Page 2 of 3 1 2 3
Re: No oil pressure after changing rockers [Re: Kam*Kuda] #2397080
11/01/17 11:41 PM
11/01/17 11:41 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
Originally Posted By Kam*Kuda
I had originally primed the engine with the drill in forward FYI
I changed the oil and filter
I took off the oil pump to check if the pressure release was stuck, but it slid back and forth easily
Forward rotation on a drill is clockwise. Wrong direction for a big block.
Re: No oil pressure after changing rockers [Re: Kam*Kuda] #2397108
11/02/17 12:44 AM
11/02/17 12:44 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I think your main problem is that big round thing hanging off the front of your engine. Send it to me , I'll pay the postage. LOL Other than that, you had oil at both rockers, did you re-fill the new filter with oil? you do have oil in the crank case right? I would look at the oil pump gasket sucking air. Try priming again .
Re: No oil pressure after changing rockers [Re: rowin4] #2397123
11/02/17 01:21 AM
11/02/17 01:21 AM
FYI to line up the passages for the heads to oil (big block), turn the dampener to TDC #6 firing & preoil one bank then back up CCW the dampener 3/4 turn (to #8 TDC firing) & preoil again for the other bank. Cut a strip of paper 17.082" to use as a ruler on your dampener if needed to go from #6 back to #8.
Re: No oil pressure after changing rockers [Re: RapidRobert] #2398343
11/04/17 11:38 AM
11/04/17 11:38 AM
Fredericksburg Va
P
plycuda Offline
plycuda  Offline
P
Fredericksburg Va
did you ever figure it out
Re: No oil pressure after changing rockers [Re: Kam*Kuda] #2399133
11/06/17 12:20 AM
11/06/17 12:20 AM
Canada
Kam*Kuda Offline OP
Kam*Kuda  Offline OP
Canada
OK back at it today
I had lots of oil coming out the shafts and then with the plug back in, thru the rockers. But I still can hold the drill with one hand, not feeling like much pressure. I didnt start it to check, (electric gauge and cant see it and rill at the same time)
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Re: No oil pressure after changing rockers [Re: Kam*Kuda] #2399134
11/06/17 12:24 AM
11/06/17 12:24 AM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
If you can hold the drill with one hand you dont have much oil at or in the pump. you are 100% turning it anticlockwise ??
1963 Plymouth Max Wedge
1971 Barracuda
Re: No oil pressure after changing rockers [Re: ozymaxwedge] #2399138
11/06/17 12:34 AM
11/06/17 12:34 AM
Canada
Kam*Kuda Offline OP
Kam*Kuda  Offline OP
Canada
Yes I double check each time I try and prime it, But I assume it wouldnt come out the rockers shafts if I had it in forward, Is that Right?
1654.5 Mustang
1955 Land Rover
Re: No oil pressure after changing rockers [Re: B G Racing] #2399141
11/06/17 12:37 AM
11/06/17 12:37 AM
Canada
Kam*Kuda Offline OP
Kam*Kuda  Offline OP
Canada
Originally Posted By B G Racing
.How much oil pressure did you have to begin with before the swap?
IIRC 70 lbs
1654.5 Mustang
1955 Land Rover
Re: No oil pressure after changing rockers [Re: Kam*Kuda] #2399144
11/06/17 12:43 AM
11/06/17 12:43 AM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
Correct, but if it is coming out of the shafts the drill should be trying to break your wrist, something strange here.
1971 Barracuda
Re: No oil pressure after changing rockers [Re: Kam*Kuda] #2405439
11/18/17 02:13 PM
11/18/17 02:13 PM
Ohio
lockjaw-express Offline
Ohio
Any word on what fixed your oiling problem?
Re: No oil pressure after changing rockers [Re: Kam*Kuda] #2405642
11/18/17 08:53 PM
11/18/17 08:53 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
OK back at it today
Your nuts are on upside down. The first picture looks like no plug in the end of the shaft
Re: No oil pressure after changing rockers [Re: Kam*Kuda] #2405663
11/18/17 09:47 PM
11/18/17 09:47 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
do you use a swinging pick-up or static in the pan?
Re: No oil pressure after changing rockers [Re: Kam*Kuda] #2405807
11/19/17 04:04 AM
11/19/17 04:04 AM
Chicago Blackhawks
hemicar1971 Offline
hemicar1971  Offline
Chicago Blackhawks
You could of called a few locals to come over and sit in the car and watch the oil pressure gauge even if it is not a Mechanical gauge. I have run some what of the same set up years and years ago. I restricted the oil to the heads because of it being roller everything. What oil pump are you running, there is always an improvement there that can be done. What oil are you running. If this is just a rocker change go back and read B.G.Racing post. If you have not solved your problem by the time your read this post, there are plenty of locals that can come and give you a hand within a hour of were you live.
1971 HEMI E BODY REGISTRY
Re: No oil pressure after changing rockers [Re: Kam*Kuda] #2405873
11/19/17 11:57 AM
11/19/17 11:57 AM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
Stupid question but are you sure the oil holes in the shaft are pointed up?
Re: No oil pressure after changing rockers [Re: camastomcat] #2405912
11/19/17 01:58 PM
11/19/17 01:58 PM
I didn't read all the posts (yet) but you could get a mech gauge & some cheap plumbing fittings & plumb the gauge into the oil psi sender 1/8 NPT port so you can see it while priming. As said with pressure you will feel it on the drill even with light oil.
Re: No oil pressure after changing rockers [Re: Kam*Kuda] #2405956
11/19/17 03:38 PM
11/19/17 03:38 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
If there is oil running out the ends of the shafts and no plugs were installed that would be the issue."big holes"
Re: No oil pressure after changing rockers [Re: Kam*Kuda] #2405991
11/19/17 05:15 PM
11/19/17 05:15 PM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
I think he had the plugs both in and out and yes, if the plugs on the shaft are not in the shafts, there's the open.
Re: No oil pressure after changing rockers [Re: Kam*Kuda] #2405994
11/19/17 05:28 PM
11/19/17 05:28 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I had lots of oil coming out the shafts and then with the plug back in,thru the rockers.
Re: No oil pressure after changing rockers [Re: camastomcat] #2406169
11/20/17 01:07 AM
11/20/17 01:07 AM
rowin4 Offline
rowin4  Offline
This question was answered on the first page. A question to you, Why would you want the shaft holes up?
Re: No oil pressure after changing rockers [Re: rowin4] #2406172
11/20/17 01:24 AM
11/20/17 01:24 AM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
I thought that's the way I remember them going, it's been a while.
Page 2 of 3 1 2 3
