W2 360 cam suggestions please! #2394334
10/28/17 07:24 PM
10/28/17 07:24 PM
Edmonton Alberta, Canada
R3DART Offline OP
R3DART  Offline OP
Hi folks. I am bolting together some parts I have accumulated through the years. This is going to be a budget build utilizing as much of the shelves in my garage as possible.
I am starting with stock stroke 360, not looking to build a stroker as the short block is very low miles wilt decent parts.
What I have:
stock stroke 360 w/ flat tops
Heavily ported W2’s
Holley Pro dominator tunnel ram
What I need help with:
camshaft (thinking solid flat, looking for suggestions)
carburetors (thinking eddy’s, again open to suggestions on size and make)
Engine will end up in an A-Body, 3.91 gears and auto.
I would like to go solid flat tappet for cam.
Basically looking to build an old school budget street bruiser that will see the odd day at the track.
Thanks in advance!
Re: W2 360 cam suggestions please! [Re: R3DART] #2394353
10/28/17 08:02 PM
10/28/17 08:02 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Mid/high-250's @.050, 108lsa........pick your favorite brand
Re: W2 360 cam suggestions please! [Re: R3DART] #2394357
10/28/17 08:12 PM
10/28/17 08:12 PM
I like and use comp Cams, for your deal I would look at their part #20-616-5 ,grind #fl272B-6 or the next bigger one Pt #20-635-5, grind #XTQ281S. I would install either one on a 101 to 103 intake lobe center and go have some fun devil up twocents
All the SB I've built and help the owner race like the close LSA and advancing the intake lobe opening from 3 to 6 degrees closer to TDC from straight up up
As far as the carb size and part numbers your on your own with the Eddys confused If you had access to a pair of Holley 1850 I would use those in a heart beat, or maybe a pair of Holley 600 or 650 CFM D.P. work
I'm a drag race guy, so keep that in mind shruggy
Re: W2 360 cam suggestions please! [Re: R3DART] #2394362
10/28/17 08:30 PM
10/28/17 08:30 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
No mention at all of what convertor you will use, nor expected compression.
Without those, no way to spec a cam
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: W2 360 cam suggestions please! [Re: B3422W5] #2394373
10/28/17 08:47 PM
10/28/17 08:47 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Heavily ported doesn’t mean dog poop without flow numbers
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: W2 360 cam suggestions please! [Re: pittsburghracer] #2394387
10/28/17 09:29 PM
10/28/17 09:29 PM
R3DART Offline OP
R3DART  Offline OP
Thanks for the input.
Re: W2 360 cam suggestions please! [Re: R3DART] #2394390
10/28/17 09:33 PM
10/28/17 09:33 PM
R3DART Offline OP
R3DART  Offline OP
Thank you Cab. Your input is much appreciated.
Re: W2 360 cam suggestions please! [Re: R3DART] #2394397
10/28/17 09:48 PM
10/28/17 09:48 PM
R3DART Offline OP
R3DART  Offline OP
B3422W5, I figured there has been enough w2 headed pump gas 360’s built that it would be fairly easy to get a few suggestions.
I have not taken the approach of choosing a camshaft based on what torque convertor I am going to use...heck, I may use a four speed.
But thanks anyway for your feedback.
Pittsburgracer, I’m not sure on the flow numbers and to be honest, I have no intention of taking them to have them flowed.
The heads were purchased from a member here on moparts. They worked very well for him. They were ported by a fellow by the name of Jimmy Bell. That is about all I know.
Either way, was simply looking for some real world suggestions. I thought if any place, this would be where I could get that.
Re: W2 360 cam suggestions please! [Re: R3DART] #2394412
10/28/17 10:17 PM
10/28/17 10:17 PM
PA.
"Little"John
"Little"John
PA.
Why I asked is although the W2 is and can be a fantastic head it peaks funny. 260@.450 and drops like a rock. Proper work and it’s 300 plus easily
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: W2 360 cam suggestions please! [Re: R3DART] #2394416
10/28/17 10:27 PM
10/28/17 10:27 PM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
Now you see why all the great people who used to post on here stopped due to all the BS that goes on here he was asking for a little help and all you want to do is give him some bs story about flow numbers like he said there are alot of 340 360 W2 motors out there id run something in the mid 250 intake low 260 exhaust worked great on my old W2 setup or something like Dons 360 260- 266 Howards cam
Re: W2 360 cam suggestions please! [Re: R3DART] #2394417
10/28/17 10:28 PM
10/28/17 10:28 PM
Saskatchewan (SK)
79410aspenrt Offline
Saskatchewan (SK)
R3DART,
i'm in the process of building a stock stroke 360 with W2 heads. my heads were ported by Jesse Robinson known as RAMM on this site.. they flow 286 cfm.
i'm going to run a solid flat tappet cam. Hughes Engines grind #, STL6468AS. 615/621 lift with 264/268 dur @ .050.
i will use a Victor 340 single plane intake. compression will be at 13.1.
i have used a holley pro dominator tunnel ram in 2 different builds. 360'' and a 440'' SBM stroker. i ran 2 650 holleys.
Re: W2 360 cam suggestions please! [Re: scottb] #2394523
10/29/17 01:04 AM
10/29/17 01:04 AM
PA.
"Little"John
"Little"John
PA.
Your right and I’m sorry. I will never try to help again. Pick up the slack for use please.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: W2 360 cam suggestions please! [Re: scottb] #2394529
10/29/17 01:16 AM
10/29/17 01:16 AM
PA.
"Little"John
"Little"John
PA.
The more I think about it Scott I will give myself a short vacation. Now I’m kinda sorry I grabbed those Summit discount coupons this week at the Halloween Classic for our members. If anyone needs one check out some other mopar sites or Yellowbullet. Maybe Scott will contribute some
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: W2 360 cam suggestions please! [Re: R3DART] #2394558
10/29/17 01:50 AM
10/29/17 01:50 AM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
Now that mr know it all has some free coupons to give away he’s a hero
Re: W2 360 cam suggestions please! [Re: R3DART] #2395037
10/29/17 09:04 PM
10/29/17 09:04 PM
SoCal
Brian Hafliger Offline
SoCal
What I have:
Heavily ported W2’s
Thanks in advance!
If the heads work really good, the TR will push your rpm range up quite high...and unless the valves your using are really lightweight, you may run into high rpm problems (above 7200rpm).
Yes you can run higher pressures, up to a point though...just alot going on with poor tappet angle, largely offset rockers and heavy valve train.
Solid roller would be my recommendation...is this on pump gas?
If so, then solid FT might work as rpm peak will be a bit lower with lower compression.
Brian Hafliger
Re: W2 360 cam suggestions please! [Re: R3DART] #2395065
10/29/17 09:52 PM
10/29/17 09:52 PM
R3DART Offline OP
R3DART  Offline OP
Brian, thank you for the response.
What you are saying makes sense.
I really would like to put that old tunnel ram to use but looks like just to much of a mismatch for what the bottom end will take.
The heads came with a port matched strip dominator. Looks like the TR will stay on the shelf for a while.
Yes, it is going to be a pump gas engine. Open chamber W2’s and flat tops are what I have.
Re: W2 360 cam suggestions please! [Re: R3DART] #2395098
10/29/17 11:04 PM
10/29/17 11:04 PM
Washington
madscientist Offline
Washington
Buy the correct cam for a TR and it won't turn any more RPM than it will with a single 4. And the TR will make more bottom and mid power.
Re: W2 360 cam suggestions please! [Re: R3DART] #2395109
10/29/17 11:25 PM
10/29/17 11:25 PM
Alexandria, NJ
WayneM Offline
WayneM  Offline
Alexandria, NJ
I have Non worked W2 econos on a 10.5 340, and it's pretty happy with this old purple shaft, "653" last of the part #. It measures .528/284/112. Summit still has it but it's expensive. I ran across it just today while helping pick a mild SB cam for a friend. This cam is happy with a 10" converter and 4.30's. Its been running 12.30's for a couple of decades now.
2014 Durango R/T
2004 Dodge Ram 3500 SRW SLT short quad Cummins 6 speed
1998 Dodge Durango SLT 5.2
1971 Plymouth Duster-
<<<<<MOPAR SPOKEN HERE>>>>>
Re: W2 360 cam suggestions please! [Re: R3DART] #2395138
10/30/17 12:16 AM
10/30/17 12:16 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
A cam that worked pulled strong in my 12:1 340 was a sig erson solid flat tappet. 258/258-.580/.580-107 in at 107. I had a 4 speed at the time with 4.10 gears.
Re: W2 360 cam suggestions please! [Re: madscientist] #2395139
10/30/17 12:16 AM
10/30/17 12:16 AM
The Great White North
RAMM Offline
RAMM  Offline
[quote=madscientist
Buy the correct cam for a TR and it won't turn any more RPM than it will with a single 4. And the TR will make more bottom and mid power. [/quote]
Was about to post something similar but more exact. Cam does not really dictate max rpm power potential at all. That is all in the induction. Everytime I've used a TR it has lowered RPM peak HP and torque comes up across the board. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
