Small block connecting rods #2391345
10/22/17 05:53 PM
10/22/17 05:53 PM
sioux falls, sd
10sec.dart Offline OP
sioux falls, sd
Looking for some recommendations for rods for my new build, r1 block , w9 heads, 3.79 Callie's crank, looking to be shifting around 7800-8000, I really don't want to use aluminum rods, what's a good h beam for the rpm??
Re: Small block connecting rods [Re: 10sec.dart] #2391346
10/22/17 06:06 PM
10/22/17 06:06 PM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
Callies comp star rods very nice for the money scat makes a good rod also with the arp 2000 bolts just for starters there are many choices when all your looking for is a chevy rod either 2.100 or 2.00 whats the deck height of the block
Re: Small block connecting rods [Re: 10sec.dart] #2391457
10/22/17 09:45 PM
10/22/17 09:45 PM
sioux falls, sd
sioux falls, sd
9.20 deck, I thought the compstars were only rated for 7500 rpm?
Re: Small block connecting rods [Re: 10sec.dart] #2391475
10/22/17 10:09 PM
10/22/17 10:09 PM
New Smyrna Beach FL
scottb Offline
scottb  Offline
New Smyrna Beach FL
Are looking at a 6 inch rod or 6.125 I know motors running the comp star rod running7500 or more what’s your budget for rods Oliver makes a very nice rod like I said it’s only a Chevy there are unlimited options
Re: Small block connecting rods [Re: 10sec.dart] #2391512
10/22/17 10:58 PM
10/22/17 10:58 PM
oregon
greendart408 Offline
oregon
I run 6in Carrillo on my W8 deal, with carr bolts, my block is only a 9in deck. Nice pieces.....
Re: Small block connecting rods [Re: 10sec.dart] #2391877
10/23/17 03:59 PM
10/23/17 03:59 PM
Wisconsin
Medlock51 Offline
Medlock51  Offline
Wisconsin
I'm using stock 340 bushed rods with ARP bolts in my 625HP small block 383 dirt track engine. That's what was in it when I bought the engine however they will not take cold starts with heavy 50W oil... the resulting carnage proves that.
I really like the I-beam Oliver and Crower rods... good stout pieces. Mu buddies have used them in their engines for three seasons without a failure. Carillo's are also good.
I'm using some used NASCAR Pankl rods in my Gen 3 build when I get to it. The have small, lightweight pins and a narrow Honda big end. Weigh in the range of 450 grams IIRC. The nice thing is the price... you can find them on Fleabay for $125/a set or less. Good stuff.
I was going to use a set in my LA engine but I didn't want the expense of repairing my damaged crank ($300) plus the cost of grinding the rod journals to Honda size plus having the nitriding done, too... another $250.00.
Re: Small block connecting rods [Re: 10sec.dart] #2391887
10/23/17 04:12 PM
10/23/17 04:12 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
My old W5 motor saw 7500 at the stripe for years with the Compstars. Pretty sure they are still in the shortblock to this day
Best machine told me they really liked them when we were talking about rod choices.
Took Arrow billet rods out they didnt like.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Small block connecting rods [Re: 10sec.dart] #2391888
10/23/17 04:12 PM
10/23/17 04:12 PM
Tulsa OK
Bad340fish Online content
Bad340fish  Online Content
Tulsa OK
Call Molnar, the 416 in my car has Molnar H beams in it. We gave him the piston wieght to get a peak RPM out of curiousity and he told us 8800. I don't recall the piston weight, the pistons are light but nothing exotic at all.
68 Barracuda Formula S 340
Re: Small block connecting rods [Re: 10sec.dart] #2391894
10/23/17 04:38 PM
10/23/17 04:38 PM
New York
polyspheric Offline
polyspheric  Offline
New York
The H vs. I question has no answer after 100 years.
Boffin Emeritus
