Re: Wire/Groove Around Combustions Chamber on Heads - Why? [Re: Cab_Burge] #2399313
11/06/17 01:16 PM
11/06/17 01:16 PM
Originally Posted By Cab_Burge
I did coat them with three light coats of Copper Coat up
I forgot about that blush
(1) Thanks Cab, when the time comes I will do exactly that (2) early onset Alzheimers (We'll take care of ya).
Re: Wire/Groove Around Combustions Chamber on Heads - Why? [Re: Jeremiah] #2399366
11/06/17 02:28 PM
11/06/17 02:28 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
I normally cut the grove for the ring in the block, and only cut a receiver groove in the head for lots of nitrous or boost. Its a lot harder to cut grooves and o-ring the head, but the purpose is the same. I have the old Isky tool to cut the blocks. Got to have an end mill to do the heads. Biggest mistake I see is not getting the o-ring the proper depth. Most that have water leaks have the o-ring to tall out of the block, holding the gasket off the water passages. http://scegaskets.com/wp_super_faq/titan-pro-gasket-installation/
SCE website give proper procedure. And use motoseal type silicone sealer around the water ports. Its designed for motorcycle cases met to metal sealing, its a thin silicone, you put it on with a brush. And a coat of copper coat on the gasket.
Re: Wire/Groove Around Combustions Chamber on Heads - Why? [Re: Jeremiah] #2399566
11/06/17 08:12 PM
11/06/17 08:12 PM
In The Hills
jughed Offline
jughed  Offline
In The Hills
540, 13.5 compression, O-Ringed block, no grooves in 440-1s, SCE copper gaskets, Hylomar sealer around the water ports. Never have had any leakage problems
End those annoying Infolink ads with AdBlockPlus
https://adblockplus.org/
