Oddball inquiry #2405395
11/18/17 12:31 PM
11/18/17 12:31 PM
ohio
bbtrux Offline OP
bbtrux  Offline OP
ohio
Considering trying to make an oil transfer pump from an old big block oil pump. First question- which direction is the oil pump drive spinning this pump? Can this pump run backwards ? The pump body has two holes, a round one and a kidney bean shaped one . Which is inlet and outlet? Thanks for any responses.
Re: Oddball inquiry [Re: bbtrux] #2405526
11/18/17 05:21 PM
11/18/17 05:21 PM
Houston
I
it's Bob Offline
it's Bob  Offline
I
Houston
The inlet will be the larger of the two holes.
Re: Oddball inquiry [Re: bbtrux] #2405913
11/19/17 01:59 PM
11/19/17 01:59 PM
ohio
bbtrux Offline OP
bbtrux  Offline OP
ohio
Thanks.
