Measure the inside diameter of your inner spring and then look at the Viton seal specs. that Comp offers,(maybe check with Goodson also
![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
) they sell more then one inside diameter dual spring. If the inner spring is at least .060 larger than the outside diameter of a seal that is offered to slip or press onto the stock valve guide outside diameter buy them
I'm thinking that the press on Viton seals come in three different inside press on sizes, .620, .530 and .500 for 3/8, 11/32 and 5/16 valve stems
![scope scope](/ubbthreads/images/graemlins/custom/scope.gif)
I bought the cutters and all three size guides so I can prepare, machine, the guides for the seals I need on the race motors I build instead of having to take them to a shop and wait
![wrench wrench](/ubbthreads/images/graemlins/custom/wrench.gif)
