Help with a problem on my 440 #238408
02/27/09 09:40 PM
02/27/09 09:40 PM
west palm beach, florida
modelmakerinc Offline OP
Hey all, I was taking my car out for cruise night and as I was leaving I noticed a water leak from under #3 & #5 exhaust port.
I am thinking it is a head gasket and the water is wicking up the head bolt?, or what where would this be coming from.
big pic sorry about the size but I wanted you to get a good look.
Exceptional Architectural, Yacht and Automotive scale models. e-mail modelmakerinc@att.net for a portfolio review. www.modelmakerinc.com
Re: Help with a problem on my 440 [Re: modelmakerinc] #238409
02/27/09 09:56 PM
02/27/09 09:56 PM
Kirkland, Washington
Pacnorthcuda Offline
Simple, your exhaust header stud is leaking, thats all. You need to disco the header, (just from the head), remove the stud (may as well do all) and re-install with thread sealant on the studs.
Re: Help with a problem on my 440 [Re: Pacnorthcuda] #238410
02/27/09 10:09 PM
02/27/09 10:09 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
It is very common to have a 2" long horizontal crack in the cylinder head under the center exhaust ports. I'd bet a dollar that's what it is... sorry!
Re: Help with a problem on my 440 [Re: TRENDZ] #238411
02/27/09 10:22 PM
02/27/09 10:22 PM
It is not the studs, I use hi temp silicone on the header flange because of poor welding/ sealing of the headers. if it is the head, How can I confirm without dissasembly.
Re: Help with a problem on my 440 [Re: modelmakerinc] #238412
02/27/09 10:38 PM
02/27/09 10:38 PM
if you want to bring it by the shop, i'd be happy to take a look at it for you.
Re: Help with a problem on my 440 #238413
02/27/09 10:47 PM
02/27/09 10:47 PM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
Did you put those studs in dry? It would only take a few minutes to pull that stud and replace it with a header bolt with a dab of silicone on it.
Re: Help with a problem on my 440 [Re: cgall] #238414
02/27/09 10:51 PM
02/27/09 10:51 PM
believe it or not the studs are original to the heads, I requested the machine shop to leave them installed throughout the process. I can assure you they are not leaking.
Re: Help with a problem on my 440 [Re: TRENDZ] #238415
02/27/09 11:21 PM
02/27/09 11:21 PM
I have seen around a dozen or more 906 heads with cracks under the center exhaust ports, it is a weak point in the engine design IMO. People will drain the block and not install antifreeze, especially racers. The heads have a water passage under the exhaust ports that does not drain and ends up freezing causing the crack I have seen machine shops(non Mopar knowleable usually) miss those cracks when the inspect and magnaflux those heads
Re: Help with a problem on my 440 [Re: Cab_Burge] #238416
02/27/09 11:25 PM
02/27/09 11:25 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Looks like a good excuse to put some better heads on it....
Re: Help with a problem on my 440 [Re: 1_WILD_RT] #238417
02/27/09 11:36 PM
02/27/09 11:36 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
for a minor leak like that I would dump a jug of Bars leak or other good sealer into it and forget it. It will seal with no problem I am sure. Seen worse ones than that sealed and never give any sign of a problem.
Re: Help with a problem on my 440 [Re: MoparforLife] #238418
02/27/09 11:44 PM
02/27/09 11:44 PM
MR_P_BODY Offline
MR_P_BODY  Offline
.... sure wont hurt to dump a can in
Re: Help with a problem on my 440 [Re: MR_P_BODY] #238419
02/28/09 12:37 AM
02/28/09 12:37 AM
sc
tjmarcus1 Offline
tjmarcus1  Offline
sc
i think you are gonna find a crack. common place for it.
Re: Help with a problem on my 440 [Re: tjmarcus1] #238420
02/28/09 06:45 AM
02/28/09 06:45 AM
Rudolph, Ohio
moparguy7074 Offline
Rudolph, Ohio
I had the exact same problem on a set of 906 heads. Thought it was leaking around the head bolts, nope, cracked head.
