How to... Proper Tire Heating?? #2392282
10/24/17 12:20 PM
10/24/17 12:20 PM
Canada
Kam*Kuda Offline OP
Kam*Kuda  Offline OP
Canada
After reading the 727 explosion and the comment.
Originally Posted By pittsburghracer
A lot of guys do most of the damage on improper tire heating
As a newbie Can you please tell me more about this?
1970 Barracuda Convertible
1968 Satellite Street Strip car
1654.5 Mustang
1955 Land Rover
Re: How to... Proper Tire Heating?? [Re: Kam*Kuda] #2392286
10/24/17 12:33 PM
10/24/17 12:33 PM
Northern N.J.
hemi_doug Offline
hemi_doug  Offline
Northern N.J.
Me too. My daughter is making the move from jr dragsters to big cars next year and I don't want to start her off on the wrong foot. Tire heating isn't as critical in Jrs as they are in the bigger cars....
71 440-6 4spd & 69 Hemi 4spd
Re: How to... Proper Tire Heating?? [Re: Kam*Kuda] #2392293
10/24/17 12:43 PM
10/24/17 12:43 PM
st.louis,mo.
dart games Offline
dart games  Offline
st.louis,mo.
roll out of the water to the edge of the water,some like to spin the tires in the water box,then go to the edge ,all that does is put water in the wheel well,which can fall on tire going down track,start your burnout in 2nd gear,never in 1st,then go to 3rd,count to 5 then roll out,,big smokey burn outs isnt needed,stop clean out the carb then go to the line
Re: How to... Proper Tire Heating?? [Re: Kam*Kuda] #2392300
10/24/17 01:03 PM
10/24/17 01:03 PM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
You need a driver and a crewman to work together until the driver can do it him/her self properly.
1. Make sure there is enough water, not just dampness, tell the guy to spray some more water if you have to.
2. Roll thru water and stop with back tires 2-3 feet past water. Some guys "blip" the throttle going thru the water, I never do this. It spits water inside your wheel wells.
3. Put trans in 2nd gear, hold line lock.
4. Wait for starter to give signal to burnout.
5. Mash the gas pedal 1/2 way, get RPM's up to max (7000 for me). It's OK to hit rev limiter.
6. Shift to 3rd, release line lock, ROLL out of the gas pedal as you move forward. This is where people get in trouble, you can't let off quickly, nor can you tromp down again.
7. Make sure car is lined up in the best groove.
8. MOST IMPORTANT: Stop 3-4 feet from staging beams, put shifter into 1st gear, roll forward to stage, this resets your sprag.
9. If in eliminations, do not stage until you see your dial-in on the score board.
10. If you should suffer driveline breakage of any kind, (axle, gear, wheel studs) the trans has to come out and the sprag inspected.
The guy that blew the trans at Milan probably failed to do one of the above, or maybe the guy that drove the car before him failed.
Re: How to... Proper Tire Heating?? [Re: Kam*Kuda] #2392304
10/24/17 01:11 PM
10/24/17 01:11 PM
Northern N.J.
hemi_doug Offline
hemi_doug  Offline
Northern N.J.
Awesome, thank you. Always better to ask a dumb question then make a dumb move...thanks guys!
We are looking forward to making the move to bigger cars. I am building a 65 Satellite for her (was supposed to be for me but you know how that works), She is 16 now, been racing jrs since 10. made track champ at Numidia this year. She's a great racer and I'm looking forward to seeing how she does in the big leagues.
Re: How to... Proper Tire Heating?? [Re: Kam*Kuda] #2392316
10/24/17 01:42 PM
10/24/17 01:42 PM
jersey
Spaceman Spiff Offline
jersey
Unless you have a manual valvebody, the trans will still start in first gear.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: How to... Proper Tire Heating?? [Re: Kam*Kuda] #2392359
10/24/17 02:55 PM
10/24/17 02:55 PM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
In regards to transmission explosion ask your transmission builder. There are to many variables. There's multiple questions you need answers to before someone can answer that question about your transmission. Add in the typical "I've done it for years" "always do this" "never do this" is a recipe for disaster. For example "never do a burn out in first" ok I put my auto shift trans in 2nd and I'll be fine. Nope. Car will start in first. Or I'll tell you what I do. I ALWAYS do my burnout in manual low and ONLY in manual low. My trans has low band apply and is auto shift. Confused yet? This question needs a flow chart! Just a hint of smoke is all you need, unless your car is setup to need some tire slip. The vast majority over heat the tire. Experiment do less and less of a burnout until it spins the tire. In the end its your daughters feet, so I personaly think the blankets survive better. If it was mine I would buy two blankets one for the trans and I would bolt another on the inside on the floor over the tunnel.
best of 11.39 at 117 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Re: How to... Proper Tire Heating?? [Re: Kam*Kuda] #2392367
10/24/17 03:03 PM
10/24/17 03:03 PM
Northern N.J.
hemi_doug Offline
hemi_doug  Offline
Northern N.J.
Just an aside, do any of you treat your tires? We do in jr dragsters (wd40), just wondering if that is also done in the bigger cars.
When it comes time to do a trans for the build, I will spend the cash on the best equipment I can for the car. I will not be cheep when it comes to the safety equipment needed. The plan is to go with a 505 wedge with Victor heads and a roller. Cal tracs w/mono leafs and a dana with 456 gears and a spool...
Re: How to... Proper Tire Heating?? [Re: Kam*Kuda] #2392369
10/24/17 03:08 PM
10/24/17 03:08 PM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
Wd40? Really! So the tire slips to gain rpm?
Re: How to... Proper Tire Heating?? [Re: cgall] #2392371
10/24/17 03:10 PM
10/24/17 03:10 PM
Cab_Burge Online work
Cab_Burge  Online Work
iagree up
As far as starting in first gear with automatic tranny do not revved it up over 4000 RPM in first unless you have the shifter held in first gear tsk You can manually shift with a automatic as long as your throttle is not wide open, you want the tire speed up to get heat in the tires as soon as possible up
Your best bet is to change the front drum to a billet steel or aluminum to protect her or any one else who drives that car up
Re: How to... Proper Tire Heating?? [Re: FurryStump] #2392372
10/24/17 03:10 PM
10/24/17 03:10 PM
Northern N.J.
hemi_doug Offline
hemi_doug  Offline
Northern N.J.
Softens the rubber...it works GREAT! We never have wheel spin no matter the track prep...We prep the tires after the run and let them sit. Wrap them and remove the wraps in the lanes...water burnout and she's good to go. She runs 7.90 @ 82 mph in the 1/8 mile. 1.64 60 fts.
Re: How to... Proper Tire Heating?? [Re: hemi_doug] #2392374
10/24/17 03:12 PM
10/24/17 03:12 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
No wonder it gets so slick after those chainsaws on a stick go down the track! you guys are greasing the track! - For big cars you can use VHT in your burn-out but usually not needed
Re: How to... Proper Tire Heating?? [Re: Kam*Kuda] #2392375
10/24/17 03:13 PM
10/24/17 03:13 PM
an8sec70cuda Offline
WD-40 will make tires REALLY sticky, but doesn't last very long. After 2 or 3 burnouts, it's back to normal...from my experience anyway.
You don't just spray it on and go run the car. You roll it on and let it soak into the tire overnight.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: How to... Proper Tire Heating?? [Re: an8sec70cuda] #2392379
10/24/17 03:17 PM
10/24/17 03:17 PM
Northern N.J.
hemi_doug Offline
hemi_doug  Offline
Northern N.J.
Exactly, but we use it between runs. It doesn't stay on the tire after the burnout, but it will make them stick. It actually changes the compound of the rubber. It will cause you to wear out the tires fast.
Re: How to... Proper Tire Heating?? [Re: Kam*Kuda] #2392383
10/24/17 03:32 PM
10/24/17 03:32 PM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
I can't get out of first fast enough, usually hit the rev limiter off the line but do a burn out in second then third.
Have a great day
Iowan
"obsolete is neat"
Re: How to... Proper Tire Heating?? [Re: Kam*Kuda] #2392391
10/24/17 03:45 PM
10/24/17 03:45 PM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
Roll through the water and get to the edge, set your line lock and pull second gear start to heat the tires and pull third and take it to 4000 rpm and hold for 5 to 10 seconds just enough to get them hot and roll forward, if you did it correctly you are set to go.
Have a great day
Iowan
"obsolete is neat"
Re: How to... Proper Tire Heating?? [Re: Kam*Kuda] #2392417
10/24/17 04:55 PM
10/24/17 04:55 PM
UK
rb446 Offline
rb446  Offline
UK
I guess 2nd gear start is better, but I always used to start in 1st, right or wrong, no issues, FMVB 727, front of the water, ease down half way and shift 2nd/3rd immediately, tach used to settle on 4800>5000 and with a small amount of smoke from the 14x32 Hoosiers I'd just let off the lock and ease out the throttle gentle or stay in it for some showtime now and again...484hp 440, 4.88's..You shouldn't need to get anywhere near a rev limiter.
1969 'Cuda 446ci, best 9.96@133.9 in 1990
1971 340 'Cuda, best 11.01@122.8 in 1987
Re: How to... Proper Tire Heating?? [Re: Kam*Kuda] #2392608
10/24/17 10:30 PM
10/24/17 10:30 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I do like most as I roll through the water and just pass it about a foot or two. Then hit it in second and run her up to about 6k and shift into third and hold about 6K for about 5 seconds or less if I feel them pushing the car. Then I lift before I release the brake/line lock so the tires wont chirp when I hit dry pavement. Then roll up and stage. Ron
Re: How to... Proper Tire Heating?? [Re: Kam*Kuda] #2392684
10/25/17 12:41 AM
10/25/17 12:41 AM
Canada
Kam*Kuda Offline OP
Kam*Kuda  Offline OP
Canada
Thank you so much for the advice. I understand things vary but the basics help a newbie
So my first time at the track I did really crappy, almost non existant burn outs.
Popped it off the rev limiter one time at 7400 rpm
Got a bit better. Here is a video of a better burnout, probably the 4th try (first part of the video)
Please critique...
https://www.youtube.com/watch?v=jqMdxvWYyq0&t=1s&ab_channel=RobKamstra
1654.5 Mustang
1955 Land Rover
Re: How to... Proper Tire Heating?? [Re: Kam*Kuda] #2392689
10/25/17 12:51 AM
10/25/17 12:51 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Put it in 2nd before you even roll into the water. 2nd gear, rev it. Shift to 3rd, maintain RPM. Get your thumb off the switch as soon as it's up on the tire and drive it out onto the dry concrete while rolling into the throttle some to keep it spinning. That's what builds heat. Lift before it catches. Put it in the beams.
