Fitech guys, 12v source for white wire?? #2380836
10/02/17 08:59 PM
10/02/17 08:59 PM
E Central IN
N
nd65 Offline OP
nd65  Offline OP
N
E Central IN
Running factory electronic ignition. Jumped white wire to battery to get it going. What do you suggest as a source for the white wire?
Thanks,
nd65
nd.neal@gmail.com
Re: Fitech guys, 12v source for white wire?? [Re: nd65] #2381077
10/03/17 03:23 AM
10/03/17 03:23 AM
AndyF Offline
AndyF  Offline
Depends if you have a ballast resistor or not. With EFI you should be using the ECU to run the ignition so in that case you don't need the ballast so you should be able to use J2 and J3 on the ignition switch.
Look at the wiring diagram for your vehicle and then double check with a volt meter.
Re: Fitech guys, 12v source for white wire?? [Re: AndyF] #2381129
10/03/17 09:46 AM
10/03/17 09:46 AM
NY usa
540challenger Offline
NY usa
I think the op issue is he is running the fitech for the fuel system only and factory ignition. So under the hood he would need to keep the ballast wires, today I will be checking under the dash to find another key source that doesn't lose voltage while cracking
Re: Fitech guys, 12v source for white wire?? [Re: 540challenger] #2381139
10/03/17 10:09 AM
10/03/17 10:09 AM
E Central IN
N
nd65 Offline OP
nd65  Offline OP
N
E Central IN
Correct 540. Running factory electronic ignition, fuel only on the Fitech.
Andy, the car is a 65 Coronet 500, maroon w/white top. Very similar to yours.
Re: Fitech guys, 12v source for white wire?? [Re: 540challenger] #2381185
10/03/17 11:48 AM
10/03/17 11:48 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Originally Posted By 540challenger
while cracking
Maybe if he stayed off the crack he could figure it out
Don't be the exception.
Re: Fitech guys, 12v source for white wire?? [Re: Supercuda] #2381196
10/03/17 12:03 PM
10/03/17 12:03 PM
E Central IN
N
nd65 Offline OP
nd65  Offline OP
N
E Central IN
Thought about running a seperate illuminated fused toggle switch to the battery for power. It would require me to flip this switch on and off at startup/shutdown.
Thoughts?
Re: Fitech guys, 12v source for white wire?? [Re: nd65] #2381202
10/03/17 12:11 PM
10/03/17 12:11 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
All you need to do is use the run line and the start line, tap them both through a diode and use that for your connection.
It is not rocket science.
Use the diode to prevent back feed from one source to the other.
Re: Fitech guys, 12v source for white wire?? [Re: nd65] #2381291
10/03/17 04:18 PM
10/03/17 04:18 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
Yep, diode is the easiest way.
Re: Fitech guys, 12v source for white wire?? [Re: John_Kunkel] #2381332
10/03/17 06:04 PM
10/03/17 06:04 PM
E Central IN
N
nd65 Offline OP
nd65  Offline OP
N
E Central IN
Thanks Supercuda,
John, thank you very much for the drawing.
Did a little research on diodes and kind of getting it now. What diode would you recommend I get?
Thanks,
nd65
Re: Fitech guys, 12v source for white wire?? [Re: nd65] #2381369
10/03/17 07:17 PM
10/03/17 07:17 PM
E Central IN
N
nd65 Offline OP
nd65  Offline OP
N
E Central IN
I get it now!!
Ignition 2 is the start mode and has 12 volts while cranking (brown wire).
Ignition 1 is run mode (blue wire). It has 12 volts when you let off the key when the engine starts.
The diode is basically a check valve. It only allows current to flow 1 way.
The diode gets wired from ignition 2 to ignition 1. This will allow 12 volts from the ignition 2 start (or crank) mode to flow to ignition 1 run mode. When the engine starts and you let off the key the diode (or check valve) prevents the 12 volts from ignition 1 from flowing back to ignition 2. Thus, ignition 1 always has 12 volts and the Fitech is happy.
Re: Fitech guys, 12v source for white wire?? [Re: nd65] #2381379
10/03/17 07:52 PM
10/03/17 07:52 PM
BDW Online content
BDW  Online Content
Re: Fitech guys, 12v source for white wire?? [Re: BDW] #2381395
10/03/17 08:25 PM
10/03/17 08:25 PM
E Central IN
N
nd65 Offline OP
nd65  Offline OP
N
E Central IN
Thanks CNXT
Re: Fitech guys, 12v source for white wire?? [Re: nd65] #2382187
10/05/17 12:20 AM
10/05/17 12:20 AM
Colorado
denfireguy Offline
denfireguy  Offline
Colorado
Originally Posted By nd65
Thanks Supercuda,
Thanks,
nd65
1N4000 series are great for this. (1N4001, 4002, 4003, etc) and you can buy a bunch for a dollar.
Craig
Re: Fitech guys, 12v source for white wire?? [Re: denfireguy] #2382313
10/05/17 10:10 AM
10/05/17 10:10 AM
E Central IN
N
nd65 Offline OP
nd65  Offline OP
N
E Central IN
Thanks Craig.
I could not find anything in the archives on this. Perhaps this could be moved there.
nd65
Re: Fitech guys, 12v source for white wire?? [Re: nd65] #2387078
10/13/17 09:44 PM
10/13/17 09:44 PM
E Central IN
N
nd65 Offline OP
nd65  Offline OP
N
E Central IN
UPDATE.
Thanks for your help guys. The diode wired to the ballast resistor wires works. I used an IN9004 from Radio Shack. There are still a few of them open in Indiana.
Re: Fitech guys, 12v source for white wire?? [Re: nd65] #2387087
10/13/17 10:05 PM
10/13/17 10:05 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
excellent
Re: Fitech guys, 12v source for white wire?? [Re: nd65] #2387280
10/14/17 11:46 AM
10/14/17 11:46 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
I get it now!!
Correct... the Diode keeps working the ballast to the coil in run correctly with the decayed power.
there was a nice discussion about this couple of months ago. A relay can be used too allong with diode, but makes a bigger and "complex" installation. Not required if the source needed is mainly just for triggering, and not for sourcing more than the stock system
Re: Fitech guys, 12v source for white wire?? [Re: nd65] #2387287
10/14/17 11:56 AM
10/14/17 11:56 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
I'm wondering about the posibility of a modified ballast to hide this diode jumping job, cuting the ceramic on back with a dremmel enlarging the groove and solding to the existant ballast ends on groove... would be an interesting job!
Of course, prongs will need to be labeled to plug Ign 1 and 2 on the same position allways
Re: Fitech guys, 12v source for white wire?? [Re: nd65] #2387449
10/14/17 07:11 PM
10/14/17 07:11 PM
BDW Online content
BDW  Online Content
I thought about trying to hide the diode, ibut the diode was pretty big and didn't see a clean way to make a channel on the solid ballast.
Re: Fitech guys, 12v source for white wire?? [Re: BDW] #2387684
10/15/17 12:11 PM
10/15/17 12:11 PM
moparx Offline
moparx  Offline
if using a single ballast, would a duel [four pin] ballast work using the unneeded section [after removing that section's guts] as a place to hide the diode ?
beer
