Re: Alternator over charging........ [Re: Bad340fish] #2381211
10/03/17 12:39 PM
10/03/17 12:39 PM
State of confusion
Thumperdart Offline OP
State of confusion
Good info and yes, most of my driving these days is a few miles testing carbs so I will put the charger on a couple times a week the get new batteries asap...........thankxxx.......... thumbs
Re: Alternator over charging........ [Re: Thumperdart] #2381224
10/03/17 12:56 PM
10/03/17 12:56 PM
MR_P_BODY Offline
MR_P_BODY  Offline
A big part of your issues are that your
alt is too small on the output.. it gets
by for the longer drives but the shorter
runs it cant recover
wave
Re: Alternator over charging........ [Re: MR_P_BODY] #2381229
10/03/17 01:01 PM
10/03/17 01:01 PM
State of confusion
State of confusion
I agree and need more output than the 60 amps this puts out so is there a better version in this style.......... thumbs
Re: Alternator over charging........ [Re: Thumperdart] #2381335
10/03/17 06:13 PM
10/03/17 06:13 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I'm sure there is... I run a Denso 3 wire so I run
a separate voltage reg.. I just run the Chrysler one
its 85a
wave
Re: Alternator over charging........ [Re: MR_P_BODY] #2381440
10/03/17 09:34 PM
10/03/17 09:34 PM
State of confusion
State of confusion
I'd prefer an internal reg. if possible........
Re: Alternator over charging........ [Re: Thumperdart] #2381445
10/03/17 09:41 PM
10/03/17 09:41 PM
Parts unknown
590 Challenger Offline
Parts unknown
They make one wire conversions for nearly all the Denso's, I keep them on hand to sell to the starter and alternator rebuilders. Most are about $20 and can be changed with a Phillips screwdriver in just a couple minutes alternator is off
Re: Alternator over charging........ [Re: 590 Challenger] #2381739
10/04/17 12:52 PM
10/04/17 12:52 PM
State of confusion
State of confusion
How does this make my 60 amp better or does it........... thumbs
Re: Alternator over charging........ [Re: Thumperdart] #2382043
10/04/17 08:10 PM
10/04/17 08:10 PM
Parts unknown
Parts unknown
It doesn't, what it does when you are wiring in something else it makes easy for people to wire (especially people that aren't good at it)It does cure many wiring issues to it, separate voltage regulators more wires that can go bad. Also makes the engine compartment cleaner without extra wires, that's all. A 60 amp will charge 60 amps. But for about the same price and work you can switch them to 16 Volt if that is ever wanted.... just tossing my 2 cents in
Re: Alternator over charging........ [Re: 590 Challenger] #2382062
10/04/17 09:29 PM
10/04/17 09:29 PM
State of confusion
State of confusion
Appreciate the info but I'll stick to 12 volts for now and maybe just have you send me a better version of mine if you have em say in 80+ amps............ beer Or not............. work
