1974 charger rear leaf spring isolators
#2387464
10/14/17 07:58 PM
10/14/17 07:58 PM
Posts: 342 dracut mass usa
sparcy
dracut mass usa
is there a kit to eliminate the isolators ? or can you just cut them off and weld on new pads ?
IF YOU ARE NOT WRECKING STUFF YOU ARE NOT LEARNING !
Re: 1974 charger rear leaf spring isolators
[Re: sparcy]
#2387657
10/15/17 11:28 AM
10/15/17 11:28 AM
Posts: 6,096 Valencia, España
NachoRT74
Valencia, España
Or simply get 71/72 lower/shock plates ( probably earliers work too??? ) fill the axle pedestal hole with a washer and remove the springs "hat" bushings from guide studs.
Maybe will need shorter U bolts too.
[Re: sparcy]
#2387663
10/15/17 11:33 AM
10/15/17 11:33 AM
Posts: 2,415 Connecticut
Ron_M
Connecticut
FWIW - You can also get poly bushings from PST.
Common sense is a flower that does not grow in everybody's garden
[Re: sparcy]
#2387675
10/15/17 11:54 AM
10/15/17 11:54 AM
NachoRT74
Valencia, España
I think he meant the spring pads used on 73 and lates assemblies. Which BTW are also available on poly.
