Cuda vs Challenger Back Window ? #239127
02/28/09 07:52 PM
02/28/09 07:52 PM
Colorado
CuriousYella70 Offline OP
Colorado
I was told the rear glass, back window is differnt on a 70 Cuda vs the 70 Challenger. Can someone on here provide me with the dimensions of each window? So from the top of the window to the bottom of the window (chrome to chrome) dead center, as well as width dimensions (chrome to chrome) from the bottom of the window and the top of the window? I'm trying to see if the Cuda window is either shorter or longer than that of the Challenger window, as well as wider or narrower then the Challenger window.
Any help would greatly be appreciated --
Re: Cuda vs Challenger Back Window ? [Re: CuriousYella70] #239128
02/28/09 08:10 PM
02/28/09 08:10 PM
Doo-Dah, KS
440fied Offline
440fied  Offline
Doo-Dah, KS
Cuda rear window has rounded corners on the bottom, Challenger has square corners. You would have to do some major surgery to get either to fit in the others place. I'll get some dimensions posted tomorrow.
Re: Cuda vs Challenger Back Window ? [Re: 440fied] #239129
02/28/09 08:13 PM
02/28/09 08:13 PM
Colorado
Colorado
I'm not looking to put a Cuda window in the place of a Challenger window or visa versa. I'm curious to know the dimensions because of the rear window louvers -- I'm curious to see why they're so different?
Re: Cuda vs Challenger Back Window ? [Re: 440fied] #239130
02/28/09 10:10 PM
02/28/09 10:10 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
The louvers are different for the same reasons he said, different shapes.
Re: Cuda vs Challenger Back Window ? [Re: CuriousYella70] #239131
02/28/09 11:21 PM
02/28/09 11:21 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I've cars equipped with both louvers, the drastic difference between the louvers/windows is that the Cuda rear glass and roof area surrounding the window is more convex, or "bubbled", the Challenger rear window is flat conpared to the Cuda,
Re: Cuda vs Challenger Back Window ? [Re: DAYCLONA] #239132
03/01/09 01:53 AM
03/01/09 01:53 AM
Colorado
Colorado
Thanks guys -- always a huge help!!
