Page 4 of 7 1 2 3 4 5 6 7
Re: Exhaust Interference and Drone Problems [Re: Supercuda] #2408385
11/24/17 08:13 PM
11/24/17 08:13 PM
SoCal
MuuMuu101 Offline OP
I got lucky at Woodward!
SoCal
How long is it and what kind of clamp would be required?
Re: Exhaust Interference and Drone Problems [Re: MuuMuu101] #2408421
11/24/17 10:16 PM
11/24/17 10:16 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
Are you running a crossover up front? (an H-pipe or an X-pipe)? If not, that will help. Do you have room in front of the mufflers for some resonators?
Re: Exhaust Interference and Drone Problems [Re: Sunroofcuda] #2408521
11/25/17 02:20 AM
11/25/17 02:20 AM
So Cal
autoxcuda Online content
autoxcuda  Online Content
So Cal
what is the smallest out side diameter resonator for 2 1/2" pipe? These are so low there's scrapage from high centering on speed bumps and driveways.
Re: Exhaust Interference and Drone Problems [Re: MuuMuu101] #2408546
11/25/17 03:19 AM
11/25/17 03:19 AM
Brisvegas, Australia
Alchemi Offline
Alchemi  Offline
A couple of the older posts alluded to these but you seem to have missed what they were talking about - Terms for the same thing: Helmholtz resonator, 1/4 Wave resonator, Branch Resonator
Google Branch Resonator and the flick to the images results to get the idea
This page has some technical ways to work out lengths
http://mkiv.supras.org.nz/articles/exhaust_drone.htm
You could possibly fit a pair above the diff?
With some creativity you could make them adjustable fairly easily
Re: Exhaust Interference and Drone Problems [Re: autoxcuda] #2408570
11/25/17 06:17 AM
11/25/17 06:17 AM
SoCal
SoCal
I'm already running an X-pipe and there really isn't any room in the front for a resonator. That was the first thing I mentioned to the muffler guy when I brought the car in.The exhaust is too close to the body and transmission. Heck, I'm even rubbing in a couple of spots. Anyway, the diameter of the smallest resonators that I could find was 4" as shown in my links above.
And I have high centered the car on a speed bump in my work parking lot before, but since then I've raised the car in the front about 1/4-1/2" and added stiffer springs.
Re: Exhaust Interference and Drone Problems [Re: Alchemi] #2408571
11/25/17 06:19 AM
11/25/17 06:19 AM
SoCal
SoCal
I saw them, and it's a cool idea I would like to implement, but that would require welding and that's a skill I am not comfortable with just yet.
Re: Exhaust Interference and Drone Problems [Re: MuuMuu101] #2408688
11/25/17 03:33 PM
11/25/17 03:33 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I'd ask Accurate, I do not know, but I do know it's a reproduction of the factory setup, so it "should" work in that area
Don't be the exception.
Re: Exhaust Interference and Drone Problems [Re: MuuMuu101] #2408710
11/25/17 04:19 PM
11/25/17 04:19 PM
SoCal
SoCal
Did a quick search and it seems that some Chevelles and Mustangs came with a muffler before the axle and a resonator out back from the factory.
Re: Exhaust Interference and Drone Problems [Re: MuuMuu101] #2408728
11/25/17 05:16 PM
11/25/17 05:16 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
I can build 2.5" core resonators with 3.5" OD bodies in any length (well - as long as 40" body). As far as the dead-end tuning pipes & bullwinkle pipes, I've NEVER seen someone actually run these on any application.
Re: Exhaust Interference and Drone Problems [Re: MuuMuu101] #2408731
11/25/17 05:28 PM
11/25/17 05:28 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
So did a butt ton of Mopars
The early A body 273 hipo setup was like that
Re: Exhaust Interference and Drone Problems [Re: MuuMuu101] #2408781
11/25/17 08:06 PM
11/25/17 08:06 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
What is keeping you from fixing the rubbing? Touching exhaust can make an enormous amount of noise.
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Exhaust Interference and Drone Problems [Re: GoodysGotaCuda] #2408923
11/26/17 12:35 AM
11/26/17 12:35 AM
SoCal
SoCal
The header was rubbing against the PS box and the exhaust pipe was hitting the T-bar. Since then I got new T-bars and I haven't looked at it. I am more timid working on the front of the car than the rear. Just dealing with more weight (engine). I never feel comfortable working with it alone.
Re: Exhaust Interference and Drone Problems [Re: MuuMuu101] #2409043
11/26/17 11:22 AM
11/26/17 11:22 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
We are heading into the colder seasons of the the year.
Does your vehicle's Drone noise change with air temperature?
I have been toying with the idea that the RPM and throttle setting where drone occurs could be shifted by injecting air into the exhaust with a 12 volt compressor. Water injection might work also.
Cooler exhaust gas should have a lower speed of sound,
which should shift the conditions where the Drone is loudest.
Someone adventurous might also experiment with adding E85 to the fuel.
Re: Exhaust Interference and Drone Problems [Re: 360view] #2409092
11/26/17 01:44 PM
11/26/17 01:44 PM
SoCal
SoCal
The most recent night when I brought it home, it was about 50-60 degrees outside which is usually about 30 degrees cooler than when I normally drive it. I did not notice a change in drone tone or location. The drone almost always occurs between 1800-2100 RPM while I'm inputting some sort of throttle.
Re: Exhaust Interference and Drone Problems [Re: MuuMuu101] #2409136
11/26/17 03:16 PM
11/26/17 03:16 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
If it's rubbing it will always make a drone. Fix that first
Re: Exhaust Interference and Drone Problems [Re: MuuMuu101] #2409168
11/26/17 04:41 PM
11/26/17 04:41 PM
SoCal
SoCal
Well, then I'll need to move the engine. As mentioned at the start of this thread, the headers are hitting on the driver's side. I checked the Torsion bar interference and it seemed like the mechanic dimpled the tubing before installing the T-bar, but there is still a small amount of rub. So, my engine needs to go a little up and to the passenger side which should be accommodated by a shim
What's the safest way to shift the over to the passenger side with shims and what tools will I require? I have an engine hoist and quite a few different chains/tools for lifting the engine I bought from Summit when I got the hoist. Is it as easy as loosening up the motor mounts and installing some shims? Schumacher seems to be out, but I may have some extra scrap metal lying around. If not, would washers work? Do they go between the bracket and the rubber mount or between the K-frame and the rubber mount.
Re: Exhaust Interference and Drone Problems [Re: 360view] #2409204
11/26/17 05:54 PM
11/26/17 05:54 PM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
OMG, are you kidding me? You would go through all that to reduce or eliminate exhaust drone/resonance? CHANGE THE MUFFLERS or add resonators to the current setup! For the love of God!
Re: Exhaust Interference and Drone Problems [Re: MuuMuu101] #2409205
11/26/17 05:57 PM
11/26/17 05:57 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
Some of the cheapo parts store biscuits are quite a bit thinner than factory. And of a lower quality. Replacing them with the proper thickness may move your header away from the box. You could easily make some shims to put between the biscuits and the k member. All you need is some flat metal, a cut off wheel and a drill. Personally, I wouldn't trust the cheap rubber mounts as far as I could throw them. I prefer solid mounts as I don't mind a little vibration. There are alternatives though : http://www.dodgecharger.com/forum/index.php/topic,13216.0.html
Re: Exhaust Interference and Drone Problems [Re: MuuMuu101] #2409213
11/26/17 06:25 PM
11/26/17 06:25 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Schumacher usually shows where the engine should be located, i.e. it's factory location. I would confirm that first, then if you can move and/or shim things about till all clears. But it is not uncommon, even with TTI's to occasionally need to manually clearance the tubes (bash a dent in them). If you decide you need to go that route I'd look at how some do it with finesse, You tube video or similar.
Re: Exhaust Interference and Drone Problems [Re: Supercuda] #2409219
11/26/17 06:39 PM
11/26/17 06:39 PM
SoCal
SoCal
I'll take a look at my biscuit mounts, They're probably a little worn out as they were on the previous owner's engine. I think I have some 1/8" steel plate laying around and I have a cut off wheel and plenty of drills so that shouldn't be a problem.
I found the engine location guide per TTi's website. I'd rather not pursue the dent the header route as it has more manual labor involved, but we'll see what happens.
