Re: Base plate for Holley
[Re: Bad340fish]
#2387976
10/16/17 01:19 AM
10/16/17 01:19 AM
Thumperdart
State of confusion
What were they...........
[Re: fourgearsavoy]
#2388195
10/16/17 03:05 PM
10/16/17 03:05 PM
Posts: 8,037 Tulsa OK
Bad340fish
Tulsa OK
Keep an eye on youtube they will probably release it soon, they checked everything from a stock single snorkle(lost 150HP) to a stainless steel salad bowl cut to fit the carb and sealed with a K&N filter top. It was a really cool episode, they relase it on Motor Trend on demand first for members but it should eventually hit youtube.
68 Barracuda Formula S 340
[Re: Leigh]
#2392537
10/24/17 08:45 PM
10/24/17 08:45 PM
Posts: 10,558 Rittman Ohio
fourgearsavoy
Rittman Ohio
Well my engine doesn't like the spacer as jetted. It has a lean stumble at tip in that it didn't have before the spacer so either I try and jet up and tune my pump shot or just change the base plate ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) I was whipped by a ZO6 Vette last weekend at the track ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif) He got hook on street rubber and I blew the tires off at the hit but I had his bumper at the stripe. Talked to him after the race and he said he heard my coming about half track ![drive drive](/ubbthreads/images/graemlins/custom/drive.gif) Gus ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: Thumperdart]
#2392672
10/25/17 12:17 AM
10/25/17 12:17 AM
fourgearsavoy
Rittman Ohio
Just a basic 1" spacer with a port on it for a PCV hose. It's definitely running lean because it was never "cold blooded" before. I'm just gonna get a baseplate for it and get rid of the spacer and go back to way my engine used to run. Gus ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
[Re: fourgearsavoy]
#2392733
10/25/17 02:21 AM
10/25/17 02:21 AM
Thumperdart
State of confusion
Rich-en it up w/the mixture screws first or idle bleeds since those are easy enuff to do and if it's in the cruise zone that will help. Worse case, jet up a bit IF you are on the boosters.........
[Re: Thumperdart]
#2393033
10/25/17 07:36 PM
10/25/17 07:36 PM
fourgearsavoy
Rittman Ohio
Thanks Dom. I turned the mixture screws out and it brought the idle up and a little more smooth and easy. I have never changed the air bleeds so I'm gonna have to get some do a little research on which ones are the idle bleeds. I still have a power valve on the primaries and I'm thinking of changing it to a higher number and see if it helps with my tip in stumble. Gus ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
[Re: fourgearsavoy]
#2393050
10/25/17 08:03 PM
10/25/17 08:03 PM
Thumperdart
State of confusion
Outer's idle, inner's next to bowl vents hi speed bleeds..........If the idle came up, it's talkin to ya......... ![thumbs thumbs](/ubbthreads/images/graemlins/custom/thumbs.gif) Are they adjustable or fixed.........
[Re: Thumperdart]
#2393076
10/25/17 09:13 PM
10/25/17 09:13 PM
fourgearsavoy
Rittman Ohio
Yeah they're screw in bleeds on a Proform 1050 body with Quickfuel blocks and bowls. It's got a Quick fuel cast baseplate too. I should probably get an AFR gauge kit and really get it dialed in because I know how to read my plugs but on a street/strip car it's hard to get a good clean read on them. I'm going to pull the bleeds that are in there now so I know where to go with them. Gus ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
