Any issues running flat tappet in a tubed smallblock #2399173
11/06/17 02:26 AM
11/06/17 02:26 AM
Portage,michigan
B3422W5 Online content OP
B3422W5  Online Content OP
Portage,michigan
Looking at a tubed for roller cam block. Can i run my flat tappet cam without issues?
Its a 340 block.
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Any issues running flat tappet in a tubed smallblock [Re: B3422W5] #2399178
11/06/17 02:53 AM
11/06/17 02:53 AM
Washington
madscientist Offline
Washington
Its a 340 block.
I do it all the time.
Re: Any issues running flat tappet in a tubed smallblock [Re: madscientist] #2399310
11/06/17 01:10 PM
11/06/17 01:10 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Absolutely but if it is one that has just been done and never run do yourself a favor and double check their work. Make sure that all the holes that need redrilled have been redrilled. I’ve seen guys mess up doing this job.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Any issues running flat tappet in a tubed smallblock [Re: pittsburghracer] #2399315
11/06/17 01:19 PM
11/06/17 01:19 PM
Pittsburgh I gotta do one. Do you have any tips/caveats (for drilling the main holes out to 5/8), I wanna em straight & not mess up a block.
Re: Any issues running flat tappet in a tubed smallblock [Re: pittsburghracer] #2399318
11/06/17 01:23 PM
11/06/17 01:23 PM
Portage,michigan
Portage,michigan
Thanks John
Yes its already been done by a reputable shop and been run with a roller previously since done
1.41 best 60 foot
6.56 at 104.17
Re: Any issues running flat tappet in a tubed smallblock [Re: B3422W5] #2399395
11/06/17 03:19 PM
11/06/17 03:19 PM
in the middle
dodger mope Offline
dodger mope  Offline
in the middle
when the block is reamed like the factory tool the reamer it can drift to one side. i drilled a hole in lead end of the reamer and press in a pilot cone with 3 cutouts for chip relief.when the tool goes straight it cuts fast
Re: Any issues running flat tappet in a tubed smallblock [Re: dodger mope] #2399416
11/06/17 03:58 PM
11/06/17 03:58 PM
Washington
Washington
That's a good idea. Since I have a tool post grinder I just turned down the end of my reamer to hole size.
Either way will work but I agree, it needs some sort of pilot or you have to be very careful to get it straight.
And don't forget what PBR says...make sure all the holes are drilled to size and make sure the tube isn't keeping the lifter from turning.
Re: Any issues running flat tappet in a tubed smallblock [Re: B3422W5] #2399429
11/06/17 04:17 PM
11/06/17 04:17 PM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
If the block is tubed why not run a roller cam its going to make more power then the flat tappet
Re: Any issues running flat tappet in a tubed smallblock [Re: scottb] #2399433
11/06/17 04:41 PM
11/06/17 04:41 PM
Portage,michigan
Portage,michigan
Just talked to Dwayne, problem is finding springs to fit the rockers. Must be 1.500 OD.
Looked around for springs. Howards makes one, but not enough pressure to run anything worth swapping to that would make enough power to pay for springs, pushrods, roller lifters, etc. over my flat tappet. Plenty in 1.550, but those would rub.
1.41 best 60 foot
6.56 at 104.17
Re: Any issues running flat tappet in a tubed smallblock [Re: RapidRobert] #2399628
11/06/17 10:02 PM
11/06/17 10:02 PM
PA.
"Little"John
"Little"John
PA.
No special tricks for me. I actually just bought a new long drill bit from Amazon because I used my old bit for 4 different block and various other jobs. I slowly hand drill around 10 inches deep from the front and rear of the block using lots of cutting fluid. Then I use 2 pieces of soft 1/2 house copper pipe driven in from the front and back. I still have the tool to drive into the lifter holes to dent the copper pipe for lifter clearance. I get out my old direct connection books for a refresher evertime I do a block and will never do another block without tubing it after seeing how much oil comes out of unbushed or untubed lifter bores. I want that oil going to my bearings. If you don’t have the tool to clearance the lifter bores round off an old solid lifter to do the job.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
