Re: Aerospace vacuum pump kit. Rebuild pump
[Re: Cab_Burge]
#2395724
10/30/17 10:43 PM
10/30/17 10:43 PM
Posts: 2,449 nc
earthmover
nc
I understand that can..they supposed to be redone by aerospace so that's why I was asking..
Ok just looked over where I asked which pump to use..so never mind I see chip had problems with 1 .thanks
[Re: earthmover]
#2395781
10/30/17 11:55 PM
10/30/17 11:55 PM
Posts: 2,422 Pittsburgh PA
Eric
Pittsburgh PA
Not a fan of the Areospace pump. Wafflebatter on here almost lost a World Championship over one.
5.53 @ 125 1/8th on the launch control..more left in her!
[Re: earthmover]
#2395918
10/31/17 10:13 AM
10/31/17 10:13 AM
Posts: 13,416 Marion, South Carolina [><]
an8sec70cuda
I was gonna go into it again, but I see you found what I'd said earlier, lol. The Moroso I have now is a much better piece.
[Re: earthmover]
#2396097
10/31/17 03:26 PM
10/31/17 03:26 PM
Posts: 19,398 Las Vegas
Al_Alguire
Las Vegas
The biggest issue with the Aerospace pump is the vanes and case. The issue with them going away is the vanes wear off the anodizing on the case. That's why to get it rebuilt it must go back to them. If a Moroso pump starts to not pull as much vacuum you order a set of vanes and off you go...
[Re: Al_Alguire]
#2396116
10/31/17 03:52 PM
10/31/17 03:52 PM
an8sec70cuda
The biggest issue with the Aerospace pump is the vanes and case. The issue with them going away is the vanes wear off the anodizing on the case. That's why to get it rebuilt it must go back to them. If a Moroso pump starts to not pull as much vacuum you order a set of vanes and off you go... Aerospace will gladly sell you a rebuild kit anyway. If you're lucky, the case won't have deep grooves worn in it when you take it apart. If it doesn't yet, it will soon.
[Re: earthmover]
#2396128
10/31/17 04:11 PM
10/31/17 04:11 PM
Al_Alguire
Las Vegas
Guess I should have added to get it repaired properly it needs to go back to them. I have heard they are now anodized inside but not sure if that's true. The one I had years ago was NOT and it was horrible looking inside after two year use and didn't work at well at that point. Moved on and will not look back.
