Re: refresh wiring harness
[Re: prairiechicken1]
#238731
02/28/09 03:13 PM
02/28/09 03:13 PM
340dart4spd
Parts Problem
Parts Problem
any ideas on how to make original harness look more appealing - all work, would just like cleaner looks
thanks!
If it's just wiring harness.. I would replace it...it will save you trouble in the long run...
[Re: 340dart4spd ]
#238733
02/28/09 03:23 PM
02/28/09 03:23 PM
Posts: 2,592 None
71rm23
None
thanks!
[Re: THESHAKERPROJECT]
#238734
02/28/09 10:25 PM
02/28/09 10:25 PM
Posts: 3,076 Renton, Wa.
Classof70Chally
super gas
super gas
Renton, Wa.
You can take the harness out of the car, unrap it ,clean any overspray with mineral sprits/thinner/reducer ect. Clean all the connecters and re-rap them with the correct harness wrap (Eastwoods,Yearone)and they will look great.
Lacquer thinner is a little rough on vinyl and plastics. Stick with common paint thinner (mineral spirits) or denatured alcohol. Straight Simple Green works pretty good also.
[Re: Classof70Chally]
#238736
02/28/09 11:34 PM
02/28/09 11:34 PM
Posts: 9,065 Milwaukee, WI
In_The_Pink
Milwaukee, WI
I used Simple Green for as much as I could, then LT for stubborn paint overspray and super dirty areas. As suggested, use LT only when necessary as it's a strong solvent.
