Drop base air cleaners for tunnel ram #2397095
11/02/17 12:03 AM
11/02/17 12:03 AM
Madison Wi
NTOLERANCE Offline OP
Madison Wi
On my 65 coronet I'm trying to locate some shorter drop base air cleaners
I haven't found any that are smaller than 14".
Trying to get the holleys under the 5" tall A990 scoop
Anyone using anything drop base about 9" diameter!(or smaller ) and shorter ? I need about 1.5" shorter than the triangle edelbrock foam filters
Re: Drop base air cleaners for tunnel ram [Re: NTOLERANCE] #2397134
11/02/17 01:39 AM
11/02/17 01:39 AM
Alberta, Canada
STR-14 Offline
STR-14  Offline
Alberta, Canada
I had this fellow build me one for a special application. Excellent quality and very fair pricing.
http://www.universalspinners.com/
Re: Drop base air cleaners for tunnel ram [Re: NTOLERANCE] #2397176
11/02/17 05:30 AM
11/02/17 05:30 AM
Australia
O
ozymaxwedge Offline
ozymaxwedge  Offline
O
Australia
Dont think a 9" filter will fit over a 4150 holley, think maybe smallest drop base would be 11" diam . On tunnel ram set up ? 9" is the largest dia you can go before they touch.
Custom made twin hole oval drop might be your answer.
1963 Plymouth Max Wedge
1971 Barracuda
