Base plate for Holley #2387504
10/14/17 10:39 PM
10/14/17 10:39 PM
Rittman Ohio
fourgearsavoy Offline OP
Rittman Ohio
Is this base plate OK for use with 4-corner idle carb.
I need to have port to attach a vacuum gauge and a PCV valve and my current Quick Fuel base doesn't have any ports on it.
I was going to get this Quick Fuel replacement and I was just wondering if it would work. I really don't know how to identify a 4-corner idle base plate.
help
Gus beer
64 Plymouth Savoy
Dana 60
Re: Base plate for Holley [Re: fourgearsavoy] #2387516
10/14/17 10:53 PM
10/14/17 10:53 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Why not drill the intake for vacuum?
Re: Base plate for Holley [Re: rickraw] #2387537
10/14/17 11:31 PM
10/14/17 11:31 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Or a 1 inch spacer if you have room
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Base plate for Holley [Re: fourgearsavoy] #2387553
10/15/17 12:14 AM
10/15/17 12:14 AM
AndyF Offline
AndyF  Offline
Looks like 4 corner idle hard to know for sure with a low res picture. Best to call the tech line and tell them what you are doing. BLP has a baseplate that will work if QF doesn't. I've done this trick before using a BLP baseplate.
Re: Base plate for Holley [Re: AndyF] #2387574
10/15/17 01:28 AM
10/15/17 01:28 AM
Rittman Ohio
Rittman Ohio
Well the nice thing about living 20 minutes from Summit is that I can look at it before I buy it.
I may still just go with a spacer an re-engineer my air cleaner with a 1" shorter element because there's not much room with the Performer RPM and a stock hood.
I would drill the intake but it's a dual plane and I would have to go into the side of the plenum and I would really like to get a better signal to this new PCV.
Thanks guys up
Gus beer
64 Plymouth Savoy
Dana 60
Re: Base plate for Holley [Re: fourgearsavoy] #2387578
10/15/17 01:43 AM
10/15/17 01:43 AM
PA.
"Little"John
"Little"John
PA.
Thanks guys up
Gus beer
I just bought this air cleaner base from summit because I wanted to put an air pan on my Duster and needed it dropped down because of my high intake and 1 inch spacer. It dropped me down 2 inches.
Untitled by John Cadamore, on Flickr
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Base plate for Holley [Re: pittsburghracer] #2387582
10/15/17 01:55 AM
10/15/17 01:55 AM
Rittman Ohio
Rittman Ohio
That looks like one of those circle track deals,I might have to look at one of those. I'd like to keep my 4" element.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Base plate for Holley [Re: fourgearsavoy] #2387583
10/15/17 02:08 AM
10/15/17 02:08 AM
CA
crackedback Offline
crackedback  Offline
CA
Looks like it's 4 corner.
Does not have the transfer channel from primary to secondary feed port.
Re: Base plate for Holley [Re: crackedback] #2387674
10/15/17 11:53 AM
10/15/17 11:53 AM
Rittman Ohio
Rittman Ohio
Well I think I'm going with a spacer and a shorter air filter. My engine might actually benefit with an open spacer shruggy I have always wanted to try it so here is my opportunity.
I really didn't want to disturb a good running carb anyway and the spacer is pretty inexpensive compared to new carb base.
Thanks guys
Gus beer
64 Plymouth Savoy
Dana 60
Re: Base plate for Holley [Re: fourgearsavoy] #2387677
10/15/17 12:01 PM
10/15/17 12:01 PM
PA.
"Little"John
"Little"John
PA.
Thanks guys
Gus beer
Hope it helps you. Do yourself a favor and either install the fitting before installation or at least check out the threads. Most of these spacers are mass produced and the taps are way past being worn out. Easier to check on the workbench than while bending over a fender.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Base plate for Holley [Re: fourgearsavoy] #2387686
10/15/17 12:11 PM
10/15/17 12:11 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
I believe that is a four corner idle base plate. The holes on the outside of the transfer slots are the idle ports. There are four. Sine most cars benefit from a spacer, I would rather go that approach, myself. I would make sure there are 2 holes. 1 for the PCV, 1 for your vacuum gauge. You won't get an accurate vacuum reading if you use the same port where you already have a vacuum leak coming in (PCV is only a regulated vacuum leak).
[image][/image]
Re: Base plate for Holley [Re: fourgearsavoy] #2387698
10/15/17 12:31 PM
10/15/17 12:31 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Thanks guys
Gus beer
Yep, and if you run the WIX racing a 3" flows more than your present carb iirc and I run one w/a 1050 or 1150 dommy w/out issues. Plus the added plenum volume usually helps accordingly.......... beer
Re: Base plate for Holley [Re: fourgearsavoy] #2387739
10/15/17 02:04 PM
10/15/17 02:04 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Gus I'm running an Allstar drop base air cleaner (4150) on my Dart. The guys that dynoed my engine do a lot of dirt track stuff and said that the Allstar base and lid along with the Wix racing filter Dom mentioned made more power on the dyno than anything they had tested.
Before anyone says anything, yes I know and so do they that dyno's aren't in an actual operating environment so take for what it's worth.
Re: Base plate for Holley [Re: justinp61] #2387763
10/15/17 03:42 PM
10/15/17 03:42 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Here's another thought....K&N SUCKS the power outta your motor NOT adds it..........fact......... beer
Re: Base plate for Holley [Re: pittsburghracer] #2387775
10/15/17 04:14 PM
10/15/17 04:14 PM
Washington
madscientist Offline
Washington
Thanks guys up
Gus beer
Can you post a link to that base PBR? I just looked on summit and I don't see it.
Re: Base plate for Holley [Re: madscientist] #2387799
10/15/17 05:40 PM
10/15/17 05:40 PM
PA.
"Little"John
"Little"John
PA.
https://proshop.summitracing.com///parts/AFC-80550
Then I cut this out by hand.
Then I cut out the hole.
Then I drilled and bolted them together.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Base plate for Holley [Re: fourgearsavoy] #2387807
10/15/17 06:14 PM
10/15/17 06:14 PM
Washington
Washington
Thank you.
Re: Base plate for Holley [Re: madscientist] #2387867
10/15/17 09:22 PM
10/15/17 09:22 PM
Rittman Ohio
Rittman Ohio
Well I put the spacer under the carb and installed my new Wenger PCV valve and the engine seems to idle smoother. I haven't driven it yet to get some butt dyno figures but the air is really cool around here now so it's hard to tell.
I'm thinking of hitting the Halloween thing at D42 this weekend so we'll see how the spacer works on the track.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Base plate for Holley [Re: Thumperdart] #2387881
10/15/17 09:53 PM
10/15/17 09:53 PM
Rittman Ohio
Rittman Ohio
Yeah Dom I gotta laugh when a car rolls into the shop with a "cold air kit" It's next to impossible to beat the factory set-up on any car. Many times I try to get customers to go back to a factory filter and they won't because they believe the hype laugh2
Gus beer
64 Plymouth Savoy
Dana 60
Re: Base plate for Holley [Re: fourgearsavoy] #2387929
10/15/17 11:35 PM
10/15/17 11:35 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
The Engine Masters show did a test with like 40 different air filters recently, pretty interesting results!
68 Barracuda Formula S 340
