INDY VS WORLD ALUMINUM BLOCKS? #2401527
11/10/17 07:25 PM
11/10/17 07:25 PM
N.W. INDIANA
moparjohn Offline OP
N.W. INDIANA
Recently there have been both Indy and world aluminum blocks for sale in the race parts section. When you consider the machining costs the price is about the same. So what I need is real recommendations on which one is better and why? I know of some good shops that work on Indy Aluminum blocks but are there good shops in the Midwest that have experience with world blocks?
Thanks! John
Re: INDY VS WORLD ALUMINUM BLOCKS? [Re: moparjohn] #2401561
11/10/17 08:21 PM
11/10/17 08:21 PM
Richmond, Tx. (Houston)
GTSDave Offline
GTSDave  Offline
I am looking for an aluminum 4.5 bore Hemi block but there is so much bad info on all of them out there it has me gun shy. So I am curious what kind of responses you get to this thread.
-Dave
PLEASE Pray for our brothers and sisters in harms way.
If you are the owner of a GTS us at the GTS Registry www.gtsregistry.com
Re: INDY VS WORLD ALUMINUM BLOCKS? [Re: GTSDave] #2401618
11/10/17 10:26 PM
11/10/17 10:26 PM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
I like the Indy block over the World. The Indy main bulkheads are much more robust. I think when World bores the casting for the sleeves they go too far down. IIRC one member here had a World iron block that was cut through in that area.
Re: INDY VS WORLD ALUMINUM BLOCKS? [Re: moparjohn] #2401622
11/10/17 10:37 PM
11/10/17 10:37 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
They have their differences. I've had 3 World blocks. One blew up worse than anything I have seen N/A. It didn't have anything to do with the block but it did. One I have have now and it has 5 rebuilds on it and has been flawless. The other is steel and not valid for this thread.
The World used to come already with bushed lifter bores, pushrod oiling, clearanced for 4.5 stroke, and outside of a little grinding for pushrod clearance is ready to go save the deck checking, mocking up, etc.
The Indy is all about upgrades and is hard to get to the lifter as there are only small holes for the oil to drain back. It may be stronger though.
That's my opinion, I've had 2 KB's too and would rather have one of those, but that's for another thread.
Re: INDY VS WORLD ALUMINUM BLOCKS? [Re: moparjohn] #2401635
11/10/17 10:56 PM
11/10/17 10:56 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
I bought my World block from a well known Hemi builder. I paid him to prep the block since I ordered the CP pistons with the block it seemed logical to me. I then paid another shop to hone the lifter bores because they were to small to even put a lifter in, another procedure I had already paid for. Also to align hone the mains, as they were out. Then check the deck height and so on. I thought I was buying a block ready to assemble and it was far from that.
The World Hemi block that I bought requires a different head gasket than what I was told. Mopar Rich got me straightened out on that after I had problems with the wrong gaskets.
Other than these issues , which I blame the original dealer for, all has been good with this block.
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: INDY VS WORLD ALUMINUM BLOCKS? [Re: Hemi Allstate] #2401641
11/10/17 11:13 PM
11/10/17 11:13 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I like the Indy better...At least they don't drill the head deck holes into the water jackets. And I will tell you what, dealing with World for customer service, at least my experience, rivals that of Indy....Maybe others had better, but that convinced me right there.
Re: INDY VS WORLD ALUMINUM BLOCKS? [Re: moparjohn] #2401660
11/10/17 11:41 PM
11/10/17 11:41 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I have World, Indy and KB block engines at our place. They all have pluses and minuses. I have not had any issues with the blocks once they are prepped properly to be used. IMO they all SUCK at customer service period!!! I have had 7 aluminum blocks over the years and have not had one yet that didn't have some issues...
IMO the Indy block does have a slightly better main support area, however they are BY FAR the thinnest in the area between the bores, like tin foil thin. KB's have the least amount of issues IF you can get one and IF it was machined properly. My current one was not done as ordered and when it was sent back to be corrected it was worse. I have not dealt with the "new company" hopefully things are better. I will be buying another new block sometime next year and IF the KB deal is sorted out will go that way.
One last tidbit currently the World aluminum block I have is the one making the most power. It is my Predator engine and so far after we changed a lot of stuff it seems fine. The current KB block is making just over 1000 and the Indy is an 850hp piece.
Re: INDY VS WORLD ALUMINUM BLOCKS? [Re: moparjohn] #2401805
11/11/17 11:23 AM
11/11/17 11:23 AM
MD
JACK1440 Offline
JACK1440  Offline
MD
My World is currently back at World for inspection. I had an oiling issue which ended up in the loss of 4 rods, 2 pistons and 2 bores on the first pass. It appears to me to be a machining error but, I could be wrong. My fingers are crossed on the customer service. Waiting to hear back. The only other issue was there was a lot of clearancing needed for the pushrods with the offset rockers. Also, be careful of the height of the lifter bore bushings. I had a learning experience with those.
Re: INDY VS WORLD ALUMINUM BLOCKS? [Re: JACK1440] #2401871
11/11/17 01:13 PM
11/11/17 01:13 PM
N.W. INDIANA
N.W. INDIANA
Thanks for all the replies from actual users of these blocks!
Here is what I have learned:
1) Both Indy and World have very poor customer service!
2) If buying one of these second hand customer service will not exist!
3) Both Indy and World need expensive machining to be ready to assemble!
4) Now I have heard of oiling problems with both which make me worried
the most!
I would like to hear and learn more!
Thanks! MJ
Re: INDY VS WORLD ALUMINUM BLOCKS? [Re: moparjohn] #2401905
11/11/17 02:14 PM
11/11/17 02:14 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
If you buy a new block, do not buy direct. Buy from one of their suppliers. Some of the Moparts members are suppliers of blocks and heads.
[image][/image]
Re: INDY VS WORLD ALUMINUM BLOCKS? [Re: moparjohn] #2401908
11/11/17 02:23 PM
11/11/17 02:23 PM
Alberta Canada
E
Edge Offline
Edge  Offline
E
Alberta Canada
I have a world aluminum block with a 572 B1 combo assembled roughly 4 years ago. Shortblock was machined and assembled at Ohio Crankshaft bought as a package. Motor was pulled apart before the long block was assembled and the short block checked out fine by my builder. For head gaskets Cometic MLS gaskets fit with out issue. Can't say how it runs as it has never been fired. Its also for sale as I decided on another direction for my car.
76 Duster work in progress
Re: INDY VS WORLD ALUMINUM BLOCKS? [Re: moparjohn] #2402007
11/11/17 05:23 PM
11/11/17 05:23 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Jack440 would be curious to hear what exactly was the oiling issue with your block if you care to share..Or what you think may have been the issue. As the one on my Predator engine had an issue as well. Which I documented here when we were screwing it together.
Re: INDY VS WORLD ALUMINUM BLOCKS? [Re: moparjohn] #2402018
11/11/17 05:59 PM
11/11/17 05:59 PM
MD
JACK1440 Offline
JACK1440  Offline
MD
Al, what is suspected is that in the front of the block at the oil pump is an auxiliary fitting to run an oil line from there to a pickup in the side of the oil pan if you wish. I used an internal pickup. What we found is that when the bore was machined for that aux port to connect with the intake side of the oil pump it broke into the distributor drive gear bore which caused air to get into the system. This was found after it heated rods number 3,4,5 & 6 but the mains were fine. It's still a lot of theory other then we do know of the intersecting bores. We're waiting on World's inspection report. I don't want to sound like I'm bashing World in any way.
Re: INDY VS WORLD ALUMINUM BLOCKS? [Re: moparjohn] #2402099
11/11/17 08:09 PM
11/11/17 08:09 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I don't have any experience with the World block but I can tell you the Indy block sucks big time. Your life will be miserable.
2011 Drag Pak Challenger
Re: INDY VS WORLD ALUMINUM BLOCKS? [Re: moparjohn] #2402127
11/11/17 08:51 PM
11/11/17 08:51 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Why are the drainbacks so small on the Indy blocks?
Re: INDY VS WORLD ALUMINUM BLOCKS? [Re: Sammy] #2402694
11/12/17 08:20 PM
11/12/17 08:20 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Nobody knows that. Why won't a starter fit on an Indy block without you doing a lot of grinding? And guess when you will find that out. Russ can't make changes because he thinks he's the smartest person in the world and his stuff can't be improved. He feels that you are a complete DA.
Re: INDY VS WORLD ALUMINUM BLOCKS? [Re: moparjohn] #2402728
11/12/17 09:30 PM
11/12/17 09:30 PM
AndyF Offline
AndyF  Offline
You might just want to take a drive up to Best Machine in the Detroit area and talk to those guys. They can answer your questions and get you set up with a block. I wouldn't even consider buying an aluminum block direct from Indy. Let someone like Best run interference for you. They deal with Indy all the time and know who to talk to and what to order. They also know how to fix the block so it will actually work.
Re: INDY VS WORLD ALUMINUM BLOCKS? [Re: AndyF] #2402751
11/12/17 10:15 PM
11/12/17 10:15 PM
sing sing
U
unknown Offline
unknown  Offline
U
sing sing
^^^^ This
Re: INDY VS WORLD ALUMINUM BLOCKS? [Re: AndyF] #2402754
11/12/17 10:18 PM
11/12/17 10:18 PM
fullmetaljacket Offline
Second that to BEST.
They have been dealing directly with Indy for some time now and like Andy said, they are aces in correcting the issues from the Mother ship and figuring out the kinks in existing motor packages using the light alloy blocks.
Chuck and Pete know the right stuff.
Re: INDY VS WORLD ALUMINUM BLOCKS? [Re: moparjohn] #2402756
11/12/17 10:24 PM
11/12/17 10:24 PM
MI, USA
moparmitch Offline
moparmitch  Offline
MI, USA
Yes, Best Machine is the first and last place you need to go...period.
