Hurst Quarter Stick Neutral safety switch #2395106
10/29/17 10:16 PM
10/29/17 10:16 PM
K
Kiddart Offline OP
Kiddart  Offline OP
K
How are you guys wiring your switch on the shifter. I thought I had it correct and its stopped working. I am checking other things but just want to see how you all did yours.
picks are always welcome
thanks
Thank you
Kiddart
Re: Hurst Quarter Stick Neutral safety switch [Re: Kiddart] #2395155
10/30/17 12:05 AM
10/30/17 12:05 AM
baldwinsville new york
a493demon Offline
a493demon  Offline
I just use the stock 727 switch
Re: Hurst Quarter Stick Neutral safety switch [Re: a493demon] #2395175
10/30/17 01:01 AM
10/30/17 01:01 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Yep! When I switched to a Glide I still use the 727 switch, sort of...
Re: Hurst Quarter Stick Neutral safety switch [Re: Kiddart] #2395292
10/30/17 11:25 AM
10/30/17 11:25 AM
K
Kiddart Offline OP
Kiddart  Offline OP
K
I guess I should have told you that I have rewired the car with an aftermarket Wire harness. Does this help to get some info.
Thank you
Kiddart
Re: Hurst Quarter Stick Neutral safety switch [Re: Kiddart] #2395315
10/30/17 12:08 PM
10/30/17 12:08 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
mt qrtr stick has a little switch on the side (came with the shifter) i just run the wire from the relay to the switch and the other side of the switch to a ground on the shifter mount.
Re: Hurst Quarter Stick Neutral safety switch [Re: Dave Hall] #2395423
10/30/17 02:23 PM
10/30/17 02:23 PM
MD
RTSE4ME Online content
RTSE4ME  Online Content
MD
Did it work when you initially wired it ?
Have you tried adjusting the switch on the shifter?
I had to adjust mine to make it work in both park and neutral.
Re: Hurst Quarter Stick Neutral safety switch [Re: Kiddart] #2395428
10/30/17 02:29 PM
10/30/17 02:29 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
I have an aftermarket wiring harness in my Allstate as well. I am using a relay in the starter circuit. I wired the ground side of the relay to run through the 727 switch to complete the circuit to a good ground. Omitting the switch in the shifter. Works for me. up
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Hurst Quarter Stick Neutral safety switch [Re: Kiddart] #2395430
10/30/17 02:29 PM
10/30/17 02:29 PM
K
Kiddart Offline OP
Kiddart  Offline OP
K
It did work, I started the car and all was good, shut car off and everything has power but the starter. I will play around with the adjustment tonight. I have it wired from the starter solenoid thru switch then to ground, just as mentioned above.
I hate electrical problems. T
Thanks so far.
Thank you
Kiddart
Re: Hurst Quarter Stick Neutral safety switch [Re: Kiddart] #2395443
10/30/17 02:53 PM
10/30/17 02:53 PM
MD
MD
Here is the adjustment instructions/diagram
Re: Hurst Quarter Stick Neutral safety switch [Re: Kiddart] #2395536
10/30/17 05:07 PM
10/30/17 05:07 PM
K
Kiddart Offline OP
Kiddart  Offline OP
K
Thank you RTSE4ME,
I have all that and did what they wanted, at least I thought. I am going to give it another try tonight.
Thank you
Kiddart
