Re: Base plate for Holley [Re: Bad340fish] #2387976
10/16/17 01:19 AM
10/16/17 01:19 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
What were they...........
Re: Base plate for Holley [Re: fourgearsavoy] #2388195
10/16/17 03:05 PM
10/16/17 03:05 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Keep an eye on youtube they will probably release it soon, they checked everything from a stock single snorkle(lost 150HP) to a stainless steel salad bowl cut to fit the carb and sealed with a K&N filter top. It was a really cool episode, they relase it on Motor Trend on demand first for members but it should eventually hit youtube.
68 Barracuda Formula S 340
Re: Base plate for Holley [Re: Bad340fish] #2388383
10/16/17 09:14 PM
10/16/17 09:14 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
thumbs beer
Re: Base plate for Holley [Re: Thumperdart] #2388581
10/17/17 05:03 AM
10/17/17 05:03 AM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
They found that as the base drop increases, so does restriction. They literally took a large metal salad bowl, with a K&N filter lid, and ADDED hp to the BBC 750 hp mule. Velocity stacks still work.
Re: Base plate for Holley [Re: Leigh] #2392537
10/24/17 08:45 PM
10/24/17 08:45 PM
Rittman Ohio
fourgearsavoy Offline OP
Rittman Ohio
Well my engine doesn't like the spacer as jetted. It has a lean stumble at tip in that it didn't have before the spacer so either I try and jet up and tune my pump shot or just change the base plate shruggy
I was whipped by a ZO6 Vette last weekend at the track laugh2 He got hook on street rubber and I blew the tires off at the hit but I had his bumper at the stripe.
Talked to him after the race and he said he heard my coming about half track drive
Gus beer
64 Plymouth Savoy
Dana 60
Re: Base plate for Holley [Re: fourgearsavoy] #2392550
10/24/17 09:15 PM
10/24/17 09:15 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
What spacer..........
Re: Base plate for Holley [Re: Thumperdart] #2392672
10/25/17 12:17 AM
10/25/17 12:17 AM
Rittman Ohio
Rittman Ohio
Just a basic 1" spacer with a port on it for a PCV hose. It's definitely running lean because it was never "cold blooded" before. I'm just gonna get a baseplate for it and get rid of the spacer and go back to way my engine used to run.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Base plate for Holley [Re: fourgearsavoy] #2392733
10/25/17 02:21 AM
10/25/17 02:21 AM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Rich-en it up w/the mixture screws first or idle bleeds since those are easy enuff to do and if it's in the cruise zone that will help. Worse case, jet up a bit IF you are on the boosters.........
Re: Base plate for Holley [Re: Thumperdart] #2393033
10/25/17 07:36 PM
10/25/17 07:36 PM
Rittman Ohio
Rittman Ohio
Thanks Dom.
I turned the mixture screws out and it brought the idle up and a little more smooth and easy. I have never changed the air bleeds so I'm gonna have to get some do a little research on which ones are the idle bleeds. I still have a power valve on the primaries and I'm thinking of changing it to a higher number and see if it helps with my tip in stumble.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Base plate for Holley [Re: fourgearsavoy] #2393050
10/25/17 08:03 PM
10/25/17 08:03 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Outer's idle, inner's next to bowl vents hi speed bleeds..........If the idle came up, it's talkin to ya......... thumbs Are they adjustable or fixed.........
Re: Base plate for Holley [Re: Thumperdart] #2393076
10/25/17 09:13 PM
10/25/17 09:13 PM
Rittman Ohio
Rittman Ohio
Yeah they're screw in bleeds on a Proform 1050 body with Quickfuel blocks and bowls. It's got a Quick fuel cast baseplate too. I should probably get an AFR gauge kit and really get it dialed in because I know how to read my plugs but on a street/strip car it's hard to get a good clean read on them.
I'm going to pull the bleeds that are in there now so I know where to go with them.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Base plate for Holley [Re: fourgearsavoy] #2393126
10/25/17 10:49 PM
10/25/17 10:49 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
With all of the EFI talk and this and that stuff, we as carb guys need data as well and a WB is our friend as a "directional" tool to help get us dialed in just the same.......... thumbs
