Wheel weight/caliper clearance
#2404778
11/17/17 01:36 AM
11/17/17 01:36 AM
Posts: 1,935 Grove, OK
hosehead
Grove, OK
I just put a set of new tires on four used aluminum slot wheels and when I had them mounted at the tire shop, I found that the wheel weights are hitting the calipers. I had the square, low-profile weights on. I have about 1/8" clearance between the inner wheel and the caliper clip. The only place the weights will clear is on the angled surface in between the slotted opening of the wheel and the flat surface where the weights normally go. Is this surface too far inward for the weights to be effective? Or do you guys think they would balance the wheels? Thanks in advance.
63 Plymouth savoy 65 d100 66 dart race project 58 plymouth suburban
Re: Wheel weight/caliper clearance
[Re: hosehead]
#2404837
11/17/17 03:52 AM
11/17/17 03:52 AM
hosehead
Grove, OK
The tire shop put them on the inside lip. They lasted about 10 miles until centrifugal force took over.
[Re: hosehead]
#2404914
11/17/17 12:27 PM
11/17/17 12:27 PM
RapidRobert
just thinking out loud, what about (mini) bolting them on?
