Screwed up, let fuel go bad. Shelf/tank life?
#2384094
10/08/17 08:48 PM
10/08/17 08:48 PM
Posts: 17,841 S.E. Michigan
ZIPPY
S.E. Michigan
For those not following my saga I had got a decent tuneup happening on the street and was getting ready to start suspension tuning. Then my daily driver got totalled and music stuff was still non stop so I let the GTX sit again. Well I screwed up big time and forgot to put stabilizer in the gas, 3 months later...varnish smell. Flushed system with stabilized gas and got it running with spare carb. Need to order a kit and go through the carb that was on it....as it's blowing raw fuel out The exhaust with the one that got the bad fuel. When warm 20w50 drains like apple juice it's obvious Some fuel got in there. Still kicking myself for forgetting.
My Buddy the 30-something year marine mechanic says he's seeing pump fuel go bad in as little as 30 days.
What kind of shelf life are you guys getting from pump gas?
Rich H.
Esse Quam Videri
Re: Screwed up, let fuel go bad. Shelf/tank life?
[Re: ZIPPY]
#2384135
10/08/17 10:21 PM
10/08/17 10:21 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
Using a overdose of Sta-Bil,I get quite a long life with fuel. I use double the amount for 5 gallons of fuel.
[Re: ZIPPY]
#2384169
10/08/17 10:53 PM
10/08/17 10:53 PM
Posts: 6,257 gulfport, ms, west mi
rowin4
My cars set for 8 months while I'm out of state. I don't put in any additive , just have close to a full tank. Haven't had a problem in 5 years. Starts right up and run they fine. These are carburetor cars also. Yesterday the hurricane was coming so I figured I should see if the generator would start and run, haven't used it in a couple years, put on the choke, one pull and it fired right up. Just cheap 87 octane.
[Re: ZIPPY]
#2384279
10/09/17 04:16 AM
10/09/17 04:16 AM
Posts: 43,127 Bend,OR USA
Cab_Burge
The last comment I would trust from a oil company rep. was that most pump gas has a 90 day shelf life in the car in area that have a 20 + F swing from day to night temps. As far as yours stinking like shellac in that little time makes me wonder how old it was when you bought it I have some old non ethanol 91 octane Oregon pump fuel sit in our snow blower from winter three years ago to last winter when it did snow again enough to get it out and it still started and ran decent It sits in a non heated garage and the winter to summer temps out here vary from low teens in the winter to high 90s in the summers
[Re: ZIPPY]
#2384659
10/09/17 07:35 PM
10/09/17 07:35 PM
ZIPPY
S.E. Michigan
Thanks for the replies. Sounds like it's probably rotten luck.
Maybe it was already old when I bought it....that's my current thought.
There's really no reason for the varnish smell to happen so quickly, other than it was no good in the first place...
There might be regional considerations too, not sure, I know they blend it differently for different weather but not much beyond that. Went and stocked up on stabilizer and will just try a little harder to remember use that whenever it sits, from now on. It sat for four years with stabilized gas and fired right up.
Rich H.
Esse Quam Videri
