Re: 2.94-3.23 and an 833
[Re: AlexP]
#2405820
11/19/17 05:13 AM
11/19/17 05:13 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
There was a narrow and wide ratio 833's, reference our resident manual transmission supplier's websites for applications but I thought that the narrow ratio was for T/A cars and wide became everything else in the non-hemi versions. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: AlexP]
#2405839
11/19/17 08:34 AM
11/19/17 08:34 AM
Posts: 8,020 Pangaea
B5 Bee
Pangaea
Didn't those have a different 1st gear? 3.09 first. My '84 D100 came with 3.21 and a 195-75x15. It now has a 3.91SG with a 235-75x15 tire, overall ratio is about the same.
[Re: B5 Bee]
#2405851
11/19/17 10:41 AM
11/19/17 10:41 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Didn't those have a different 1st gear? 3.09 first. My '84 D100 came with 3.21 and a 195-75x15. It now has a 3.91SG with a 235-75x15 tire, overall ratio is about the same. Not exactly, A833OD and six cylinder A833's had a 3.09 first gear, the rest nope.
[Re: Supercuda]
#2405928
11/19/17 02:45 PM
11/19/17 02:45 PM
Posts: 43,303 Bend,OR USA
Cab_Burge
Not exactly, A833OD and six cylinder A833's had a 3.09 first gear, the rest nope. [/quote] Mopar used the 3.09 first gear tranny in many SB V8 in A body from day one up until the late 1960s, the last one I saw and worked on was out of a 1969 273 Baracuda ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif)
[Re: Cab_Burge]
#2405945
11/19/17 03:12 PM
11/19/17 03:12 PM
Supercuda
About to go away
About to go away
up yours
Mopar used the 3.09 first gear tranny in many SB V8 in A body from day one up until the late 1960s, the last one I saw and worked on was out of a 1969 273 Baracuda ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) [/quote] IS the OP asking about an A body? No The OP has a B body, pay attention
[Re: Supercuda]
#2405951
11/19/17 03:26 PM
11/19/17 03:26 PM
B5 Bee
Pangaea
Didn't those have a different 1st gear? 3.09 first. My '84 D100 came with 3.21 and a 195-75x15. It now has a 3.91SG with a 235-75x15 tire, overall ratio is about the same. Not exactly, A833OD and six cylinder A833's had a 3.09 first gear, the rest nope. I need to improve my reading comprehension. I read the question as 1st gear ratio for a 833od. The 2.44/2.47/2.66 ratio on 833's will be fine with a 2.94 gear. A .25 difference in 1st gear ratio or a .10 change in rear gear ratio shouldn't create excessive clutch wear. The Munchie M-22 "rock crusher" GM used only had a 2.20 1st. A body 833 V8 up to '66 also had a 3.09 1st.
[Re: Supercuda]
#2406483
11/20/17 07:36 PM
11/20/17 07:36 PM
Posts: 2,094 central texas
krautrock
central texas
in case you missed it... 3.23 was a standard axle ratio for A body 4 speed cars. Didn't those have a different 1st gear?
