Re: O-ringed R1 block and mls gaskets
[Re: 10sec.dart]
#2386516
10/12/17 09:35 PM
10/12/17 09:35 PM
Posts: 4,457 Washington
madscientist
Washington
So has anybody ran a o ringed block with cometic mls gaskets? Is there a way to do it? It's already a short deck so milling the deck is not a option I want to do, my w9's are not o-ringed Just fill the grooves with JB weld and file them smooth.
[Re: 10sec.dart]
#2386570
10/12/17 10:35 PM
10/12/17 10:35 PM
madscientist
Washington
That's the problem, it's already a 9.20 deck height and I don't want to mill it anymore I've done it many times and never had a failure. One thing is where they put the groove. If it's out of the fire ring you may get lucky and not have to do anything to the grooves. I just fill them off and get them flat. It's just easier.
[Re: 10sec.dart]
#2386592
10/12/17 11:13 PM
10/12/17 11:13 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
That's the problem, it's already a 9.20 deck height and I don't want to mill it anymore All I did was remove the o ring, the grooves are still there.
[Re: 10sec.dart]
#2386673
10/13/17 03:09 AM
10/13/17 03:09 AM
Posts: 43,233 Bend,OR USA
Cab_Burge
What's wrong with putting a receiver groove in the heads to match the O rings on the block? Is this a ten head bolt block or 18 bolt block?
