Re: OK, lets talk about pinion angle again....
[Re: poorboy]
#2403379
11/14/17 02:32 AM
11/14/17 02:32 AM
RapidRobert
You want the angles to be (1) minimal (1-1.5, maybe 2) & (2) parallel but in different planes (if one is up from horizontle the other needs to be down from horizontle) (3) plus the pinion a slight bit down further from parallel cuz it will rise on accell & that depends on the app, how much it is expected to rise (not much in your app). First with the truck reasonably level side to side (which it should be, just sayin), see what the trans output shaft angle is at & post it
[Re: poorboy]
#2403382
11/14/17 02:41 AM
11/14/17 02:41 AM
Posts: 43,355 Bend,OR USA
Cab_Burge
The old Mopar chassis manual for leaf springs calls for between 3 to 7 degree difference from the drive shaft and pinion shaft with the pinion shaft pointing down towards the ground and the driveshaft pointing up towards the tranny forming a V, not a ^ or inverted V I've use that spec on a lot of drag cars as well as on my own street cars As far as tranny angles and other angles I don't worry about them nor try to use those angles in setting my pinion angle to the driveshaft angles
[Re: poorboy]
#2403716
11/14/17 09:52 PM
11/14/17 09:52 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
This link is right here on Moparts as the very first pic shows a good pic of pinion angle. Bottom line is you want the trans centerline and the diff centerline to be about the same when on the gas but on different parallel lines. So on a leaf spring car if you set the pinion say 3 degrees down in relation to the trans it will move up about the 3 degrees when on the gas to be a parallel line to the trans but not the same line. Easy way to look at is if the trans centerline is 0 then the pinion centerline should be about 3 to 4 down on a street driven car so it will move up to be about 0 when on the gas. Ron Here is the link: http://www.moparts.org/Tech/Archive/axle/8.html
[Re: poorboy]
#2403801
11/15/17 12:48 AM
11/15/17 12:48 AM
Posts: 10,670 Freeport IL USA
poorboy
Freeport IL USA
RapidRobert & Cab_Burge, I've built a few cars & trucks. The truck sits as level as my garage, and driveway cement allows, certainly real world close enough to level. The motor mounts were built with the throttle body level in forward/backward and side to side, should give me about 3 degrees trans down. Of course the angles for the pinion angle were checked with the front end up on jack stands, my fat butt doesn't fit under this thing if its not jacked up. I checked the angles with a degree finder placed on the drive shaft yoke in the trans and against the u joint mounting flange on the rear axle. The angles were position corrected. I figure the difference in the angle from a 90 degree setting should be the same, and the difference was all I was concerned about. The side to side angle is good. The trans center line and pinion center line are parallel with each other side to side, and the trans is on a higher level then the rear axle, about 2" higher with a 45" long driveshaft. When I welded the axle perches on the axle, the axle was on my bench with 2 pieces of 2" x 4" steel tube under each of the perches. I took an educated guess at the pinion angle before I welded them on because the bare frame was sitting on jack stands on my driveway. I'm really pretty happy they are as close as they are. Thank you for your input.
Moparx sorry, not much in updated pictures just one of the painted frame with the motor sitting on it. I've done a bunch of stuff to it, I probably should update the photos.
FurryStomp, that video blew me away. I knew things were moving a lot down there, I guess actually seeing it changes one's perspective.
383man, since I'm at 5 degrees pinion up, I better go with the 6 degree wedge to at least get me back to 1 degree down. It will be better then what I have now. Thanks for that video. Gene
[Re: poorboy]
#2404265
11/15/17 11:01 PM
11/15/17 11:01 PM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
6 degrees is a lot to correct with wedges. The limiting factor will be the locating pin must protrude through.
I know we all use the Performance manual as gospel. I too agree with a relatively weak leaf spring 7 nose down works pretty well on a drag car but it's way too much if smooth operation is the goal.
