11/27/17 04:40 PM
Is your Milidon pump the cast aluminum or the billet aluminum one? Both of them now use three O rings on them to seal between the block and pump, are you using a gasket also? If so, don't tsk
How much torque are you using on the four 3/8 inch pump retaining bolts?
The shaft broke for a valid reason, figuring out what caused it is the hard part, huh whistling grin Dang Murphy anyways runaway
Good luck, let us know what you find, that will help others in the future thumbs
Re: Distributor-oil pump drive shaft breaks [Re: DANA60] #2409872
11/27/17 11:23 PM
11/27/17 11:23 PM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
Something small and hard has made it's way into that pump.
A needle roller from a rocker was the cause of my last fail, I now have a -12 filter before (external feed line) the pump and don't use needle roller type rockers.
1971 Barracuda
Re: Distributor-oil pump drive shaft breaks [Re: DANA60] #2409880
11/27/17 11:41 PM
11/27/17 11:41 PM
P
Porter67 Offline
Porter67  Offline
P
Now clue why but I snapped a oem shaft off a 440 in my 4x4 just by hitting a deep pothole, simply replaced the shaft and never happened again....never figured out why it happened.
Re: Distributor-oil pump drive shaft breaks [Re: DANA60] #2410231
11/28/17 06:28 PM
11/28/17 06:28 PM
TP Exit 7, NJ, USA
DANA60 Offline OP
DANA60  Offline OP
TP Exit 7, NJ, USA
I took the pump apart, a couple scratches, nothing major. Nothing in the filter, nothing in the pan, all clean. I did not use a gasket. The pump is an older cast one. I have a Titan on another motor, I'll use that one. There were no marks at all on the brass gear, very clean. Could it of been from 1) Just a junk part, bad metal? 2) Could the alignment problem with the shaft (too long by mistake, or the shaft just wrong)?
