Re: Real world weight loss program and it` cost..........
[Re: Thumperdart]
#2394938
10/29/17 05:18 PM
10/29/17 05:18 PM
Posts: 12,592 Great Neck,LI,new york
hemi-itis
Spoke about this with my crew chief,a gear change would put me in a happy spot for a cheap church mouse,,,LOL.I don't want to change anything just yet as that 8 second slip will come with just a few more lbs! ![whistling whistling](/ubbthreads/images/graemlins/custom/whistling.gif) I'm at a whoppin 6 lbs at 6% OD. ![work work](/ubbthreads/images/graemlins/custom/work.gif)
[Re: Thumperdart]
#2394949
10/29/17 05:56 PM
10/29/17 05:56 PM
Posts: 1,896 Spahn Ranch
RMCHRGR
Spahn Ranch
You love to do things the hard way. Costs money to go fast, as you know. What we are saying is that do it right and it will be consistent. Think about it - you had that converter with the old combo, AFAIK. Now the combo is totally different, do you expect the converter to behave the same? Converter should always match the combo. It's gotta be an uphill battle trying to tune a motor that is fighting itself. I'll bet your data curves will look completely different with the right converter. Look at the pics you posted in your other thread - top left, the first two data inputs - engine speed vs. driveshaft speed, maybe kinda important ones? The first pic on the 9.79 pass shows a ratio of .52%!! According to your readout there, the DS was spinning at over 13K RPM. Thank Marty for doing a good job balancing that thing. ![](https://board.moparts.org/ubbthreads/ubbthreads.php/ubb/download/Number/302980/filename/10.22.17%20104.jpg) Now look at the 2nd pic, the ratio is more than 20% higher and see how much it picked up. Imagine if it was up in the 90% range...might not be possible to get it working that efficiently but you get the idea. ![](https://board.moparts.org/ubbthreads/ubbthreads.php/ubb/download/Number/302981/filename/10.22.17%20108.jpg) Don't mean to talk out of school here, just trying to point out that the blower does not overcome all maladies.
'71 Duster '72 Challenger '17 Ram 1500
[Re: fullmetaljacket]
#2395025
10/29/17 08:40 PM
10/29/17 08:40 PM
hemi-itis
If you breach the 8 mark you might acquire a new alias for your self to be called 8Ball. 8Ball in the corner pocket. I will wear it like a badge of honor.Looking forward to the new licence plate bracket as well. Just might have that air brushed on the rear panel,,,,
#2395079
10/29/17 10:26 PM
10/29/17 10:26 PM
Posts: 1,853 South Bend
John Brown
South Bend
I wannna know why driveshaft rpm would show higher than engine rpm. Something is sorta out of whack there.
#2395129
10/30/17 12:04 AM
10/30/17 12:04 AM
hemi-itis
That there is a super cool character logo. I can arrange a small color painting on the deck lid for you once you get there. Perhaps at that time, you can lease me some ET on a monthly basis.LOL.
License plate bracket? I would keep it al hush hushhhh and have a pool stick chalk at hand to hit it in the corner.
Itis, you ever heard of the two 64' SF/X supercharged Chargers? Basically, two 330 Coronets called Chargers. Spoke with Bud Fauble at length about them.After his 1st nitro explosion,he told them he would NEVER drive anything on nitro again!! Bud was a very cool dude and light on his feet! RIP BUD,,,
[Re: Thumperdart]
#2395248
10/30/17 10:35 AM
10/30/17 10:35 AM
RMCHRGR
Spahn Ranch
I should engage my brain before posting next time. If the converter was slipping DS speed would be lower than engine speed. Burnout is probably correct or tire spin somewhere during the run. Ask Al how much the tires moved on the rims by the end of the day.
Might be good to know at what points the data was taken from though since both screen shots show the DS speed higher than engine speed.
Sorry for the misinformation and for getting off track.
[Re: Thumperdart]
#2395488
10/30/17 04:50 PM
10/30/17 04:50 PM
hemi-itis
Screenshot was at the stripe.I never programmed the DS sensor,still tryin to figure it out.As far as the tire movement,I will try DVWs rec with the permatex.If that fails I will switch the street tires with the slicks so the beadlocks are with the slicks. PF is set at 7,will drop to 6 in high gear.
[Re: RMCHRGR]
#2395493
10/30/17 04:59 PM
10/30/17 04:59 PM
hemi-itis
You love to do things the hard way. Costs money to go fast, as you know. What we are saying is that do it right and it will be consistent. Think about it - you had that converter with the old combo, AFAIK. Now the combo is totally different, do you expect the converter to behave the same? Converter should always match the combo. It's gotta be an uphill battle trying to tune a motor that is fighting itself. I'll bet your data curves will look completely different with the right converter. Look at the pics you posted in your other thread - top left, the first two data inputs - engine speed vs. driveshaft speed, maybe kinda important ones? The first pic on the 9.79 pass shows a ratio of .52%!! According to your readout there, the DS was spinning at over 13K RPM. Thank Marty for doing a good job balancing that thing. ![](https://board.moparts.org/ubbthreads/ubbthreads.php/ubb/download/Number/302980/filename/10.22.17%20104.jpg) Now look at the 2nd pic, the ratio is more than 20% higher and see how much it picked up. Imagine if it was up in the 90% range...might not be possible to get it working that efficiently but you get the idea. ![](https://board.moparts.org/ubbthreads/ubbthreads.php/ubb/download/Number/302981/filename/10.22.17%20108.jpg) Don't mean to talk out of school here, just trying to point out that the blower does not overcome all maladies. I will get the DS sensor programmed before my next outing.Then we can talk about the tight street converter ![work work](/ubbthreads/images/graemlins/custom/work.gif)
[Re: hemi-itis]
#2395521
10/30/17 05:50 PM
10/30/17 05:50 PM
Thumperdart
State of confusion
Screenshot was at the stripe.I never programmed the DS sensor,still tryin to figure it out.As far as the tire movement,I will try DVWs rec with the permatex.If that fails I will switch the street tires with the slicks so the beadlocks are with the slicks. PF is set at 7,will drop to 6 in high gear. Unless I missed something, why are you NOT screwing the tires to the rims...........
[Re: hemi-itis]
#2395803
10/31/17 12:42 AM
10/31/17 12:42 AM
Posts: 2,363 Cotati, CA
Dave Hall
Cotati, CA
PF is set at 7,will drop to 6 in high gear. If you mean fuel pressure, the data shows 3. something.
#2395848
10/31/17 02:14 AM
10/31/17 02:14 AM
hemi-itis
Itis. Is the first graph in the burnout box and the second graph through the stripe after shifting into neutral? That is low fuel Pressure. That was at the stripe,last pass om pump gas.That was at the stripe when I was on the binders it went 1,2,1,2 ![eek eek](/ubbthreads/images/graemlins/custom/eek.gif) After I turned around on the return it came back enough to get back to the pit.I was outta fuel...... The other screen shot It went from 7 to 6.5.
[Re: Thumperdart]
#2396013
10/31/17 01:07 PM
10/31/17 01:07 PM
hemi-itis
Screenshot was at the stripe.I never programmed the DS sensor,still tryin to figure it out.As far as the tire movement,I will try DVWs rec with the permatex.If that fails I will switch the street tires with the slicks so the beadlocks are with the slicks. PF is set at 7,will drop to 6 in high gear. Unless I missed something, why are you NOT screwing the tires to the rims........... Dom,I have several friends that are faster than me that don't screw the rims.DVW is a perfect example.Over the winter I will break these slicks down and clean them to re=do with the permatex Doug said to use.If I still have an issue then I will switch the rear rims around.
