Power to Manual steering adapters, what are my options? #240421
03/01/09 09:51 PM
03/01/09 09:51 PM
Maine
itali83 Offline OP
itali83  Offline OP
Maine
I'm converting my power steering car to manual and like to know what my options for an adapter are. I know flaming river makes an adapter but for almost 200 bucks, I'd like to figure something out other than that. Has anyone found another pre made adapter, or made their own? If so how did you do it and how did it attach to the original shaft? Thanks in advance!
'68 Roadrunner Built 440/727 4:10 filled 8 3/4 in the process of a ground up restification
Re: Power to Manual steering adapters, what are my options? [Re: itali83] #240422
03/01/09 10:12 PM
03/01/09 10:12 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I bought this one from Mancini for $119. about 2 years ago. I believe it is made by Firm Feel. And it works great on my 63. Ron
Re: Power to Manual steering adapters, what are my opti [Re: itali83] #240423
03/01/09 10:17 PM
03/01/09 10:17 PM
the house on the left.
cogen80 Offline
cogen80  Offline
i like the flaming river one the best
Re: Power to Manual steering adapters, what are my opti [Re: cogen80] #240424
03/02/09 01:49 PM
03/02/09 01:49 PM
Maine
itali83 Offline OP
itali83  Offline OP
Maine
anyone else!
Re: Power to Manual steering adapters, what are my opti [Re: itali83] #240425
03/02/09 02:23 PM
03/02/09 02:23 PM
Berwyn, IL
challenger70 Offline
Berwyn, IL
Those are the only 2 I found when I was looking, I think the flaming river is a nicer looking piece and went with that.
Re: Power to Manual steering adapters, what are my options? [Re: itali83] #240426
03/02/09 02:26 PM
03/02/09 02:26 PM
United States
STLDuster Offline
STLDuster  Offline
United States
I bought one from mancini last year, along with a Mancini 20:1 Worm gear. They really didn't fit together and I actually regret buying it. It was a major pain; I wish I would have bought a Firm Feel Adapter.
"No great genius has ever existed without some touch of madness." - Aristotle
Re: Power to Manual steering adapters, what are my options? [Re: STLDuster] #240427
03/02/09 06:04 PM
03/02/09 06:04 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
From time to time they come up on eBay for around $75, and they're also available from Mopar.
Re: Power to Manual steering adapters, what are my options? [Re: topside] #240428
03/02/09 06:11 PM
03/02/09 06:11 PM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
For 200 bucks I'd be changing the column!
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: Power to Manual steering adapters, what are my options? [Re: Silver70] #240429
03/02/09 08:36 PM
03/02/09 08:36 PM
USA
max Offline
super gas
max  Offline
super gas
USA
several years ago i went the other direction from manual to power on my 70 Challenger.
my father and i took the column out and then on the bench we took the shaft out of the column and there was a couple of crash pins that we knocked out. slid the shaft up to the next set of holes and put another set of pins back in.
so in reality the stock shaft was used for both manual and power steering set ups.
Re: Power to Manual steering adapters, what are my options? [Re: max] #240430
03/02/09 08:40 PM
03/02/09 08:40 PM
Maine
itali83 Offline OP
itali83  Offline OP
Maine
You know, now that you say that, I have the column completely apart. And I see the the shaft is in two pieces and has what looks like white plastic, nylon maybe, that is holding the two halves together and I was wondering what that was for. So the column will collaps in the unfortunite event of a head on collision? So you are saying that the two halves of the steering shaft are the same, just bonded together in different places depending on the steering box? I'd like to go that route if possible and safe.
Re: Power to Manual steering adapters, what are my options? [Re: itali83] #240431
03/02/09 09:18 PM
03/02/09 09:18 PM
Glendale, AZ
69L78Nova Offline
Banned. Forever.
69L78Nova  Offline
Banned. Forever.
Glendale, AZ
Go to the junkyard and get one out of a B-van. I know theres actually one sitting down at my local u-pull-it yard
1969 Nova
454/M21/3.31
Mild mid-11 second weekend cruiser
1994 F150 XLT Super Cab 2WD
5.0/4R70W/3.55
(Daily driver)
Re: Power to Manual steering adapters, what are my options? [Re: itali83] #240432
03/02/09 09:37 PM
03/02/09 09:37 PM
USA
max Offline
super gas
max  Offline
super gas
USA
it has been a good while since we did that but i believe they were nylon and yes they are there in case of a head on collision so the shaft will collapes.
i don't know if every column is the same but i'm thinking the one in my Challenger had 2 sets of holes and we just slid the shaft to the upper set of holes and repined it.
i just don't remember right off hand what we used to repin the shaft.
Re: Power to Manual steering adapters, what are my options? [Re: max] #240433
03/02/09 11:02 PM
03/02/09 11:02 PM
Maine
itali83 Offline OP
itali83  Offline OP
Maine
Try and remember what you did because this sounds like a plan to me. I'd like to figure something out that will work the same way god forbid I get in an accident with this car the steering column will collapse like it should. Thanks again.
Re: Power to Manual steering adapters, what are my options? [Re: itali83] #240434
03/02/09 11:20 PM
03/02/09 11:20 PM
Renton, Wa.
Classof70Chally Offline
super gas
super gas
Renton, Wa.
As far as repinning the shaft goes just go to the hardware store and find the appropriate sized Nylon machine screw and nut. It will be strong enough to hold everything together but will shear when need be in an accident!
Re: Power to Manual steering adapters, what are my options? [Re: Classof70Chally] #240435
03/02/09 11:51 PM
03/02/09 11:51 PM
NE Ohio
71 FJ6 Charger Offline
NE Ohio
I just did this conversion to my 71 Charger. YOu will seperate the shafts approximatley 3.5" apart.You dont have to put any nylon screws back in at all,it should be tight enough.Remember,you had to BEAT them apart,atleast 9 times out of 10.For piece of mind,scratch it up and put some JB Weld on it,it will still collapse. If I did it again,I would extend it 3 3/4"(same length as the adaptors),if it is too long,you can beat it back in. If you are too short,you gotta take ALL back apart and do it again. 3.5" on the heavy side(meaning a tad longer)will have you safely down into the coupler. Make sure you have the coupler for the manual box,as they are different,also put your pin back in the coupler to keep the shaft from coming out,(like it's going to anyway,not!).Here is a pic,you can see by the surface rust how much I brought it out. Good luck!
'71 383HP FJ6 Charger SE
Re: Power to Manual steering adapters, what are my options? [Re: 71 FJ6 Charger] #240436
03/02/09 11:55 PM
03/02/09 11:55 PM
NE Ohio
NE Ohio
Cost me a 6 pak of Dortmunders!
Re: Power to Manual steering adapters, what are my options? [Re: itali83] #240437
03/03/09 02:49 AM
03/03/09 02:49 AM
IMGTX Offline
IMGTX  Offline
Just an FYI.
1. They are not all the same shafts. They are not supposed to be "adjustable". There is a specific upper and lower shaft for each body style. There may be some cross platform swapping but you have to have the length chart to make comarisions. Stretching or shortening a shaft at the least will reduce the ability to collapse in an accident or make it easier to misalign and bind or come apart if the shafts are not long enough.
2. They are not nylon shear pins. I though they were until I saw pictures of a shaft Julesthewiperman disassembled. They are injection points for a nylon binder that rests in a groove around the inner shaft.
That being said you can probably or shorten the shaft and never have a problem as long as you don't have a serious accident. I would be much more concerned about lengthening it if I did not know exactly how much overlap the two shafts still had.
Play at your own risk but remember there will be others in the car and in the cars around you.
I suggest the van adapter if you can find it as a cheap alternative.
Re: Power to Manual steering adapters, what are my options? [Re: IMGTX] #240438
03/03/09 03:30 AM
03/03/09 03:30 AM
NE Ohio
NE Ohio
You would end up with about half of what you start with. I see your points,but I dont see how it would'nt collapse like a manual column rod would. The manual rod is only that much longer.
I also see what you mean about the length differences model to model,I did my 70 Dart a few years back and it was of course shorter than the one in the Charger I just did.
I considered welding a piece in,but felt better going this route,20 years ago maybe... Those adaptors are just outrageous cash.Even the van ones anymore,if you find them.
Re: Power to Manual steering adapters, what are my options? [Re: 71 FJ6 Charger] #240439
03/03/09 07:45 AM
03/03/09 07:45 AM
Maine
itali83 Offline OP
itali83  Offline OP
Maine
Thanks guys, I'm defintly going to look at everything and make a decision on safety. I'm doing a ground up restoration and another 200 bucks is nothing in the big scheme of things, but if I can make it safe for less, I'm defintly going to go that route.
What is this van adapter people are talking about? I'm not familliar with this.
Thanks again!
Re: Power to Manual steering adapters, what are my options? [Re: itali83] #240440
03/03/09 09:40 AM
03/03/09 09:40 AM
I think with the van adaptor the coupler from a manual steer colum is still needed.
