Re: Tips Tuning Stroker- UPDATE
[Re: 65Fury440]
#2456693
02/24/18 03:02 PM
02/24/18 03:02 PM
Posts: 571 Spring Hill Fl
65Fury440
Spring Hill Fl
Just to review- My 526 has ported TF and 337 intake, 260/266 @ 50 cam, 2" headers through a 3" exhaust.I have 3.54s and a 4 speed.
My first time out at 4200 lbs and 28" tires it was almost dead hooking, and bogging the engine. My 60 was 1.79 and 11.71.
Since talking to some guys on here I did the following
Advanced the 108 ICL cam, it's now in at 101.
Opened the lash to .020
Went to FBO box
Installed jet extensions
Installed a fuel pressure gauge- it was losing fuel pressure, top of 3rd gear was almost 1 psi, even though it didn't seems to nose over
Got some 26" bias ply slicks, huge improvement in SLR and grip
Went to a Carter hemi type FP, it works good when it works, which is about half the time, it just loses pressure off idle or driving normal.
I ordered a FG hood with a Hemi scoop from Sled city, not sure when it will be done, but that will cut about 100 lbs. I would like to try a carb spacer
One thing I noticed, the low end improved dramatically with the cam advance.
I used a larger wheel than originally, the cam was actually installed at 105. I was hesitant to go another 4, but boy was it a good move.
My cranking compression jumped from 175 to 185, engine used to buck at low throttle just cruising around anything under 2000, now 1800 is no problem.
Full throttle it still pulls hard to 7k.
The time slips will tell, but there will be improvement, it pulls harder than before.
Thank you all you guys for your help. Every bit of advise given made the car just a little bit faster.
[Re: 65Fury440]
#2456799
02/24/18 05:44 PM
02/24/18 05:44 PM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
If you are running with the exhaust hooked up, it might be strangling the motor. I would get a pair of 18 inch extensions for the headers and try running open exhaust. The extensions alone on an open pair of headers were worth a tenth plus on a couple of my cars.
[Re: gregsdart]
#2456916
02/24/18 08:25 PM
02/24/18 08:25 PM
65Fury440
Spring Hill Fl
If you are running with the exhaust hooked up, it might be strangling the motor. I would get a pair of 18 inch extensions for the headers and try running open exhaust. The extensions alone on an open pair of headers were worth a tenth plus on a couple of my cars. I might try opening up the headers. My wide band is back about 18 inches in the exhaust so I was wanting to see what the AFR was, but I'm happy with that. It was annoying not to hear your own car, when the guy in the next lane is running open, which is most everybody.
[Re: 65Fury440]
#2457004
02/24/18 11:07 PM
02/24/18 11:07 PM
Posts: 1,096 Australia
ozymaxwedge
Australia
YES 4.1 gears and a Dominator carb
1963 Plymouth Max Wedge 1971 Barracuda
[Re: 65Fury440]
#2457050
02/25/18 12:03 AM
02/25/18 12:03 AM
Posts: 8,779 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
Very interesting thread. I'm going to have to watch this one. I have less cubes, less weight, less cam, but a 4-speed and a 3.54 gear. I was going to put a 30" tall tire on it, but this is making me think twice. Unless I go to a 4.10 or a 4.30. I think I can live with the RPM at 75 MPH with either gear and the tall tire. Good luck. I hope you can hit your goal. If you have one.
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
[Re: 65Fury440]
#2457133
02/25/18 03:04 AM
02/25/18 03:04 AM
Posts: 10,218 Someplace you aren't
SomeCarGuy
Seems like guys are all the time finding out a gear change doesn’t do a thing. Small changes in et that could even be weather related. Same thing with cross overs in the exhaust or lack thereof.
I want my fair share
