Re: LSD for Autocross? [Re: CJD AUTOMOTIVE] #2390748
10/21/17 11:49 AM
10/21/17 11:49 AM
New Mexico
Adobedude Offline
Adobedude  Offline
New Mexico
Originally Posted By CJD AUTOMOTIVE
The Detroit Locker is going to be the best, providing you change the springs to accommodate what your doing and for the type of tires (slicks or treaded). For treaded tires, a #48 spring is what you'll want. Yes, it is a little noisy, but the abrupt lock and unlock is usually do to the unit having too high a spring rate, and once setup with the correct springs, you'll have a hard time finding a unit that can put the power down better with more predictability.
http://shop.ronsuttonracetechnology.com/shopping/?k=detroit%20locker%20springs
I ordered the 110# springs to keep my locker from unlocking...Will put them in the winter
2001 Dodge Dakota
408 All Motor
11.27 @ 117.83 mph
2017 NM Mopar Challenge Series Champion.
Re: LSD for Autocross? [Re: myduster360] #2399094
11/05/17 10:32 PM
11/05/17 10:32 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
Originally Posted By myduster360
I'm definitely considering a helical diff like the Eaton TrueTrac, Quaife, Torsen,ect.
The fact that they always transmit torque to the wheel with the MOST traction(instead of the least) is what sets that design apart. Seems it would work great for corner exit.
We are all traditionalist here and I personally still prefer the Power lock for street and strip drag racing but if you are going autocrossing a helical differential is the only way to go.
Re: LSD for Autocross? [Re: Bob J] #2399108
11/05/17 11:07 PM
11/05/17 11:07 PM
So Cal
autoxcuda Online content
autoxcuda  Online Content
So Cal
At SEMA Richmond said they were comin out with a Torsten style mopar 8.75 setup and to check with Dr Diff.
Re: LSD for Autocross? [Re: autoxcuda] #2399111
11/05/17 11:22 PM
11/05/17 11:22 PM
IN
ahy Offline
ahy  Offline
IN
The helical style is better in theory... but the 8.75 versions have had quality problems. Why I suggested the clutch type (which I run).
Re: LSD for Autocross? [Re: autoxcuda] #2399166
11/06/17 02:01 AM
11/06/17 02:01 AM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
That will be cool.
