Re: Looking for GOOD air shocks ro something like that.
[Re: 71birdJ68]
#2379550
09/30/17 10:11 PM
09/30/17 10:11 PM
Posts: 36,840 South San Francisco, Californi...
MidPenMopar
Looking for fun? Keep looking
Why do you need to adjust ride height? The problem with air shocks is the upper bracket where they mount isn't made for that kind of abuse. So i have been told, but there is not any wear on that area and all looks good. I carry a lot of weight between people and stuff in the car and need to raise and lower it when needed.
[Re: 71birdJ68]
#2379581
09/30/17 11:13 PM
09/30/17 11:13 PM
Challenger 1
Cincinnati, Ohio
Why do you need to adjust ride height? The problem with air shocks is the upper bracket where they mount isn't made for that kind of abuse. I had a pair of these under a E body I bought mostly for parts. I did drive it one time and seemed fine and it had good stance, azz was not sagging. LINK
[Re: Challenger 1]
#2379650
10/01/17 12:06 AM
10/01/17 12:06 AM
MidPenMopar
Why do you need to adjust ride height? The problem with air shocks is the upper bracket where they mount isn't made for that kind of abuse. I had a pair of these under a E body I bought mostly for parts. I did drive it one time and seemed fine and it had good stance, azz was not sagging. LINK Thank you those look like a good place to start.
[Re: MidPenMopar]
#2379880
10/01/17 12:37 PM
10/01/17 12:37 PM
Posts: 8,670 Buford, GA
I_bleed_MOPAR
Buford, GA
... I carry a lot of weight between people and stuff in the car and need to raise and lower it when needed. So I guess shackles are out of the question?
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
[Re: I_bleed_MOPAR]
#2379897
10/01/17 12:55 PM
10/01/17 12:55 PM
Posts: 16,149 Mesa, Arizona
dart4forte
Mesa, Arizona
... I carry a lot of weight between people and stuff in the car and need to raise and lower it when needed. So I guess shackles are out of the question? Shackles and sidepipes
Abe Lincoln
[Re: dart4forte]
#2379912
10/01/17 01:15 PM
10/01/17 01:15 PM
MidPenMopar
... I carry a lot of weight between people and stuff in the car and need to raise and lower it when needed. So I guess shackles are out of the question? Shackles and sidepipes Well i tried, but going in i knew it was a lost cause.....
