Seat Brackets - How Strong? #2398596
11/04/17 10:33 PM
11/04/17 10:33 PM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
So I am making aluminum brackets (3/8 inch thick) for my street/strip 69 GTX Corbeau seats. The Corbeau supplied steel sliders will bolt to the aluminum bracket - the sliders then bolt to the seats with 7/16" bolts.
How strong do the brackets need to be? Can I lighten them by drilling similar to what I have laid out or should I save weight elsewhere?
Re: Seat Brackets - How Strong? [Re: markz528] #2398790
11/05/17 12:14 PM
11/05/17 12:14 PM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
No opinions?
Re: Seat Brackets - How Strong? [Re: markz528] #2398811
11/05/17 12:47 PM
11/05/17 12:47 PM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
Looks plenty strong to me, I wouldn't have a problem with lightening them up a bit.
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: Seat Brackets - How Strong? [Re: markz528] #2398813
11/05/17 12:48 PM
11/05/17 12:48 PM
East Coast
A/MP Offline
A/MP  Offline
East Coast
I'd say the sliders might be the weak link. Seen may an accident and that racket action fails on a hard impact. Check that 7/16" bolt is grade 8. Your aluminum bracket is lighter that the comparable steel one. I'd leave it intact with no lightening holes.I'd also use grade 8 bolts for the bracket and floor with grade 8 washers, lock washers and nuts securing to the floor.
Re: Seat Brackets - How Strong? [Re: A/MP] #2398824
11/05/17 01:04 PM
11/05/17 01:04 PM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
You make good points. The car is built to go 10.0 but for now am targeting 10.50's. The car has a full roll cage (so has the support behind the seat that certainly helps keep things in place in the event of an incident) and also has a submarine belt which also helps.
Re: Seat Brackets - How Strong? [Re: markz528] #2399007
11/05/17 06:21 PM
11/05/17 06:21 PM
SE Washington
Forest Offline
Forest  Offline
SE Washington
I would feel comfortable lightening it up some, but maybe not quite as many holes as you have drawn...
Re: Seat Brackets - How Strong? [Re: markz528] #2399162
11/06/17 12:49 AM
11/06/17 12:49 AM
Topeka Kansas
K
ksj Offline
ksj  Offline
K
Topeka Kansas
How much of a weight reduction will that be?
Re: Seat Brackets - How Strong? [Re: markz528] #2399199
11/06/17 03:22 AM
11/06/17 03:22 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
I think your seat belts are more important than the seat itself. The seat itself weighs what? 25-35 pounds? I don't know how much they really want to move with a 200 lb. guy strapped in them and the 200 lb. guy strapped to the floor and roll cage. I don't know how much weight your layout there would save and probably isn't worth your time.
Re: Seat Brackets - How Strong? [Re: markz528] #2399326
11/06/17 12:36 PM
11/06/17 12:36 PM
AndyF Offline
AndyF  Offline
I built a set of seat brackets from SST and then decided they were too heavy so I switched to aluminum. These are 10 ga aluminum bent to fit my seat. I went ahead and put a truss design in them to take a little more weight out.
Re: Seat Brackets - How Strong? [Re: markz528] #2399410
11/06/17 02:45 PM
11/06/17 02:45 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Would you hang 1000 pounds off the seat?
It don't take a real bad crash to see the G forces go way up
Re: Seat Brackets - How Strong? [Re: FastmOp] #2399449
11/06/17 04:14 PM
11/06/17 04:14 PM
Lowes
steve660 Offline
steve660  Offline
Lowes
I remenber Monte talking about seat mounts.
Heres what he said.
The seat mounts DO NOT hold the seat in the car. For Christ sakes, Pro-Mods and similar have the damn seats held in with dzus fasteners. You think those keep the seat in the car in the event of a crash? The BELTS hold you AND the seat in the car. If your belts let you and the seat move around a lot in the event of a crash......either the belts are not mounted correctly OR you did not have them tight enough
PSO headed 632 from MM. Cracked cylinder, loose valve seats, low oil pressure, low cylinder pressure.
..... Now its a door stop....
Re: Seat Brackets - How Strong? [Re: FastmOp] #2399453
11/06/17 04:22 PM
11/06/17 04:22 PM
dogdays Offline
dogdays  Offline
It's a 1/2 lb savings. That's assuming 13, 1" holes in 3/8 aluminum.
Think of this: There are four 7/16" bolts holding the seat down. I'm sure they didn't get there because some engineer was too lazy to change the drawing.
I would not risk my life or health for a 1/2 lb weight savings. Your mileage may vary.
R.
