Re: 904 builds?
[Re: justinp61]
#2402794
11/12/17 11:34 PM
11/12/17 11:34 PM
Posts: 11,737 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
A good manual valve body Later wide flex band 4.2 lever 5 friction front drum assembly with coil spring conversion kit I like the blue plates Rollerized rear support A handful of the correct shims and washers to get the end plays right Late model style converter hub and pump gears not a bad idea
Couple other little things. Everybody has their own little details they like to use. Or not.
Re: 904 builds?
[Re: justinp61]
#2402843
11/13/17 12:46 AM
11/13/17 12:46 AM
Posts: 472 Minnesota, USA
humpty
Minnesota, USA
Here are the notes from my 904 Build. 200+ passes and the last pass was the best yet. I took it apart for inspection and still looked fresh.
73 904 complete 4.2 billet front band lever (Cope Racing) Cope Racing heavy duty band strut Cope Racing rear billet servo New sprag inner race, springs and rollers Cope Racing Front semi-rigid band red lining Cope Racing Low reverse band red lining Teflon pump support rings Unrestricted pump support oil feed Blocked front pump vent and relocated vent to upper tail shaft Drilled front clutch retainer for quick piston release Blocked accumulator - .002" clearance between piston and valve body Front clutch: 5 - .061" Alto Red frictions, 5 - .068" Kolene steels. Clearance = .060" Rear clutch: 4 -.061" Alto Red frictions, 5 - .068" Kolene steels. Clearance = .036" Cope Racing 4 pin Low gear front planetary 2.74 first gear, 1.54 second gear (factory steel 4 planetary from Cope Racing). Replaced thrust washer Replaced all bushings Used original rear planetary thrust washer Replaced front clutch return spring with Cope Racing multi-spring clutch retainer Total end play .013" Gear train end play .009" Front band adjustment - tighten to 70 inch pounds, back off 2 turns Rear band adjustment - tighten to 70 inch pounds, back off 2 turns Output shaft support bolts - 150 inch pounds Pump body bolt torque - 160 inch lbs Front servo pivot rod plug - 150 inch lbs Tail housing bolts - 24 foot lbs Pump to case bolts - 175 inch lbs CSR transmission shield ATI transmission pan - bolts 150 inch lbs A&A Trans Brake - bolts 70 inch lbs (per A&A) Air tested front, rear clutches, front and rear servos using 30psi air pressure
Re: 904 builds?
[Re: justinp61]
#2402948
11/13/17 11:59 AM
11/13/17 11:59 AM
Posts: 11,686 W. Kentucky
justinp61
W. Kentucky
Thanks Humpty . At 3350# with a 4.10 gear do I need a low gear set? I've been 1.40 60' with my 727 foot braking.
Re: 904 builds?
[Re: justinp61]
#2402977
11/13/17 01:14 PM
11/13/17 01:14 PM
Posts: 20,678 in a cattle trailer down by th...
Guitar Jones
Thanks Humpty . At 3350# with a 4.10 gear do I need a low gear set? I've been 1.40 60' with my 727 foot braking. If you are running a stroker small block you probably don't need the low gear set. You just need the converter to be right. My car ran virtually the same when I took the low gear out of it. When I was running the stock stroke 340 it was a help. Now having said that the newer style flat drive torque converter hub and pump should be mandatory. That slot drive hub is the weakest link in the the 904.
Re: 904 builds?
[Re: scottb]
#2403053
11/13/17 03:25 PM
11/13/17 03:25 PM
justinp61
W. Kentucky
How much line pressure are you running I've never checked it, my 727 has one of Cope's billet trans brake valve bodies in it.
