Re: My car is really close to the 10's
[Re: Uncle Barry]
#2384126
10/08/17 09:53 PM
10/08/17 09:53 PM
Posts: 9,894 MI, usa
dvw
MI, usa
Plugs look clean. I may just try dropping the secondary jets down one more size and try it. I'm not sure if it's smart to drop 3 sizes smaller on the secondary circuit than what the primary is. So I think I'll wait for a wideband. Eddy's can easily go 3 sizes leaner on the secondary. No metering rod restriction. Lately guys have been telling me they've dynoed as far lean as 107/089. Doug
[Re: Uncle Barry]
#2384280
10/09/17 04:34 AM
10/09/17 04:34 AM
Posts: 43,352 Bend,OR USA
Cab_Burge
Which eddy 750, the smoggers with the electric chokes or the non smoggers with the mechanical chokes? If the smoggers look at each plug from a WOT pass at the end of the track to tune off of ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) The OEM Carters had a much smaller jet in the right hand side secondary jet(.069 diameter), passenger side rear carb. which was needed to prevent flooding # 8 cylinder at WOT ![work work](/ubbthreads/images/graemlins/custom/work.gif) On your deal with that manifold you probably won't need to do that ![shruggy shruggy](/ubbthreads/images/graemlins/custom/shruggy.gif) Are you running the linkage like stock or one to one ? Most drag Radials don't work well on bad tracks, they are faster than the same size bias ply tires on a good track. Your close to reaching your goal and have the parts needed to get the job done, go have fun and test until your happy ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
[Re: Uncle Barry]
#2384333
10/09/17 11:07 AM
10/09/17 11:07 AM
Posts: 13,416 Marion, South Carolina [><]
an8sec70cuda
If you can unbolt your headpipes and slide em over so you can run open headers, you'll have your 10 sec timeslip. Hemis hate mufflers. Nice car!!!
[Re: Uncle Barry]
#2384405
10/09/17 12:58 PM
10/09/17 12:58 PM
Posts: 14,515 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
You mentioned unported heads. Some are better ootb than others.
Which heads are you running?
[Re: Uncle Barry]
#2384664
10/09/17 07:43 PM
10/09/17 07:43 PM
Posts: 17,924 S.E. Michigan
ZIPPY
S.E. Michigan
It's a good place to be. I never thought I'd be stuck at this same point for quite this long, but does it bother me? All things considered, not a bit....Good running, nice looking car you got there.
Rich H.
Esse Quam Videri
[Re: Uncle Barry]
#2384689
10/09/17 08:19 PM
10/09/17 08:19 PM
Thumperdart
State of confusion
I think Dom will tell me to throw them in the trash ![laugh2 laugh2](/ubbthreads/images/graemlins/custom/laugh2.gif) . I run them because I want the stock look on my car. They work well in pairs and I understand the "look" thing but a w/b is your friend..........Runs good and a couple of tweaks and 10's will be there.............
[Re: Uncle Barry]
#2384766
10/09/17 10:33 PM
10/09/17 10:33 PM
Posts: 511 Temperance, MI
68 HEMI GTS
Temperance, MI
My roadrunner knocked off an 11.04 first pass with the 511. Figured shoot, it's just gonna run 11.0's. Next pass was 10.95, then 10.92. Feels good when you get it, even if it is only by a little! Street car with no roll bar. Nice ride you have, keep tuning! https://i.imgur.com/0PTLj5T.jpghttps://i.imgur.com/s2A4gPb.jpg
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780# 69 Roadrunner 511 six pack 10.92 drive to track street car
