Romove bondo from aluminum #2399769
11/07/17 01:50 AM
11/07/17 01:50 AM
northwest USA
N
NANKET Offline OP
NANKET  Offline OP
N
northwest USA
Is there a product that will remove approximately 1/8" thick layer of bondo from aluminum? Can't wire wheel or sand it off, will ruin the aluminum underneath.
Paint remover, pine-sol, lacquer thinner, acetone? Thanks for any ideas.
Re: Romove bondo from aluminum [Re: NANKET] #2399771
11/07/17 01:53 AM
11/07/17 01:53 AM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
Paint stripper like Kleen Strip AR-343 will soften the filler.It may take a couple applications to completely remove then rinse with high pressure water.
Re: Romove bondo from aluminum [Re: NANKET] #2399896
11/07/17 12:16 PM
11/07/17 12:16 PM
Hamburg - Germany
SuperRob Offline
SuperRob  Offline
Hamburg - Germany
Heat gun.
Re: Romove bondo from aluminum [Re: NANKET] #2399915
11/07/17 01:15 PM
11/07/17 01:15 PM
Alberta
rustbuckett68 Offline
Alberta
Lacquer thinner softens 'bondo' so that would be my choice. If you can puddle the thinner, great. If not, spread a paper towel over the mud and keep damp. After a bit, scrape with a plastic spreader so you don't gouge the soft aluminum. I use a small spray bottle with thinner, very handy. Heat might warp the aluminum.
Re: Romove bondo from aluminum [Re: RTSrunner] #2400102
11/07/17 07:19 PM
11/07/17 07:19 PM
crlush Offline
crlush  Offline
iagree
Re: Romove bondo from aluminum [Re: crlush] #2400209
11/07/17 10:19 PM
11/07/17 10:19 PM
IN
ahy Offline
ahy  Offline
IN
Agree paint stripper will soften it. Aircraft stripper is my choice though I am sure others will work. Apply a heavy coat and cover with plastic to keep it wet. After a few hours, scrape off what you can and repeat if needed.
Re: Romove bondo from aluminum [Re: NANKET] #2400324
11/08/17 02:38 AM
11/08/17 02:38 AM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
If there's a layer of bondo on the aluminum part chances are it's been sanded for adhesion already so carefully sanding it off won't do any harm...
