8 1/4 rear....what HP limts #2405209
11/17/17 10:44 PM
11/17/17 10:44 PM
NEW JERSEY
dynamite Offline OP
dynamite  Offline OP
NEW JERSEY
how much power will an 8 1/4 rear take...3000 lb car with 582 HP
Re: 8 1/4 rear....what HP limts [Re: dynamite] #2405217
11/17/17 11:05 PM
11/17/17 11:05 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
582 hp is fine so long as it never gets any traction, BUT if it does then that is more than enough to destroy it.
You need at least an 8-3/4 axle with that amount of power.
Re: 8 1/4 rear....what HP limts [Re: dynamite] #2405266
11/18/17 01:15 AM
11/18/17 01:15 AM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
I destroyed an 8 1/4 with a small cam in a 318 with an auto trans in about 6 months in my 35 Dodge street rod. The 3:55 Sure Grip, 235*60*15 tires, and traction proved too much for the carrier bearing bolts. In low gear, standing start, wot, and BOOM!
The 8 1/4 came out of a 73 340 auto Duster with 55K miles on it that I converted to a dirt track car. We had an 8 3/4 set up for racing we used in the Duster. Gene
Re: 8 1/4 rear....what HP limts [Re: Neil] #2405326
11/18/17 04:16 AM
11/18/17 04:16 AM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
I agree. Unless you're slicks or similar and just driving on street tires and smoking them once in awhile you'll be fine. Currently I have one with close to 500hp and over 500tq and it's been fine for quite awhile. 3.21 gears. I've had three HP 360's with 8.25 rears and street tires with sure-grip and they held up fine for thousands of miles.
Facts are stubborn things.
Re: 8 1/4 rear....what HP limts [Re: dynamite] #2405592
11/18/17 07:35 PM
11/18/17 07:35 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
Have a 8 1/4" rear that has survived fine on the street between a somewhat stupid 340 with a 3000+stall converter and a set of hoosier quicktimes. It may have lived on borrowed time but might also have alot of life left in it.
Re: 8 1/4 rear....what HP limts [Re: dynamite] #2405626
11/18/17 08:23 PM
11/18/17 08:23 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Maybe one of those cast covers with the bolts that apply pressure to the back of the caps would make it live longer. I have a 8-1/4 with posi and 430 gears that I've been waiting on a car to put in, maybe something will turn up.
Re: 8 1/4 rear....what HP limts [Re: larrymopar360] #2405643
11/18/17 08:55 PM
11/18/17 08:55 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
I agree also. Mine is behind a 470" 4spd(500+ HP) It's a street toy running 245-60/15 BFGs. They don't stand a chance but the diff has been fine for a few years. If I don't put sticky tires on it I suspect it'll live a while. 3.73 gears with a sure-grip.
Re: 8 1/4 rear....what HP limts [Re: dynamite] #2405764
11/19/17 01:37 AM
11/19/17 01:37 AM
Illinois
StrkrDart69 Offline
StrkrDart69  Offline
Illinois
I run one in my Dart. Do not know HP but I run 11.5 on slicks, 3500 stall. No problems at all. 4.10 gears. I do have the aluminum cover with the bolts for the carrier bearing caps. 3000 lb
Re: 8 1/4 rear....what HP limts [Re: dynamite] #2405790
11/19/17 02:56 AM
11/19/17 02:56 AM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
Depends on how much maintenance you're willing to do on it. Dunno if it's still true but there used to be MANY NHRA stockers that ran the 8 1/4 because they were the lightest and those guys were able to make them live. They had a specific need to run that rear - if you do not have to run that rear, there are cheaper alternatives with less maintenance.
Re: 8 1/4 rear....what HP limts [Re: Sixpak] #2405816
11/19/17 04:45 AM
11/19/17 04:45 AM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Billet caps and longer bolts will go a long way towards making many rear ends stronger.
Re: 8 1/4 rear....what HP limts [Re: StrkrDart69] #2405893
11/19/17 01:17 PM
11/19/17 01:17 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
Do you have a source for those covers with the bolts to support the carrier caps? I did a quick search but didn't stumble across any for the 8 1/4.
Re: 8 1/4 rear....what HP limts [Re: Dcuda69] #2405982
11/19/17 04:51 PM
11/19/17 04:51 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
I found these thanks to that post thumbs
http://g2axle.com/pages/view/torque
Until i read this thread i didnt have a clue those covers where available and nice to see that they are made in the USA:D
One of those are on my to buy list now!
Re: 8 1/4 rear....what HP limts [Re: 1Fast340] #2406640
11/21/17 02:31 AM
11/21/17 02:31 AM
Illinois
StrkrDart69 Offline
StrkrDart69  Offline
Illinois
This is the cover I use. Nice quality. Highly recommend.
Re: 8 1/4 rear....what HP limts [Re: dynamite] #2406850
11/21/17 03:05 PM
11/21/17 03:05 PM
md
mopars4ever Offline
mopars4ever  Offline
md
Re: 8 1/4 rear....what HP limts [Re: mopars4ever] #2406876
11/21/17 03:45 PM
11/21/17 03:45 PM
dogdays Offline
dogdays  Offline
Dudes, the original question is so bogus! The only HORSEPOWER limit on a rear end would be the horsepower that would generate enough BTUs to cause the rear end to overheat. Example: NASCAR, where the Ford 9" they used required an oil cooler of its own. I don't know what they are doing nowadays.
What the OP should have been asking is how much TORQUE the rear end can tolerate. That's how axle manufacturers rate their axles, torque capacity.
Shock loads are also important and I think there's usually a factor for shock loads included in the calculations.
Why not use horsepower? Because an engine with rated horsepower at 5,000rpm will produce roughly 3 times the torque as an engine producing the same max hp at 15,000rpm.
R.
Re: 8 1/4 rear....what HP limts [Re: 1Fast340] #2407046
11/21/17 09:53 PM
11/21/17 09:53 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
Thanks!! I did stumble on that one....agree,love the fact it's USA made! It's now in my ebay cart. Thanks guys!!
Re: 8 1/4 rear....what HP limts [Re: dynamite] #2407101
11/21/17 11:23 PM
11/21/17 11:23 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Great, something else I've just got to spend money on!! grin
Re: 8 1/4 rear....what HP limts [Re: dogdays] #2407408
11/22/17 04:03 PM
11/22/17 04:03 PM
sweden
1Fast340 Offline
1Fast340  Offline
sweden
R.
However that 15000rpm peak hp car would probably use 3 times as much gear ratio and at that point just as much torque would be trown at the axleshafts anyway and at that point you are back to squareone again.
Re: 8 1/4 rear....what HP limts [Re: 1Fast340] #2407420
11/22/17 04:25 PM
11/22/17 04:25 PM
dogdays Offline
dogdays  Offline
You're overanalyzing my example.
My point was simply to illustrate that you cannot tell an engine's torque output, from its horsepower rating.
Anyway, we weren't talking about axle shafts. The weak point in most hypoid gear axles is the intersection between pinion and ring gear teeth.
As the torque applied increases, the force trying to push the gear teeth apart from each other increases. The gear teeth then become loaded closer to the tooth's tip which increases the moment on the tooth's attachment to the gear. Result is the tooth breaks off. The reason the Ford 9" can take so much torque is its pinion support. There is another smaller bearing surface behind the gear teeth and thus the pinion is supported on both ends, lending stability to the pinion. It's harder for the pinion to move away from the ring gear.
I saw a picture recently that showed the pinion sheared off right behind the inner bearing. While this looks at first glance to be the engine twisting the pinion shaft too hard. My theory is that it's a fatigue crack that was stated by the pinion moving away from the ring gear through whole revolutions of the pinion. The metal fatigued and eventually snapped with a brittle fracture. This is the same idea used to fatigue test metals.
R.
Re: 8 1/4 rear....what HP limts [Re: dynamite] #2407784
11/23/17 11:51 AM
11/23/17 11:51 AM
Locomotion Offline
Locomotion  Offline
If you concerned about the strength of an 8 1/4" rear, step up to an 8 3/4" because you'll be spending extra to strengthen it. Same philosophy when concerned about an 8 3/4" - move up to a Dana 60.
I know of some 8 1/4 rears that have been used in 3,600+ lb cars running mid-high 11's in the Stock class. But they spent a lot on them and at least one did eventually upgrade to a Dana 60.
Weight and gear ratio are also big factors in durability. The lower the ratio (higher numerically), the weaker the teeth because they are smaller. Between an 8 3/4" and Dana 60 - it's the gears that are the weak link in the 8 3/4. In many cases they both use 35 spline axles. Not only is the same ratio in a Dana 60 stronger, because it's bigger, but it's also more efficient because of the pinion position in relationship to the ring gear.
I would think that the ring gear would be the weak link in an 8 1/4" rear, but the caps wouldn't be far behind. Same with an 8 3/4'. I've broken some 8 3/4" ring rears over the years, but no caps (knock on wood). I am looking at a Dana 60 for peace of mind.
Even if it's built "right", it's not just how much power/torque the rear will handle, but for how long. And if you're not sure what the weak link is in the rear you choose, it can eventually show you.
