Anyone here have a 440 in a A100 van?
#2407104
11/21/17 11:27 PM
11/21/17 11:27 PM
Posts: 1,652 Amarillo, Tx
old_goat
Six Abuser
Six Abuser
Amarillo, Tx
Just curious. Considering pulling the slant six and 3 speed. I sold the 84 Swb truck body. The 440 and 727 need a new home! If anyone has done this, it would be good to hear any drawbacks. I do know the cooling system has to be capable.
84 D150 440/727 79 /6 swb D150 1964 A100 window van. Just because it has spark plug tubes doesn't mean it's a Hemi.
If ya haven't been there, ya just wouldn't understand.
Re: Anyone here have a 440 in a A100 van?
[Re: old_goat]
#2407129
11/22/17 12:18 AM
11/22/17 12:18 AM
Posts: 96,664 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
Might give you ideas;
MoparRon's van
#8
frame
side view red
side view yellow
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: old_goat]
#2407379
11/22/17 02:55 PM
11/22/17 02:55 PM
Posts: 20,647 in a cattle trailer down by th...
Guitar Jones
I don't think it's possible in the stock position if you still want to drive it from the stock position. There just isn't enough room. You could set it back some and maybe get away with it.
[Re: old_goat]
#2407444
11/22/17 05:06 PM
11/22/17 05:06 PM
old_goat
Six Abuser
Six Abuser
Amarillo, Tx
I have heard of a few being done in stock position. I do know that trimming on floor/ back of doghouse is needed to clear bellhousing. I plan on doing a mustang 2 front suspension with triangulated four bar in the rear. All I can do is try. I put one mid engine in a VW bus once, similar to Mopar Ron's setup... If it needs to be mid engine, then I will just build a 408 stroker, and stay stock location.
[Re: superbee69]
#2407590
11/22/17 10:30 PM
11/22/17 10:30 PM
old_goat
Six Abuser
Six Abuser
Amarillo, Tx
How much clearance between exhaust manifolds and doghouse? Also, did you have to raise the lid, and how much if so?
[Re: Rhinodart]
#2409074
11/26/17 12:50 PM
11/26/17 12:50 PM
old_goat
Six Abuser
Six Abuser
Amarillo, Tx
Thanks! My mind is made up. Big block in the A100's future!!
