Page 3 of 6 1 2 3 4 5 6
Re: Best PCV valve? [Re: fourgearsavoy] #2384821
10/09/17 11:54 PM
10/09/17 11:54 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Well guys we have more than enough to make the order but if it's OK I'm gonna wait until I get home tomorrow to see if anyone else want's in on this deal.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Best PCV valve? [Re: fourgearsavoy] #2384822
10/09/17 11:54 PM
10/09/17 11:54 PM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
It's fine by me.
Re: Best PCV valve? [Re: fourgearsavoy] #2385055
10/10/17 12:56 PM
10/10/17 12:56 PM
moparx Offline
moparx  Offline
pm sent gus.
beer
Re: Best PCV valve? [Re: UCUDANT] #2385324
10/10/17 10:36 PM
10/10/17 10:36 PM
New Mexico
UCUDANT Online content OP
Troll Hunter
UCUDANT  Online Content OP
Troll Hunter
New Mexico
Huge thanks to Moparx for answering my original question (with this part), and now the masses responded with a purchase smile that's good stuff
Don't forget to source a grommet that will work in your application guys
Re: Best PCV valve? [Re: UCUDANT] #2385335
10/10/17 10:49 PM
10/10/17 10:49 PM
NC, USA
davenc Offline
davenc  Offline
NC, USA
Just to share a thought, I gutted a parts store PCV valve and used a standard grommet, then ran the parts store PCV to an oil/vapor separator before going to the remotely mounted MEWagner valve.
Re: Best PCV valve? [Re: UCUDANT] #2385345
10/10/17 11:04 PM
10/10/17 11:04 PM
St Louis, MO, USA
srunge55 Offline
srunge55  Offline
St Louis, MO, USA
thanks davenc, I have been thinking about the best way to setup the pcv system. I was thinking the pcv valve would go in the VC and connect to a vacuum source on the carb base. Then on the other VC I would run AN hose directly to a catch can with a breather on top. I'd love to get some advice on how others have done this, pics would be great too.
Thanks,
Steve
Re: Best PCV valve? [Re: srunge55] #2385349
10/10/17 11:13 PM
10/10/17 11:13 PM
NC, USA
davenc Offline
davenc  Offline
NC, USA
As mentioned, I run a gutted parts store PCV on the drivers valve cover to a vapor/oil separator mounted on the drivers side of the motor above the oil filter (BB), then from the separator to the MEMagner valve at the back of the motor (cheaply mounted on a bracket bolted to the valley pan retainer at the moment) then to the PCV port on the carb.
This keeps oil from potentially gumming up the MEMagner valve over time. The downside is that I had to buy the MEMagner inline adaptor for some extra $ to make the plumbing work.
There is a breather on the passenger side VC.
Re: Best PCV valve? [Re: UCUDANT] #2385362
10/10/17 11:34 PM
10/10/17 11:34 PM
St Louis, MO, USA
srunge55 Offline
srunge55  Offline
St Louis, MO, USA
I understand now. I was thinking a baffle in the VC would help prevent the valve getting gummed up. This does explain why they have the inline valve setup in the first place.
Re: Best PCV valve? [Re: davenc] #2385365
10/10/17 11:35 PM
10/10/17 11:35 PM
NC, USA
davenc Offline
davenc  Offline
NC, USA
Here are some pics of my setup. My first goal was to make it functional and then tune. The to-do list has an item to make the install nicer, particularly mounting of the ME valve.
Re: Best PCV valve? [Re: davenc] #2385369
10/10/17 11:41 PM
10/10/17 11:41 PM
Rittman Ohio
Rittman Ohio
OK guys this thing really took off and I got an E-mail from the company and she said if it would be easier if each member could contact her individually.
Here is the E-mail:
Thank you for your information regarding the Group Buy. If it is easier for
you, please have the members who are interested in participating send me
their information just like you did. When I get 8 names, I will then send
out the invoices through PayPal. Please call if you have any further
questions.
Barbara Wagner
Customer Service
M/E Wagner Performance Products
barbara.wagner@mewagner.com
www.mewagner.com
570-899-4544
Just mention that you are with the Moparts group buy and the discount will be applied to your order.
I'm kinda overwhelmed I thought it would be hard to get 8 orders now we have twice as many.
Gus beer
64 Plymouth Savoy
Dana 60
Re: Best PCV valve? [Re: fourgearsavoy] #2385426
10/11/17 01:56 AM
10/11/17 01:56 AM
The Pale Blue Dot
Skeptic Offline
Skeptic  Offline
The Pale Blue Dot
I just got the e-mail off Thanks again Gus for getting the ball rolling thumbs
Re: Best PCV valve? [Re: Skeptic] #2385553
10/11/17 12:16 PM
10/11/17 12:16 PM
moparx Offline
moparx  Offline
sent of my e-mail as well gus ! THANK YOU for getting this deal set up ! bow punkrocka up
beer
Re: Best PCV valve? [Re: UCUDANT] #2385593
10/11/17 01:14 PM
10/11/17 01:14 PM
Colorado front range
BcudaChris Offline
BcudaChris  Offline
Sent mine off last night. Thanks again Gus, for stepping up and getting this going!
Re: Best PCV valve? [Re: UCUDANT] #2385610
10/11/17 01:36 PM
10/11/17 01:36 PM
Caldwell, Idaho
67R/T4speeder Offline
Caldwell, Idaho
Email sent, I am in for one
Re: Best PCV valve? [Re: UCUDANT] #2385648
10/11/17 02:48 PM
10/11/17 02:48 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
My order is in for two, thanks for the leg work Gus
Joe
P.S. as an aside I called Fram tech support to see if they had any specs on the PCVs that some said are better for our application, i.e. low idle vacuum, He knew some were for some GM and Ford hi-perf engines but could not come up with any real numbers, so I opted for the adjustable one rather than guess.
Joe
Re: Best PCV valve? [Re: jlatessa] #2385874
10/11/17 08:39 PM
10/11/17 08:39 PM
Rittman Ohio
Rittman Ohio
I'm glad the group buy deal is working, I just received my invoice and I cant wait to get my valve. Since my carb doesn't have a port for vacuum and they don't recommend using an intake runner source I will need to drill my plenum. I was going to use the booster port on my Performer RPM intake but I guess that wont work so I'm going to pull the intake and find a good spot to drill and tap for a source.
Does anyone else have this situation?
Gus beer
64 Plymouth Savoy
Dana 60
Re: Best PCV valve? [Re: UCUDANT] #2385896
10/11/17 09:22 PM
10/11/17 09:22 PM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
I'm running one on my 99 Dakota. I started out with clear tubing and saw oil going into the plenum. I fine tuned the idle and cleared that up. There was oil weeping from the grommet around the vent elbow that would not adjust out.
I replaced that elbow with the gold colored vent cap ( the 70s style) and the weeping was cured.
I found later the original elbow was 50% blocked with casting flash.
I could not believe how well the idle and driveability improved.
Re: Best PCV valve? [Re: UCUDANT] #2385899
10/11/17 09:38 PM
10/11/17 09:38 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
My center carb has a port below the throttle blade I can use, but the original PCV was connected to a port under the rear carb in the intake.
I'll have to look at the schematic to see if my memory is correct.
I would imagine the central port might be the one to use when calibrating
the new PCV.
I'll try both to see if there's a difference when I get ours.
Joe
Well, I was wrong again!! PCV tube goes to center carb!
Rear fitting in intake must be for power brakes??
Re: Best PCV valve? [Re: UCUDANT] #2385917
10/11/17 10:06 PM
10/11/17 10:06 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I am curious how much that valve cost ? Myself I have been using a stock 318 PCV valve on my eng for about 2 years now and its working good for me. Ron
Re: Best PCV valve? [Re: UCUDANT] #2385923
10/11/17 10:18 PM
10/11/17 10:18 PM
St Louis, MO, USA
srunge55 Offline
srunge55  Offline
St Louis, MO, USA
I think they are $127 + shipping normally, $97 with free shipping with the group by discount. Still pretty expensive considering what a normal pcv valve cost. I hope its worth the money. Lots of good feedback on this valve.
Steve
