Re: DIESEL OIL IN A GAS ENGINE
[Re: Magnumguy]
#2406616
11/21/17 12:57 AM
11/21/17 12:57 AM
Posts: 96,664 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
Yup. Shell Rotela.
And it doesn't have as much zinc in it as it use to have, so might have to use Rislone ZDDP zinc additive anyway, I do.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: Magnumguy]
#2406726
11/21/17 11:35 AM
11/21/17 11:35 AM
Posts: 13,376 Marion, South Carolina [><]
an8sec70cuda
My good friend used to run it in his Camaro bracket car. Has a 436" sbc that makes about 700 hp and made a lot of passes every season running 6.0 index classes. Never had any problems with it.
[Re: Magnumguy]
#2406743
11/21/17 12:18 PM
11/21/17 12:18 PM
Posts: 15,551 Norwich CT USA
moparts
Norwich CT USA
I see the Rotela has a new look to the gallon jug again.
Has it been changed again?
Tom ,
2011 Ram 3500 C&C Diesel 2009 Challenger R/T 1971 Challenger Conv. 511/4 speed 1970 Challenger R/T 503/727
[Re: Magnumguy]
#2406787
11/21/17 01:26 PM
11/21/17 01:26 PM
Posts: 6,008 Salem
Grizzly
Moparts Proctologist
Salem
I've been using 10-30 and 15-40 diesel-spec for many years now. I can't get 5-30 diesel-spec anymore so I go back to Mobil 1 in the winter. Just ask any Truck Maintenance Person when the last time it was that they used Penzoil, Amsoil, Quaker State or any of that other "flavor-of-the-month" crap in their Cat, Cummins ISX, Volvo D13 or Detroit DD15.
Mo' Farts
Moderated by "tbagger".
[Re: DaytonaTurbo]
#2406905
11/21/17 04:56 PM
11/21/17 04:56 PM
dogdays
Answer for the OP: Yes, it's been done many many times.
At my local WalMart I see three different Shell Rotellas. You have to look at the information in the circle on the back of the bottle.
Your engine's need for the zinc compound depends nearly entirely on the acceleration of the lifter by the cam lobe and the valve spring load. If you're running stock springs and a mild Chevy lobe cam, any old oil will do. Same with hydraulic roller lifters.
If you have gone along with me to cams with very fast lifter acceleration rates and high load valve springs, the oil needs to have additional anti-wear properties which usually means more zinc dialkyldithiophosphate. 1200 to 1600 ppm seems to be the right amount. Many oil companies have this information hidden on their websites. There are other posts by people who have had lab tests done.
Motorcycle oils have sufficient amounts of ZDDP, too. I don't see a price advantage, though. I fail to see a price advantage with Diesel engine oils, either.
Additives are problematic as there is a chance of reacting with the oil's own additive package.
R.
I don't recall a majpor difference in pricing between car and truck lube oils, as long as one compares like to like. Petroleum oils, blends and full synthetics are available for both engine types.
[Re: DaytonaTurbo]
#2406941
11/21/17 06:25 PM
11/21/17 06:25 PM
Posts: 74 Stevensville, ON
Frank Raso
Stevensville, ON
Check to see if it has the SN rating on it, if it does, it's got the low zinc. Shell sells their rotella in the diesel spec CK-4 which IIRC has around 1100ppm zinc and they also make a dual rated CK-4/SN which only has the 800ppm zinc. That's not entirely correct. API SN only limits phosphorus to 600-800 ppm for energy conserving grades (ie 5W-30, 10W-30, etc). A dual-rated (API CK-4/SN) 15W-40 grade of heavy duty engine oil is limited to a maximum of 1200 ppm of phosphorus. Ford WSS-M2C171-F1 specifies a minimum phosphorus level of 1000 ppm. I've been using Petro-Canada Duron SHP 10W-30, which has both API-CK-4 and Ford WSS-M2C171-F1. Petro-Canada shows that this grade is suitable for SN because it uses the same additive package of its 15W-40 grade, which is rated CK-4/SN.
