69 Super Bee WM23H9A280311 #2393503
10/26/17 08:04 PM
10/26/17 08:04 PM
Mike W Offline OP
Mike W  Offline OP
Hello.
I recently purchased a 1968 Super Bee with the wrong stuff in it. I am taking it back to original. Today while taking it apart I found the build sheet, and matching numbers engine and trans for a 1969 Super Bee. I also have the ramcharger hood for the car. If this is your car contact me to collect the goods.
I assume the car was totaled or stripped down, but thought it was worth a shot.
Thanks!
Mike
Re: 69 Super Bee WM239A280311 [Re: Mike W] #2393703
10/27/17 08:51 AM
10/27/17 08:51 AM
Dallas, Texas
FC7cuda Offline
FC7cuda  Offline
Dallas, Texas
I applaud your effort, hope it works out. BTW, you're missing the H in you VIN heading
68 Charger
70 Cuda
Re: 69 Super Bee WM239A280311 [Re: FC7cuda] #2393712
10/27/17 10:01 AM
10/27/17 10:01 AM
blewbyu Offline
blewbyu  Offline
So you are saying the 68 Superbee you bought has the build sheet in the car and also installed in that car is the matching numbers motor and tranny to that build sheet? I'm thinking you bought a 69 Superbee with a 68 vin tag on it now and made to look like a 68. It is to weird the build sheet and motor and tranny are in this car. stirthepot
The only other explanation is motor and tranny and seats were removed from a 69 and installed into the 68 car. twocents
Re: 69 Super Bee WM239A280311 [Re: Mike W] #2393725
10/27/17 10:24 AM
10/27/17 10:24 AM
Pattison Texas
CSK Online shake_head
CSK  Online Shake_Head
Pattison Texas
did you check the body #s ?
Re: 69 Super Bee WM239A280311 [Re: Mike W] #2393748
10/27/17 11:24 AM
10/27/17 11:24 AM
tennessee,usa
mattsmopars Offline
mattsmopars  Offline
tennessee,usa
The body numbers on the car in question are correct for a 1968, and they DO match the fender tag for the car. Someone used a 69 bee to replace a lot of parts on the 68 bee. The original engine and auto trans were replaced along with the K frame, the 383, the 4 speed. The Ramcharger hood replaced the 68 bee hood. Most likely the rear seat was also used out of the 69 bee that all the other parts had been sourced from so that would explain the 69 buildsheet being in it.
Matt
Re: 69 Super Bee WM239A280311 [Re: mattsmopars] #2393914
10/27/17 06:26 PM
10/27/17 06:26 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
I too applaud your efforts and hope they are fruitful.
Unfortunately, the parts usage tend to point to a junked '69.
You never know though...
Stranger things have happened but...
It makes much more sense to me, to replace seats and a motor/trans
and other bolt on parts from a parts car, than to replace the hood, front fenders, grill, core support sheet metal, rear 1/4 panels/side marker lite openings, tail panel & tail lites, for a fraudulent cause.
I have mechanical Aptitude.
I can screw up anything.
Re: 69 Super Bee WM239A280311 [Re: bboogieart] #2394033
10/27/17 10:40 PM
10/27/17 10:40 PM
santa anna, Tx.
charles6970 Offline
charles6970  Offline
santa anna, Tx.
Yep Thinking that 69 superbee is long gone.
Re: 69 Super Bee WM239A280311 [Re: Mike W] #2394142
10/28/17 08:50 AM
10/28/17 08:50 AM
Mike W Offline OP
Mike W  Offline OP
Thanks for the info guys! Yes, for some reason the guy wanted a 69 vs. 68. Not sure if he got in an accident, destroyed the Hemi and couldn't afford to replace it...etc???
I assume the other car is toast. Just figured I would try, as I hope someone else would do the same for me.
Re: 69 Super Bee WM239A280311 [Re: Mike W] #2394185
10/28/17 12:41 PM
10/28/17 12:41 PM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
So,if I am reading correctly the '68 you are restoring is a Hemi car,correct?
RT
Re: 69 Super Bee WM239A280311 [Re: RTSrunner] #2394299
10/28/17 05:37 PM
10/28/17 05:37 PM
Mike W Offline OP
Mike W  Offline OP
RT
Yes it is. It is going to be a bit of a challenging project, but hopefully a fun car. I got it out of Pennsylvania. Hoping to track down the original engine someday, but I realize this is most improbable.
Re: 69 Super Bee WM23H9A280311 [Re: Mike W] #2394655
10/29/17 09:41 AM
10/29/17 09:41 AM
Wisconsin
Big D A12 Offline
Big D A12  Offline
Wisconsin
I do not have any record of this car. The assumption the 69 is long gone is mostly likely correct.
Can you post the EAD and casting dates from the block for us numbers junkies? Thank you.
Seeking 1969 Lynch Road fender tags/Build Sheets/Window Stickers/VIN - Over 2300 so far thanks to you!!
2018 Demon Challenger PY4 A8 Black Hood
2017 Jeep Trail Hawk
2016 Hellcat Challenger PCP A8
1969.5 A12 Super Bee WM21 V1H F6 D21
1969 Coronet RT B5 D32 M46 N96
Re: 69 Super Bee WM23H9A280311 [Re: Big D A12] #2394726
10/29/17 12:32 PM
10/29/17 12:32 PM
Mike W Offline OP
Mike W  Offline OP
I would be happy to. May take me a bit to get back to it. Took it out at my friends place.
