max wedge exhaust port
#2383604
10/07/17 10:21 PM
10/07/17 10:21 PM
dartman366
Mt. Vernon, Ohio
what is the port size dimentions for a max wedge exhaust port at the header flange??
Re: max wedge exhaust port
[Re: dartman366]
#2383856
10/08/17 01:31 PM
10/08/17 01:31 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
An ootb replacement MP 518-M MW head has ex openings that are - 1.760 x 1.340
An Edelbrock RPM head has ex openings that are - 1.650 x 1.200
[Re: fast68plymouth]
#2383894
10/08/17 02:33 PM
10/08/17 02:33 PM
dartman366
Mt. Vernon, Ohio
Thanks guy's, it looks as if my Hedman fenderwell headers are big enough for the MW port as my copper gaskets with the sealing rib are not wide enough to cover the opening in the flange and had apperent leak's in areas around the openings so I need to use different gasket, any suggestion's, I looked on Superformance's web site, but he apperently does not make them.
[Re: AndyF]
#2383959
10/08/17 04:38 PM
10/08/17 04:38 PM
dartman366
Mt. Vernon, Ohio
The ports in the TF 240 head is much smaller than the header ports, looks like I need a standard MW flat gasket since the rib's on the standard port copper gaskets are inside the header flange opening and that's where they are leaking in spots.
[Re: 70dusterjohn]
#2384024
10/08/17 06:18 PM
10/08/17 06:18 PM
dartman366
Mt. Vernon, Ohio
Does TF recommend a gasket for there head ??? Or maybe call summit tech line since TF is owned by them maybe they would have an answer for you. Thanks, I will give that a try, getting ready to get on their web site now and if I don't come up with an answer then they will get a call. Thanks
