Re: Nice timing cover for big block
[Re: earthmover]
#2389986
10/19/17 07:55 PM
10/19/17 07:55 PM
Posts: 47 CO
Nitrojunkee
CO
Steel is fine with me aluminum is nice but I'm not going to throw a ton of money on it ..i just don't want any leaks if possible I have the Milodon 65650 and it doesn't leak, it's a nice rigid piece.
[Re: Nitrojunkee]
#2389989
10/19/17 08:01 PM
10/19/17 08:01 PM
Posts: 2,449 nc
earthmover
nc
Steel is fine with me aluminum is nice but I'm not going to throw a ton of money on it ..i just don't want any leaks if possible I have the Milodon 65650 and it doesn't leak, it's a nice rigid piece. Thank you I think ill order that tonight
[Re: Stanton]
#2390088
10/19/17 11:32 PM
10/19/17 11:32 PM
Posts: 1,169 Virginia Beach, VA
Old School
Virginia Beach, VA
so are those Walmart sneakers you're wearing !! But it's nothing to switch out a pair of sneakers
68 cuda formula S 588" bb 5sp 70 CUDA CONVERT 500" 5SP (SUBLIME) 70 CUDA CONVERT 500" 5SP (PLUMCRAZY):TOO MUCH HORSEPOWER, IS ALMOST ENOUGH!
[Re: Stanton]
#2390130
10/20/17 01:01 AM
10/20/17 01:01 AM
Posts: 20,195 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Watch the stock ones or cheap chrome ones. I always use a cam button to limit thrust and if you watch the cheapie they will bulge out
[Re: earthmover]
#2391695
10/23/17 11:18 AM
10/23/17 11:18 AM
Posts: 13,380 Marion, South Carolina [><]
an8sec70cuda
I use factory covers on all my stuff.
[Re: earthmover]
#2391770
10/23/17 01:24 PM
10/23/17 01:24 PM
Posts: 4,450 Michigan
MarkZ
Worthy
Worthy
I'm using the 440 Source cover on my motor with a roller cam. Just clocked over a 1,000 miles on it this year and still bone dry. Website claims they're US made.
[Re: MarkZ]
#2391819
10/23/17 02:52 PM
10/23/17 02:52 PM
Posts: 43,274 Bend,OR USA
Cab_Burge
I saw one of 440 Source polished aluminum fabricated covers in their blem section, I ask about it and was told it was return do it not being exactly flat. I'm building a high dollar all new parts 572 C.I. Hemi motor for show car guy that wants everything chromed or polished, I had one of AR Engr. aluminum timing cover on the shelf but the stock water pump won't clear it so I order two of the fabricated polished aluminum 440 Source ones, one of them rocked on the hemi block and one didn't I called them about the bent one and they told me all of them will be slightly bent due to heat warpage when they are welded up They said to bolt the bent one on the block to see if it will flatten out and seal up I installed the front seal in the other non bent one and it is bent now I'm going to bolt it on and see if I can get a .0015 feeler gauge to slide in all the way around it without a gasket, if I can I will use a gasket and some adhesive silicone gasket sealer to seal it up and pray it doesn't leak IHTHs
[Re: AndyF]
#2391832
10/23/17 03:04 PM
10/23/17 03:04 PM
Cab_Burge
Neither one of my Mopar brand aluminum water pump housing would clear on that World block I used yours on one of my roller cam race motors for the thrust button, it has a 1/4 thick front motor plate on it
