2.94-3.23 and an 833 #2405800
11/19/17 03:23 AM
11/19/17 03:23 AM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
Who runs this combo? I've got a realistic 500 crank HP motor with a 4 speed and a 219/231 roller camshaft. It should make plenty of torque. It's got a pretty standard heavy steel flywheel. Its in a 3500 lb B body.
Will it get out of its own way, and will my clutch live through first gear?
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: 2.94-3.23 and an 833 [Re: AlexP] #2405802
11/19/17 03:45 AM
11/19/17 03:45 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
3.23 was a standard axle ratio for A body 4 speed cars.
Re: 2.94-3.23 and an 833 [Re: AlexP] #2405806
11/19/17 03:58 AM
11/19/17 03:58 AM
Houston, Tx
AlexP Offline OP
AlexP  Offline OP
Houston, Tx
Didn't those have a different 1st gear?
Re: 2.94-3.23 and an 833 [Re: AlexP] #2405820
11/19/17 05:13 AM
11/19/17 05:13 AM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
There was a narrow and wide ratio 833's, reference our resident manual transmission supplier's websites for applications but I thought that the narrow ratio was for T/A cars and wide became everything else in the non-hemi versions. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: 2.94-3.23 and an 833 [Re: astjp2] #2405833
11/19/17 07:33 AM
11/19/17 07:33 AM
IN
ahy Offline
ahy  Offline
IN
I think either one of those ratios will work fine with the 4 speed and torquey engine. I run 3.23 with a close ratio 5 speed and no issues. The 2.94 would be great for road trips.
Re: 2.94-3.23 and an 833 [Re: AlexP] #2405839
11/19/17 08:34 AM
11/19/17 08:34 AM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
3.09 first.
My '84 D100 came with 3.21 and a 195-75x15.
It now has a 3.91SG with a 235-75x15 tire, overall ratio is about the same.
Re: 2.94-3.23 and an 833 [Re: B5 Bee] #2405851
11/19/17 10:41 AM
11/19/17 10:41 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
3.09 first.
Not exactly, A833OD and six cylinder A833's had a 3.09 first gear, the rest nope.
Don't be the exception.
Re: 2.94-3.23 and an 833 [Re: AlexP] #2405852
11/19/17 10:43 AM
11/19/17 10:43 AM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
My Challenger has a late 2.47 1st 833. Its running far less torque than you. A 9-1 360 with a 224@/050 hyd roller and 275/60x15 tires. It normally runs a 3.55's. Drives great, has been 12.70's. For a long trip I tried a 2.76 it really wasn't to bad.
Doug
Re: 2.94-3.23 and an 833 [Re: AlexP] #2405919
11/19/17 02:22 PM
11/19/17 02:22 PM
mt. pleasant, PA
Diplomat440 Offline
Diplomat440  Offline
mt. pleasant, PA
You won't have any problems. I ran 3.23s for years with an A833 and loved em.
Re: 2.94-3.23 and an 833 [Re: Supercuda] #2405928
11/19/17 02:45 PM
11/19/17 02:45 PM
Not exactly, A833OD and six cylinder A833's had a 3.09 first gear, the rest nope. [/quote]
Mopar used the 3.09 first gear tranny in many SB V8 in A body from day one up until the late 1960s, the last one I saw and worked on was out of a 1969 273 Baracuda shruggy
Re: 2.94-3.23 and an 833 [Re: Cab_Burge] #2405945
11/19/17 03:12 PM
11/19/17 03:12 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Mopar used the 3.09 first gear tranny in many SB V8 in A body from day one up until the late 1960s, the last one I saw and worked on was out of a 1969 273 Baracuda shruggy [/quote]
IS the OP asking about an A body?
No
The OP has a B body, pay attention
Re: 2.94-3.23 and an 833 [Re: Supercuda] #2405951
11/19/17 03:26 PM
11/19/17 03:26 PM
Pangaea
B5 Bee Offline
B5 Bee  Offline
Pangaea
3.09 first.
I need to improve my reading comprehension.
I read the question as 1st gear ratio for a 833od.
The 2.44/2.47/2.66 ratio on 833's will be fine with a 2.94 gear.
A .25 difference in 1st gear ratio or a .10 change in rear gear ratio shouldn't create excessive clutch wear. The Munchie M-22 "rock crusher" GM used only had a 2.20 1st.
A body 833 V8 up to '66 also had a 3.09 1st.
Re: 2.94-3.23 and an 833 [Re: AlexP] #2405955
11/19/17 03:37 PM
11/19/17 03:37 PM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
I believe the Green Brick used that low a gear ratio on the road course.
Re: 2.94-3.23 and an 833 [Re: AlexP] #2406216
11/20/17 03:52 AM
11/20/17 03:52 AM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
If your cam selection gives you a smooth idle and throttle response is "there", then, it don't matter what you run for gears or what the first gear ratio is. What you got there you should be able to take off in third off-idle. grin
Mo' Farts
Moderated by "tbagger".
Re: 2.94-3.23 and an 833 [Re: AlexP] #2406472
11/20/17 07:05 PM
11/20/17 07:05 PM
P
Paul_Fancsali Offline
P
Gear the hell out it what are you saving it for ?I would not even think of those gears with a stick. If fuel is a concern go overdrive. I figure its just a way to blow out the cobwebs 3.91s 4.10s 4.30 4.56all can be street driven with tall tires Lt
Re: 2.94-3.23 and an 833 [Re: Supercuda] #2406483
11/20/17 07:36 PM
11/20/17 07:36 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
in case you missed it...
