used cam/lifters into another block. Problem or OK?
#2382376
10/05/17 01:01 PM
10/05/17 01:01 PM
RapidRobert
Well used cam/lifters in the right order (318) to go into another engine (360) to get it running to sort out leaking head gasket issue, will there be a problem with this? A guy mentioned once that the slight lifter bore angle difference from engine to engine would be an issue. thank you for your time.
Re: used cam/lifters into another block. Problem or OK?
[Re: DrCharles]
#2382381
10/05/17 01:08 PM
10/05/17 01:08 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Some feel that it's OK but you have to go through another break-in since there are slight differences in lifter bores. Others will tell you not to even try. Or just go ahead and run it if you're using stock or near-stock spring pressures. Or buy an inexpensive new Summit cam/lifter set (which then needs a break-in)... So, to translate... I dunno. Me, used stock 318 cam and lifter in a stock 360, I'd just run it. But that's my opinion, not interested in guessing other's opinions.
[Re: Supercuda]
#2382393
10/05/17 01:39 PM
10/05/17 01:39 PM
Posts: 3,380 St. Charles, MO
wingman
Uncreative Title
Uncreative Title
St. Charles, MO
So, to translate...
I dunno.
I'm afraid all you are going to get on this topic is opinions. I'd wager that NO cam/lifter manufacturer is going to endorse/recommend this practice. And I'm sure you'll get guy's chiming in with anecdotes: "I've done it and it ran 100,000 miles" or "My buddy did it and trashed his motor". I'd be shocked if there has been any kind of study done to say yea or nay. Ultimately it comes down to how much you have invested in the motor and how much you want to invest, it's intended use, the life you hope to get out of it, and how lucky do you feel...
1969 Dodge Coronet Super Bee 383 A4 1970 Plymouth Road Runner 440 FC7 (sold)
[Re: wingman]
#2382427
10/05/17 02:40 PM
10/05/17 02:40 PM
RapidRobert
this is the leaking head gasket from Hell eng (5th fireup just went bad) so I do not feel lucky! Thanks a bunch guys...
[Re: RapidRobert]
#2382510
10/05/17 04:28 PM
10/05/17 04:28 PM
Posts: 1,809 North Dakota
Azzkikrcuda
North Dakota
I have a Bigblock Mopar 484 cam and lifters that just went into its 5th engine last week. I had to replace the lifters this time because they got rusted from sitting. I expect no problems, lobes still look nice.
The only Carbs I care about are under the hood!
[Re: RapidRobert]
#2382519
10/05/17 04:39 PM
10/05/17 04:39 PM
Posts: 1,255 Columbus, GA
Michael Ecks
Columbus, GA
I would do it with no break in and no worry, but I've pretty lucky with such things. If you're concerned and assuming the wear pattern on the cam itself looks normal, then get a fresh set of lifters and go through normal cam run in proceedure. Coat cam with high pressure grease, verify lifter rotation, break in additive, 30 min at 2200 rmp or so, change oil, etc. etc.
"The happiness of your life depends upon the quality of your thoughts" ~ Roman Emperor Marcus Aurelius
[Re: Paul_Fancsali]
#2382623
10/05/17 08:06 PM
10/05/17 08:06 PM
RapidRobert
Alright You (all) have convinced me, I will go ahead & not sweat it, this is actually going to be brief run in times to try & sort out the head gasket situation. I did not want a potential bunch of metal in there if it turns out I can resolve this with just a gasket change as opposed to a complete tear down (#6) but I don't feel lucky!
[Re: RapidRobert]
#2382668
10/05/17 09:12 PM
10/05/17 09:12 PM
Posts: 96,662 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
I've done it, no break-in, no problems.
And it wasn't no stock cam either, high lift, somewheres in the .530" or more. Been MANY years ago, in the late '60s, '68 or '69.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: Kern Dog]
#2382699
10/05/17 10:07 PM
10/05/17 10:07 PM
RapidRobert
Lifters do not rotate in the bores. If the cam and lifters were fine in the first engine and the lifters rotate easily in the 2nd block, there is no reason to anticipate a failure if you use good oil. Noted, I will confirm they rotate when I hand spin the cam.
[Re: RapidRobert]
#2382864
10/06/17 09:50 AM
10/06/17 09:50 AM
Posts: 637 West Central Wi.
1969 HEMI R-T
West Central Wi.
I put a used purple shaft in my 340 years ago. but I did install new lifters. never had a problem. the oil quality then may have helped!
HEMI,S ARE FOREVER!!!
[Re: Neil]
#2383063
10/06/17 06:02 PM
10/06/17 06:02 PM
Posts: 2,861 Pattison Texas
CSK
Pattison Texas
I sold a used 268 comp cam for $20.00 years ago to a friend and he installed it in his engine with new lifters and ran it no problems. As far as I know that engine is still together.
I wonder if there was some way the cam companies couldn't do a break-in before selling them? Make up some sort of machine that replicates the top half of an engine that runs off an electric motor for 20 minutes while motor oil is being recirculated over the moving parts. I bet people would pay more for a cam that was ready to go, or closer to it. So long as the lifters spin free in the customers block it seems like there would be a little less to worry about. Here you go, Camshaft break in machine CLICK HERE
